Question about Hifonics Car Audio & Video
I got a hifonics xx-zeus mono 1600 watts rms amplifier and I turned the car on and my subs were working and they just cut out.I looked at my amp after I turned the car off and turned it back on and notice that my amps power source lights was not lighting up,but I know the amp was getting power still because the rest of the amp was lighting up.I opened the amp and then realized the problem.On the sides of the amp inside I seen were there was burn marks were these little black medal squares that has three prongs that's sawdered onto the rest of the amp. The black squares that were burned has writing on them.Four of them say\irfp064n\ i r 48\327l 3f\ and three of them say\irfp064n\i r 48\327l 9e\. I want to buy those parts and just sawder them back on.there was also this white sticky stuff under these seven little black squares to hold the black squares in place,so I would also need to get that as well.Do you know any were I can purchase these items.
    Genius:
  • 1,011 Answers
Sir,
click this link for order your spare parts or try at ebay
thanks
good luck
Posted on Dec 05, 2008
    Genius:
  • 1,239 Answers
  • 10,594 Answers
Check eBay and there is a lot available on reasonable price.
White glue is Thermal Compound and used to transfer heat to heat sinks.
Good Luck.
  • 2,326 Answers
You will be able to find those power MOSFETS by clicking here you will see different places where to buy them from. The white sticky thingy is called thermal compound and it should be apply before you solder the new MOSFETS.
    Sergeant:
  • 276 Answers
    Sergeant:
  • 217 Answers
Try  www.bestbuy.com or radioshack.com to get the required parts.
Protect light amp
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
would definitely look at getting it repaired. These new amplifiers can't hold water to an old school Zed audio hifonics Zeus.
Jul 31, 2013 | Hifonics XX-Zeus Car Audio Amplifier
Hifonics colossus-ltd dual monoblock amp does not have much output, running a cerwin vega stroker dual 2 ohm sub wired 4 ohm load bridged
Bridge at 4ohms your only getting 600watts rms. You will need to bridge at 1ohm (parallel) and adjust the gain accordingly. This will give it 1600 watts rms. If you would of had a dual 4ohm sub, then you could of bridged it at 2ohms mono, but you can't you have to go either 1 ohm or 4ohm. I believe it's not getting enough power.
May 20, 2012 | Hifonics Colossus-ltd Dual Monoblock 3200w...
I have a xx zeus 1600 rms amp when i plug in the bais control knob the musuc cut of and protect light comes on what can be the cause knob dont even light up
did bias plug come with amp or is this aftermarket?
bias knobs are manufacturer specific. do not assume 1 bias control will work with different amps.
(even though the RJ11 jack is similar, they are wired differently)
your lucky your amps internal circuitry is detecting the short your introducing.
May 08, 2011 | Hifonics Brutus BX 2005D Car Audio...
Why does the hifonics bxi1608d 1600 watt super D-class mono have 2 postive terminals and two negative terminals? would that cause my speakers to blow?
That is still a single channel cass D amp. Each (-) and each (+) terminal are connected so its actually like only having one. This is so you can hook speakers up in a series circuit to lower impedance, because this amp is 1ohm stable. What causes your speakers to blow is too much power. What kind of speakers are you running? This hifonics amp is very powerful, they are getting big in the competition industries beacuse they put our true power for less money and they are tough. That 1600 amp you have may be putting out more like 1800 watts at 14.4 volts which is 900 per sub at 1ohm so be careful this amp has tons of power and its true rated its not like a sony or rocksford or kenwood that says 1800 max and then in small writing it says 500 rms. This amp puts out true. I have 3 hifonics amps and love them.
May 07, 2010 | Hifonics BXi1608D Car Amp
Does this amp have dual 2GA inputs-Hifonics XX-ZEUS
Mono amps have single power in so if it is stereo then it should have two.
Apr 25, 2010 | Hifonics XX-Zeus Car Audio Amplifier
How i wire my sub to my jbl gto301-1iiamp with 2 Hifonics HFi12D4
If the amp is 1200 watts at 2 ohm stable you will want to set up the speakers as parrallel and bridge the amp. That means conncect the speakers with + to + and - to -. Look at the amp connections. Usually thereare connects that look like this:
If yours look like this use the diagram on top. You will use the + for the left ouput on the amp to the right - on the amp. This will allow you to use all the power from the amp. Be sure to lower the gain as to not pop the speakers or amp.
Nov 17, 2009 | JBL GTO 301.1II Subwoofer Mono Amp - 200W...
I have 3 hifonics zeus Size: 12 inch Impedance: Single 4 Ohms Peak Power Handling: 800 watts RMS Power Handling: 400 watts Sensitivity: 89.9 dB Aluminum Cast Basket American Spider For Reliable Performance...
Hello king3132,
Three 4 ohm subs can be wired parallel for a 1.34 ohm final load or series for a 12 ohm load. If you have the channels of the amp bridged, I hope that the subs are connected in series because the Sony XM-2200GTX is NOT rated for or stable at 1.34 ohms. It's only stable down to 4 ohms.
You definitely will not get the maximum potential of the subs from that amp. They can handle 400 watts RMS each (total 1,200 watts) and the amp is only capable of 500 watts RMS into 4 ohms (less at higher impedance), so each sub could only be getting a maximum of 166.6 watts RMS.
Hope this helps.
Jul 20, 2009 | Digital Audio Car Audio & Video
Make the sub pop and hum and no rca wire are hooked in?
first off nice choice on the amp check ur power and ground connections make sure the main battery to bady ground is good if questionable add a new one cant hurt to have extra grounds from the batt to the body make sure the amp ground is as short as u can make it make sure its grounded to bare metal if any of these dont work u may have a prob inside ur amp
May 06, 2009 | Hifonics XX-Zeus Car Audio Amplifier
What is best amp to run 2 12 inch cvr's
12In Kicker CVRs
are Dual Voice Coil, and You can run each voice coil around 200 Watts RMS
So each sub will have a 400 Watt RMS and 800 Watts peak.
Now since you have 2, Your total will be 800 Watts RMS and 1600 Watts Peak.
I would get really any amp that sits at around 800-1000 Watts RMS.
These are kicker but they are low end so i wouldnt push them to the extreme.
1000-1200 Watts RMS Max and but keep the Gain down on the amp. They will hit no doubt but i wouldnt push these subs or you will be disapointed in the long run.
I would get a Fosgate or MTX amp.
You can get any amp really but find something right around 1000 Watts RMS and it will push those well.
You can go mono block or a 2 channel, just depends on how you want to wire them.
Be careful though. If your running them bridged right now with your mono block, do not run them parallel bridged on a 1000w RMS Amp, you will blow them so fast lol
(RMS = Root Mean Square. Or in other words is the continuous wattage being sent from the amplifier to the subwoffers)
Feb 15, 2009 | Kicker KX1200.1 Car Audio Amplifier
XX- ZEUS MONO D- CLASS / 1600 WATTS RMS
It's likely that the amplifier has shorted output transistors. If that's the case, they will have to be replaced. If you have zero experience with electronic repair, you should pay someone to repair it instead of trying to repair it yourself.
Let me know if you have any other questions.
Jul 28, 2008 | Hifonics BX1500D Car Audio Amplifier
Car Audio & Video Logo
55 people viewed this question
Top Hifonics Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Jaime Hernandez
Are you a Hifonics Car Audio and Video Expert? Answer questions, earn points and help others
