Question about Saeco Vienna Digital Coffee Maker, Espresso Machine
How do I turn off the "descale now" warning on my Saeco Vienna Deluxe espresso machine?
    President:
  • 1,618 Answers
After performing the descale, use the menu buttons to get to descale and set to reset.
Posted on Apr 06, 2009
On Vienna Deluxe after the beans are ground and ready to drop the espresso shots, nothing comes out and the red light goes on? I shut the unit off for a minute or so, turn it back on and it works ok, but...
Solid red light is a ventilate light.. Try Priming the machine to see if the light goes away.
Something may be in the flow meter. Its the while device between the water tank and the pump of the machine. You would have to open the machine and clean out the flow meter.
Also, if you haven't descaled the machine already, I would start there.
Saeco Espresso Parts Brew Groups Pumps Boilers Water Tanks Drip trays
Mar 07, 2015 | Saeco Vienna De Luxe Espresso Machine
I am looking for a manual to de-calc and clean in Saeco Vienna superautomatica sup 018
Descaling Saeco Automatic espresso machines SAECO VIENNA SUPERAUTOMATIC MACHINES:
SAECO VIENNA DIGITAL - MANUAL DESCALE PROGRAM
1. Fill the water tank with the Saeco descaling solution. (1 bottle of Saeco descaling solution to one full tank of water.)
2. Turn on the machine. Run approximately 1 cup through the steam wand by turning open the hot water steam valve). Turn machine off and let sit for 5 minutes.
4. Repeat this procedure until the water tank is empty. Then rinse water tank thoroughly and flush the machine by running two tanks of clear water through the steam wand.
5. To clear the "Decalcify" message on the Digital model, press the MENU/OK key to go into programming mode. Scroll up or down to select the "Signal.Descal" function. Press MENU/OK. Next, the messages " Quantity Water Not Reached" and "Left Quantity" will flash. Press MENU/OK again - the message "Reset Descaling Program - Yes" will appear. Press MENU/OK again. The Descale meter is now cleared.
SAECO VIENNA DIGITAL - AUTOMATIC DESCALE PROGRAM
1. Press the MENU/OK key to go into programming mode. Scroll up or down to select the "Descaling" function . Press MENU/OK key. Place a large container under the hot water/steam nozzle. Fill the water tank with Saeco descaling solution. (1 bottle of Saeco descaling solution to one full tank of water. Refer to the instructions on the bottle).
2. Then completely open the hot water/steam rotary valve/knob. The pump starts and the descaling program begins. During this phase the pump runs at intervals and the message "Machine is Descaling" is displayed. The complete program takes about 40 minutes. Do not add any water to the tank during this phase. When the message "Descaling Finished" appears, close the hot water/steam valve. The message "Rinse Machine" will appear.
4. Remove and rinse water tank thoroughly, fill with fresh water and replace on machine. Empty the container under the hot water/steam nozzle and replace. Flush the machine by running the tank of clear water through the hot water/steam wand until the message "Rinsing Finished" appears. Exit the Programming mode by pressing "MENU/OK" Refill the water tank with fresh water.
Descaling Single Boiler Home espresso machines (HOME SINGLE BOILER ESPRESSO MACHINES)
Approximately every 3 months (depending on your use and the water hardness), clean the machine with natural citric acid based decalcifying agent.
1. Add a descaling solution into the water reservoir. Mix thoroughly to dissolve (use warm water for better results).
2. Remove the filter holder and place a cup under the group head and another cup, or other container, under the steam wand to catch cleaning solution.
3. Turn espresso machine on, turn coffee pump on and run approximately 8 oz. of solution through the brew head. Turn machine off and let the machine sit for 15 minutes.
4.Run approximately 8 oz. through the steam wand, and again, turn machine off and let sit for 15 minutes.
Repeat by allowing solution to run alternately through the steam wand and brew head. Turn espresso machine off after each cycle. Repeat process until solution has been run through.
5. Do not leave espresso machine on. Do not wait for the ready light to come on. Do not use the steam switch during this process. Do not allow reservoir to run empty!
6. Rinse reservoir thoroughly with fresh water. Refill reservoir with fresh water. Run half a tank of fresh water through group head, alternating between group head and steam wand.
Feb 28, 2011 | Saeco Vienna SuperAutomatica Coffee...
How do I descale my Saeco Vienna Deluxe?
Purchase the Saeco descaler. Mix solution accordingly. Pour into water tank. Run a cappucino cup full of water through the wand. Wait about 20 minute and repeat. Do this until all the water is gone in the tank. (Don't run all the water at once!). Rinse water tank well. FIll with clean water and run through the wand. I do this twice just to be sure I have gotten all the chemical out.
Aug 15, 2009 | Saeco Vienna De Luxe Espresso Machine
How do I get the steam to work?
If it will make coffee then you have a horse shoe boiler blockage or a steam valve blockage.
Try descaling first. If this does not work you will have to disassemble machine and trace the water lines back from the steam wand to the high pressure pump to detrmine where the blockage is. This can be trickey and is best left to someone with experience with this type of fix.
Contact saeco in Vancouver.
Jan 06, 2009 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna Deluxe
ok which red light are you talking about. the water or the beans or the warning
Apr 15, 2008 | Saeco Vienna De Luxe Espresso Machine
Saeco Magic 2nd light to the left (ON RED LIT)
Sound like descaling warning light, need to run descaling solution through the machine (follow instructions, you can download a manual on saeco's website) this light can be turned off by pressing and holding the steam button for 5 seconds.
Jan 21, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco Vienna Digital Coffee Maker, Espresso Machine Logo
159 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
