Question about Motorola Mobility RAZR V3
FILE HAVING PROBLEM WHEN I PRESS THE MENU BUTTON
    Brigadier General:
  • 7,752 Answers
Have the flexcable replaced
Posted on Apr 15, 2008
SOURCE:
Goes to save screen when i press print
1. Press the Print Screen key on your keyboard. It may be labeled [PrtScn].
2. Open an image editing program, such as Microsoft Paint, or any of these free photo editors.
3. Go to the Edit menu and choose Paste.
4. If prompted to enlarge the image, choose Yes.
5. Optional: Use your image editor's crop tool to crop out unnecessary portions of the screen shot.
6. Go to the File Menu and choose Save As.
7. Navigate to the folder where you want to save the image.
8. Type a file name for the image.
9.. Select a file type. See Which Graphics File Format Is Best To Use 10. When? if you are unsure what to choose.
Click the Save button.Still having Problem Then follow Us ForEpson Printer Support
Feb 19, 2014 | Epson Office Equipment & Supplies
Hi ! .I recorded my voice in the MSI 527. How may I play that record ? What button must I set to visualize and ear the archive. Thank you very much Marisa
To play a microphone recording file, press the Menu button once, and then push the Menu button to the right once, and now you should read the message of VOICE appearing on the Display. Press the Menu button again, and then use the Menu button to select a desired microphone recording file by pushing the Menu button to the right or to the left. Once the desired microphone recording file is selected, press the "play/pause" button to start playing the file.
this is all from the manual hope this helps
Jun 26, 2011 | MSI MEGA Stick (256 MB) MP3 Player
I have an olympus ds 4000 and the folders are locked. How do I unlock the folders and what causes this problem? thanks, Sherise
Hello 1 Press the Menu button the menu appears 2 Press FF or Rew button until "lock"in sub menu flases on the Display. 3 Press Menu button the file locking set up process begins. 4 Press the FF or REW button to chose between "ON" and "OFF" ON: Locks the file and prevents from being edit or erased. OFF: unlocks the file and alows to be edit or erase 5 press the Menu button to select the option. Press and hold the MENU button for 1 second or longer to close the Menu.
Nov 24, 2010 | Olympus DS-4000 Digital Voice Recorder
Unexpected size in tray 2
whenever i took printout of a multipage file of Powerpoint. Everytime i have to preses the ok button to proceed with the print. because every page an eror comes displaying on screen of printer "UNEXPECTED SIZE IN TRAY 2" when i press the OK button it start printing the page. everytime i have to press the ok button to take print out. For example if i give a print command to a file that is having 15 pages. i have to press 14 times the ok button to complete the printing of 15 pages. pls help me in this
May 14, 2009 | HP LaserJet 2840 Printer
Help dont want to lose everything
The reason it is asking you if you want to delete all is because you have not selected specific files to erase, so when you hit erase without selecting a file it assumes you mean delete all.
To erase try these steps...
To erase a selected file from Folder A, B, or C:
  1. Press the MENU/FOLDER button to select Folder A, B, or C.
  2. Press the - or + button to select the file to be erased.
  3. Press the ERASE button.
  4. Press the - or + button to select YES.
  5. Press the ENTER/INDEX button.
To erase the contents of Folder A, B, or C:
  2. Press the ERASE button twice.
  3. Press the - or + button to select YES.
  4. Press the ENTER/INDEX button.
To erase a selected file from a date subfolder in Folder S:
  1. Press the MENU/FOLDER button to select Folder S.
  2. Press the - or + button to select the date subfolder.
  3. Press the PLAY button.
  4. Press the - or + button to select the file to be erased.
  5. Press the STOP button.
  6. Press the ERASE button.Press the - or + button to select YES.
  7. Press the ENTER/INDEX button.
To erase the contents of a date subfolder in Folder S:
  2. Press the - or + button to select the date subfolder to be erased.
  3. Press the ERASE button twice.
To erase the contents of a month subfolder in Folder S:
  2. Press the ERASE button three times.
  3. Press the STOP or PLAY button to select the month subfolder to be erased.
  5. Press the - or + button to select YES.
  6. Press the ENTER/INDEX button.
To erase the contents of Folder S:
  2. Press the ERASE button four times.
May 30, 2008 | Olympus VN-480 Digital Voice Recorder
I want to delete some files!
PS. here is a link to download manuals and software for this device:
http://www.olympusamerica.com/cpg_section/cpg_support_product.asp?id=1080
Good Luck ... oh and dont forget to rate my response.
ERROR A90
OK Guys...After fidgitting for hours on this with the bits & pieces on this forum & on others...here's how I got it to finally work:
A- I have a Pentax Opio S hence I had to get the "fwdc110p.bin" file here:
http://www.pentax.de/mediapool/attachments/photo/100/104/46139/fwdc110p.zip
Optio S4, S4i & S5i shall use another file. Don't really know for S4 but for S4i & S5i, there on the Pentax customer service website at:
http://www.pentaximaging.com/customer_care/software_firmware?sfFlag=f
B- Drop this file on your SD Card at the root directory (same level as DCIM folder) or as described by the following link and then close your camera to OFF:
http://www.pentaximaging.com/customer_care/show_firmware?firmId=1020
Attention: Do not load this file yet onto the camera i.e. the menu+power on procedure, follow step C first...
C- Open the now infamous "Secret Menu" in order to re-initialize your camera prior to re-installing the new firm ware:
Simultaneously press MENU + Flash symbol button + Power ON...a white screen with data written in black should show.
Then a sequence of buttons must be pressed: 2 times the focus button (flower, mountain, MF symbols button) followed by 2 toggles to the Right of the "OK" button...then press MENU once and voilà...ze Secret Menu appears !
Using the down toggle of the OK button, go to "SYSTEM INITIAL" and press OK. Press another OK to re-initialize your camera.
Once this has been completed, turn your camera off.
D- Load the firm ware by opening your camera with the MENU+Power ON procedure...finally this should be posting "Complete" after the "Loading" message, instead of the "Error!" that we initially kept on having.
Your camera should be working perfectly ! Only thing, is that you will have to redo your personal settings on it from scratch...but hey, this is much better than to wait for months to get your camera back from Pentax and save that money for your next photogenic trip !
Jan 30, 2008 | Pentax Optio S4i Digital Camera
Curtis mps515 mp3 player
pp.9-10 of the closest model's manual states: (substitute the weird blocky characters for "forward" and "back" buttons)
4.6 Delete single file
From MP3 mode or voice standby mode, you can press the MENU button 2 seconds to enter the main
10
menu, and press the ��or��button to select Delete single file, then you can press the MENU button to enter, you
can press the ��or�� button to select the file you want to delete, and press the MENU button to ensure delete.
and press the play����button to return the current mode. The relative indicatorht will turnoff after you lig r operation.
Delete menu delete ask Delete done
�� Remind: You can not erase the music file which is “read only”
Jan 04, 2008 | Curtis SMP228 MP3 Player
Sony tape recorder- ICD-B310F there is no erase button, how do you erase messages
I have the same recorder (Sony ICD B310F) and in playing around with the buttons, I figured out how to ERASE THEM!!!
Go to the file you want to erase
Hold down the menu button (have to do this the entire time ) until you see the word "MODE"
While holding the menu button, press the forward arrow (like FF) and scroll until you see the word "ERASE"
Still holding down the menu button, press the play button.
Your file number will blink along w/ the word "ERASE", press the play button.
You should notice your file numbers decreased by one file. You have successfully erased the file.
Aug 03, 2007 | Sony ICD-B310F
Freeze Up
http://www.badongo.com/file/707791
Important!!! Insert a fully charged battery or connect to an external power source.
C- Open the now infamous "Secret Menu" in order to re-initialize your camera prior to re-installing the new firm ware: Simultaneously press MENU + Flash symbol button + Power ON...a white screen with data written in black should show.
Then a sequence of buttons must be pressed: 2 times the focus button (flower, mountain, MF symbols button) followed by 2 toggles to the Right of the "OK" button...then press MENU once and voile...the Secret Menu appears!
Using the down toggle of the OK button, go to ROM UPDATE then go down to "SYSTEM INITIAL" and press OK. Press another OK to re-initialize your camera.
Your camera should be working perfectly! Only thing is that you will have to redo your personal settings on it from scratch...but hey, this is much better than to wait for months to get your camera back from Pentax and save that money for your next photogenic trip!
Sep 13, 2005 | Pentax Optio S Digital Camera
Motorola Mobility RAZR V3 Logo
15 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
