Question about Promaster 7500DX for Nikon TTL Flash
Promaster 7500 D Digital Flash usage with Nikon D70
I have a promaster 7500DX flash and I'm trying to use it with my Nikon D70. I've used it before, but can't remember which settings on the camera work with the flash. I know it sounds crazy, but which ones are they? I know it's a few...
  • 3 Answers
You need to go to your cameras menu and set your flash function to m ( no to ttl) set it in full M and then it works hope it works that works for me i had the same problem
Posted on Oct 05, 2010
I have a Nikon promaster FL120 flash. I put new batteries in it and now it won't work. What could be the issue?
If it was working and the only thing you did was change batteries. it can really only be two things. Bad batteries or they were not put in correctly.
Try another set set batteries that are fresh out of the box and also make sure they are put in the flash in the correct way.
Dec 11, 2014 | Promaster SystemPro Universal Light Stand...
Is it ok to use a promaster 7000m flash with a canon eos t1i? I don't want to damage the camera.
Yes, the Promaster 700M, with its trigger voltage of about 3 volts, is safe to use with modern digital cameras.
Mar 06, 2011 | Canon EOS 400D / Rebel XTi Digital Camera
Manual for promaster flash
Select your flash unit from
http://www.promaster.com/products/products.asp?CatID=150
Aug 29, 2010 | Cameras
Cannot get my Promaster 7500DX (for Nikon) to sync with my D-200 Nikon camera. Can you help me ???
go to your cameras menu and set your flash mode to the section of full manual and then click that, never on ttl, and set you flash also in the leter M and it will works
Jun 12, 2010 | Promaster 7500DX for Nikon TTL Flash
Is it compatible to use with a Nikon D-50?
No, the Vivitar 283 does not have TTL (Through The Lens metering capability) and the voltage in the flash may be much higher than that in the camera. Some of the old 283 flashes had a very high operating current that, when the flash is left one and removed from the camera can damage the camera operating circuts. Find a Nikon SB 400, 600, 800 or 900 speedlite, or a Promaster 7200 or 7500 for a great less expensive flash for this camera.
Nov 20, 2009 | Vivitar 283 Flash
Promaster 7500dx problem
Send the flash back to Promster for repair, they are real good about fixing or replacing products.
Sep 05, 2009 | Promaster 7500DX for Canon TTL Flash
What flash for Nikon D80
No, the FT1700 is not TTL compatible which is what the camera wants to use. The Promaster 7500EDF is compatible in all modes with the Nikon D80
Jun 20, 2009 | Promaster FT1700 Flash
Promaster Spectrum 7 Lens
I believe Promaster does not have any lenses with focus motor in the lens, so it will not autofocus with your D60. Their AF versions for Nikon will work with your camera's metering system for proper exposure, but you would have to focus manually.
Dec 30, 2008 | Nikon D60 Digital Camera with 18-55mm lens
Lock disc mechanism stuck
Try to put some silicone oil to the thread the disc is turning on. The oil slowly penetrates into the gap and lets the disk rotating. Car dashboard shine sprays often contain silicone oil, check the ingredients.
Laszlo
Nov 13, 2008 | Promaster 7500DX for Canon TTL Flash
Promaster 7500DX for Nikon TTL Flash Logo
345 people viewed this question
Top Promaster Cameras Experts
teddyboy
Lawrence Oravetz
Are you a Promaster Camera Expert? Answer questions, earn points and help others
