Question about HP PSC 1410v Printer
My friend is having problems with her printer. The printer keeps printing blanks, how can we fix this?
  • 75 Answers
I would suggest changing out the print cartridges. They may have sat for too long and the nozzles have dried shut. This can happen even with brand new cartridges as well.
Posted on Dec 05, 2008
My laserjet printer 2015 is printing blank, even taste printing and every thing i send for printing, i change the toner cartridge, and also the computer but it still printing blank
Dear friend,
There may be a problem with the Toner cartridgecontact point.Try cleaning the toner cartridge contact points inside the printer.If I won't help then neither a problem with that contact points nor with the logic board,
Mar 10, 2011 | HP LaserJet P2015dn Printer
Printer keeps printing blank pages non stop going
drop kick unit across room:)))) sorry just kidding I had the same problem with mine. If the computer is continually printing that means the printer is receiving print orders from your computer. Best thing is just disconnect the printer from the computer and turn the computer off and wait 30 seconds then turn on . This should clear the print cache then reconnect the printer. Make sure to only request one print at at a time.
if the printer continues to print blank pages check to see if you have the latest software driver for the printer installed on your computer. You can do this by going to the manufactures website and download the software its easy to do just follow the prompts and install! Hope this helpful!!!
Jul 24, 2010 | Epson Stylus C84 InkJet Printer
Canon BJC 80 prints blank pages!!
i think u already solved your problem...your printer's problem is its printer head...u cannot solve this problem by fixing it yourself.all u can do is to buy new printer head at printer's shop. it is true because i got the same problem with my BJC 200.i do the same solution as u r and lastly, i go to the technician and he said i need to replace my printer head at some price.....just think bout money n i discover that buy a new one is better(as for my problem)
not to discourage u, but try to plan either to buy new printer head or buy a new printer....
hope this solution help... ; )
May 26, 2009 | Canon BJC 80 InkJet Printer
Select print and paper is blank - all cartridges have ink
dear friend
the thing that you have changes is ink tank, not the whole unit
this problem is with all the machines which have separate ink tank and head assembly
generally head gets blocked and users keep on changing the ink tanks
friend you have to change head also to get your machine working
thanks
Apr 10, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Printing blank pages
My MF 6530 printer began printing light so we changed the cartridge and the machine began printing blank pages. When the other cartridge was put back in the machine, it too began printing blank pages. We have several of these machines in a couple of offices and have had this problem before. Canon is aware of the issue with this model, but I would like to know it as well. Can you help with what the problem is and the repair instruction? A friend of mine with this machine and the same problem, had called Canon and they had repaired it quite fast in his office. I'd like to do it myself in case it re-occurrs.
Apr 09, 2009 | Canon imageCLASS MF6530 Monochrome Laser...
Epson Stylus C67 keeps printing blank pages
The symptoms infer that the problem is with the computer (printing from an application) rather than the printer (prints OK when the computer is not involved). The best way out of this is to uninstall the printer (start-control panel-uninstall software-epson software). But before you do this double-click the printer icon in the printer list (start-control panel-printers & faxes) and cancel all print jobs in the list (if there are any). Then uninstall the printer Then reboot the computer. Make sure your printer is connected to the computer BUT TURNED OFF. Then insert your printer installation CD and re-install the printer. Turn on the printer when prompted. All should then be well.
Feb 28, 2009 | Epson Stylus C88 InkJet Photo Printer
My hp1020 problem
Friends try to remove the scanner section of the printer and clean it this make solve your problem
May 05, 2008 | HP LaserJet 1020 Printer
HP All-In-One HP C7280 (Ink Jet Color Printer/Scanner/FAX)
on that web page look if u have any thing which says printable version or printer friendly
try with that and check
Mar 07, 2008 | Office Equipment & Supplies
Printer keeps printing blanks...
We have found a reset that we use.
We unplug the printer and then we hold down the feed button and we keep holding down the feed button while we plug back in.
It goes through some sort of a reset and this sometimes works.
Jan 23, 2008 | Dymo LabelWriter 400 Turbo Thermal Printer
I am working on the same problem. While you will not like the
answer here it is for the canon mf6530. What is causing it
is the shutter over the laser is failing to open. There for
it blocks all exposer. A temperary fix is to carefully lift the
shutter and tape it open using black electrical tape. Then
try a few prints you should have an image if this is your
issue as it is mine. I do not recommending running it in
this condition very long. When I find the final answer I
will attempt to post it.
Jan 05, 2008 | HP DeskJet 880c InkJet Printer
Open Questions:
HP PSC 1410v Printer Logo
23 people viewed this question
Ben Johnson
