Question about Friedrich YL24J35D HEAT COOL 24000 BTU 230 208V BRAND IN STOCK Air Conditioner
Heat pump doesnt turn on when calling for heat
Friedrich twintemp model yl24j35d-a serial ldcr11178
  • 85 Answers
Make sure your power source is still supplying power. Breaker box, maybe you have another too many appliances hooked up to same circuit? If that does not work, get advise from your local distributer before having a small appliance tech charge you for the issue.
Posted on Dec 05, 2008
I have a Friedrich twintemp model YS12J33 thas trips the breaker as soon as you turn it on. You here a popping sounds (arcing) from unit then it trips the breaker.
call the service technician / electrician for a repair /quote
could be damaged insulation from vermin infestation but it is dangerous and needs urgent diagnosis and repair
leave the circuit breaker off if it is on it's own circuit or tape the switch off if it is not
Aug 28, 2016 | Friedrich Heating & Cooling
When AC or Heat is turned on, it trips the breaker
Boyd, from what you have described, it sounds as if the heating element is overheating and rather than the overheating sensor turning it OFF like it should, your home's circuit breaker trips. Which is a good thing. According to the Service Manual for your model : The heating element contains a fuse link and a heater limit switch. The fuse link is in series with the power supply and will open and interrupt the power when the temperature reaches 161.6°F, or a short circuit occurs in the heating element. Once the fuse link separates, a new fuse link must be installed.
Keep in mind, if you have the 115 - 120 volt model, it will not provide heat, if the temperature is below 40 degrees outside.
For your benefit, should you have to call a service technician to service or repair your unit. I have included a link to the Service Manual, that you can download and print for future reference. The service person will greatly appreciate it.
http://www.ajmadison.com/ajmadison/itemdocs/Room_Air_Service_Manual.pdf
I hope all of this will help you to further troubleshoot and solve the problem. Please let me know, Thanks.
May 06, 2011 | Friedrich TwinTemp YS09J10 Air Conditioner
Re: friedrich model # EL25J35-A wall unit It is spewing water from the front and not draining out the hole in the back underside out side of the house. I want to slide the unit out onto it's support...
Dont pull the unit out, you may damage the lines that carry the freon.Your drain may be stopped up. try pumping it out by hooking up a shop vac to the drain from the outside, this should pull through any debris loose that is blocking the water from draining.
May 03, 2011 | Friedrich TwinTemp EL25J35 Air Conditioner
I have a friedrich window unit el25j35. the heat went out last night
Toget proper heat, keep your temp setting at 30+ degree and also mode in "heat"position. If still no heat, check your heating sensor for closed circuit by anOHMs metre.It it's with RV, check power to RV.If it's with heatingelement check power to element. If power is there but still no heat meanselement defective. Replace new heating element. Thanks.
Jan 08, 2011 | Friedrich EL36L35 TwinTemp® 36000 BTU...
Friedrich YM18J34 will not heat
Sounds like a bad limit switch. Open and test continuity on all limits with power off and at least one wire off one side of each
Jun 17, 2017 | Friedrich TwinTemp YM18J34 Air Conditioner
Friedrich wiring diagram
COPY PASTE THIS TO YOUR WEB BROWSER TO LOCATE YOUR MANUAL AND DIAGRAM...:)
http://www.airconditionparts.com/filecabinet/PartsLists/TwinTemp_Parts_Service_Manual.pdf
JUST GO TO THE WEBSITE FOR CLEAR DIAGRAM.
Jan 19, 2008 | Friedrich TwinTemp EL24J35A Air...
Heating & Cooling Logo
171 people viewed this question
Top Friedrich Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Michael Vincent Cruz
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
