Question about Technics SL-1210MK5 Turntable
Frequent sound alright. i have technics 1210s mk5 and every ten or tweny mins during a mix one monitor speaker will cut out with my left turntable, the right turntable is still fine. also my left headphone cuts out or can be heard at a very low sound, but the right one still works fine. i was advised to slightly lick my finger and brush over the four cartridge connectors to leave them slightly wet, i did this and it worked fine again. then thirty mins later it will do it again. i have changed the entire cartridge and stylus and it still happens.now it is starting to happen to my right turntable. and i have also put the turntables on an entirely different sound system and this problem still happens. its been like this for about a month now. frustrating to hell lol. cheers. AaRoN
  • progress_lif Dec 15, 2008
    a friend switched my turntables around so its only the one turntable that's at fault. I have replaced all the equipment to see if the problem is still there (also the whole needles). ta
Its one of the 4 the wires not connected properly inbeetween the needle and the arm. the bass makes it connect and disconnect.
Posted on Jun 13, 2009
  • 515 Answers
You are probably using Ortofon Concorde series cartridges or similar - cartridges that look like the Concorde airplane. These all in one designs, do not connect well to the Technics 1200s series tonearm. So, you'll have connectivity issues during play.
Licking the cartridge is not recommended, as it will eventually rust out your tonearm, and then you will have permanent sound issues, and the only way to correct this is to replace the tonearm.
Ortofon has addressed this issue by issuing the OM series Cartridges, which are the same models as the Concorde series, but mounted to Technics Headshells. Using Technics headshells is your best option, so optimally, you'll want to eventually get this replaced.
If you do not want to get this replaced, then I would suggest investing in some sort of contact spray. Instead of licking your cartridges, spray this inside the tonearm, and you'll be good throughout the night. Since it is an oil based spray, it will not dry out so easily, like saliva. In addition, it cleans, and provides protection on the contacts.
- OPTiC
The Technics Expert
Technics Repair
DJ Equipment
Posted on Dec 30, 2008
  • 68 Answers
Please re-check all your other equipment, as its highly unlikely to be the 2 turntables at fault, let me know how you got on.
Regards.
http://www.audiovisualservices.info/
Posted on Dec 13, 2008
Buzzing from one Technics MK5 1200
More than likely your RCA's need to be replaced. There is no need to open it up, as the ground wire rarely every comes loose. It's held down by a screw & soldered to the circuit board. Unless you pulled on the ground wire.
There are only 3 issues which can cause this:
1) Technics Tonearm - Check the 4 prongs inside the tonearm. Make sure they are all clean (shiny gold), and all protruding the same distance. There are springs behind these prongs, and often times they do come loose over time or overtightening.
2) Technics RCA Cables - This is more than likely the culprit.
3) Cartridge/Headshell - swap out with your good unit. If it works, then your good. Just replace cartridge
With the exception of #3, the other 2 will require assistance from a qualified service technician, otherwise you could cause more damage to your turntables.
- OPTiC
Master Tech, 1200s.com
Technics Parts : Technics Repairs
Jun 16, 2009 | Technics SL-1210MK5 Turntable
After mixing for a while the turntable (1200 technics mk5) starts to lose the pitch or the record starts jerking up near the -5 or -6.
hi! there is a problem inside your turntable (on the main board) check the components  TRANSISTOR    Q2, Q3,  ZENER DIODE   D3..
CHANGE IT IF POSSIBLE..
Jun 14, 2009 | Technics SL-1200MK5 Turntable
Technic 1210 deck
Make sure your 2nd turntable is connected to the PHONO input of your DJ Mixer or Receiver. If you have it connected to LINE IN or AUX IN, the turntable will be very low, as this model requires a phono pre-amp to amplify it's signal.
If this is set up correctly, then you might want to check your cartridge. Can you swap the cartridges out to see if the problem remains on the same turntable, or if it switches to the other turntable. If it switches, then you know the problem is with the cartridges.
If that checks out ok, you might have an issue with the RCA cables or Tonearm or both. At this stage, I would suggest taking it to a service center for assistance.
- OPTiC
Technics DJ Repair Videos
Technics DJ Repair
Technics DJ Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Apr 17, 2009 | Technics SL-1210 Turntable
Pitch problems
You would need to calibrate them to each other. Not very difficult, but not that easy either.
I would suggest taking it to a service center, and ask them to calibrate the turntables to each other. It's a matter of adjusting VR302, which is located underneath the turntable platter. You'll also need a frequency counter or similar - which aren't cheap.
- OPTiC
Technics Repair Videos
Technics DJ Repair
Technics Parts
DJ Parts
DJ Equipment Sales
Mar 15, 2009 | Technics SL-1210M5G Turntable
Technics SL-L3 turntable no sound until warm up
either the cartridge is bad in the phonograph tone arm.  Or the pre-amp in the stereo is bad...remember that the turntable is the only accessory that uses the pre-amp input on the stereo.  I'm betting the pre-amp is bad.
Mar 10, 2009 | Technics SL-1210 Turntable
Techics sl-1210s m3 turntable spins back on itself
You have a fault on the quartz-lock speed control electronics. It may be a simple fix, it may be not.
It will require specialist investigation. A Technics dealer should be able to advise you, and arrange shipping back to Technics for repair if you decide that is the best thing to do.
Jan 15, 2009 | Technics SL-1210M5G Turntable
Pitch problem
check it.
http://www.repairnyc.com/
These guys are authorized technics service.
Jan 05, 2008 | Technics SL-1210 Turntable
Problem with pitch on my technics
You may have to recalibrate the motor. These guys are pros.
Check em out.
Pitch adjustment light is always on
Ok DJ,I use to Dj too,Probley you have moved the equipment quite a Few times,Is the Table Synchronous if so you might have some dust in you control throwing it off,Also Different locations have ac Voltage differences,Ck that too... Other wise go to radio shack and pick up some Contact cleaner Good luck let me Know ttech
Jul 24, 2007 | Technics SL-1200MK2 Turntable
Technics SL-1210MK5 Turntable Logo
95 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
