Question about Indesit W 123 Front Load Washer
Light for door keeps flashing when shut hotpoint aquarius
I,ve just had new door clip but now when i close door it says not closed and light flashes
  • Indesit Master
  • 3,463 Answers
When you say new door clip fitted, I assume you mean door handle, if this is the case then it could be you have not got it back together properly, if you have, then it could faulty door interlock
Posted on Dec 09, 2008
Hotpoint 6kg washing machine Aquarius wash light indicated door lock indicator flashing machine won't fill any ideas thanks Brendan checked filter ok
Many or even most washing machines will not run if the door lock switch is not working. Open and close the door a few times to see if the light stops flashing. You could press on the door where the latch is and see if that makes a difference.
Jun 04, 2015 | Hotpoint Washing Machines
My door is shut and light is on flashing door on my hotpoint washing machine WT741. the door is shut and it does lock aswel so why the flashing light and no washing being done?
There is likely to be a problem with the 'door closed' sensor/microswitch requiring a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
May 07, 2011 | Hotpoint Aquarius WD63 Front Load...
Door lock flashes doesnt work or start up
The flashing door lock light is indicating that the door is not closed proerly.
This can be caused by a weak or broken spring in the door handle.
Another reason for this to happen, is a faulty control board at the top of the washer, a blown track will cause this.
This in turn, is usally caused by a fault on the motor.
Hope this helps.
Jan 20, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Hotoint WMA34 door light keeps flashing and machine wont start
The light flashing usually indicates that the door is not closed securely. this can be caused by a weak or broken door handle spring.
If you are satisfied that the handle is o/k, then the other possibility is that the control module has a blown track, this can be accessed by removing the top cover.
Hope this nhelps.
Jan 15, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
The door lock light keeps flashing and wont wash how do i solve this problem?
check door is closing correct if not the machine will never start if this is ok check main pcb
Jun 08, 2009 | Hotpoint Aquarius WMA52 Front Load Washer
Door locked light flashing when door is closed
push on the door where the lock is... it may not be fully locked.
Feb 22, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Door lock
Switch off. Try some WD40 on the machine lock (not on door) and open & close door many times, to ease out the lock.
Jan 28, 2009 | Hotpoint WMA54 Front Load Washer
Why do the lights just keep flashing?
Try unplugging it and rubbing the plug on a soft dry cloth, static electricity can cause problems.
Try opening and closing door acouple of times, if still no luck , suggest you call engineer
Dec 09, 2008 | Hotpoint Aquarius WD63 Front Load...
Indesit W 123 Front Load Washer Logo
256 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
