I have C4200 All-in-One printer.I install new color cartridge, printed align sheet, put it on glass, hit color button. I'm still stuck; this is second question today. There is small window which says click OK. I push on that window hard. Nothing happens. The printer will not copy;just prints another align sheet. Your first reply says follow instructions. I'm trying but I get nowhere. I need something more than "follow instructions".
  • 75 Answers
Are you sure that there is not an "OK" button and you don't push the actual screen? I am guessing you have to find an "OK" button. I don't think that machine has a touch screen interface. I hope this helps.
Posted on Dec 05, 2008
Ink cartridge doesnt any help
  1. Make sure the HP All-in-One is on. Press the On button to turn on the HP All-in-One. The On button is lit when the HP All-in-One is on.Figure 1: Press the On button to turn the product onc00442142.gif1 - On buttoncaution.pngCAUTION:If the HP All-in-One is off when you open the print-carriage access door to access the print cartridges, the HP All-in-One will not release the cartridges for changing. You might damage the HP All-in-One if the print cartridges are not docked safely on the right side when you try to remove them.
  2. Open the print-carriage access door by pulling it forward. The print carriage moves to the far right side of the HP All-in-One.Figure 2: Open the access doorc00442143.gif
  3. Wait until the print carriage is idle and silent, and then lightly press down on a print cartridge to release it.Figure 3: The print carriagec00316910.gif
    • If you are replacing the tri-color print cartridge, remove the print cartridge from the slot on the left.
    • If you are replacing the black or photo print cartridge, remove the print cartridge from the slot on the right.
    Figure 4: The print cartridges in the proper positionc00442144.gif1 - Print cartridge slot for the tri-color print cartridge2 - Print cartridge slot for the black and photo print cartridges
  4. Pull the print cartridge toward you out of its slot.
Step two: Install the new print cartridgeBack to top
  1. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab.Figure 5: Remove the tapec00442146.gif1 - Copper-colored contacts2 - Plastic tape with pink pull tab (must be removed before installing)3 - Ink nozzles under tapecaution.pngCAUTION:Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.c00442147.gif
  2. Slide the new print cartridge forward into the empty slot. Then gently push on the upper part of the print cartridge forward until it clicks into the socket.
    • If you are installing the tri-color print cartridge, slide it into the left slot.
    • If you are installing a black or photo print cartridge, slide it into the right slot.
    Figure 6: Insert the print cartridgec00442148.gif
  3. Close the print-carriage access door.Figure 7: Close the access doorc00442149.gif
Step three: Align the print cartridgesThe HP All-in-One prompts you to align cartridges every time you install or replace a print cartridge. Use the following steps to align the print cartridges from the control panel.
  1. Make sure you have letter or A4 unused plain white paper loaded in the input tray, and then press OK .
  2. The HP All-in-One prints a print cartridge alignment sheet.note.pngNOTE:If you have colored paper loaded in the input tray when you align the print cartridges, the alignment will fail. Load unused plain white paper into the input tray, and then try the alignment again.
  3. Lift the lid. Place the top of the alignment page face down in the left front corner of the scanner glass. Close the lid.Figure 8: Load the alignment sheet on the glassc00443602.gif
  4. Press OK to begin the alignment.
  5. The HP All-in-One aligns the print cartridges. Recycle or discard the print cartridge alignment sheet.
Oct 28, 2011 | HP Officejet 5610 All-In-One InkJet...
Installed new black ink cartridge in HP PSC 2110 color printer, scanner, copier. Followed instructions to align cartridges. Printer printed paper that had additional instructions. Placed second printed...
hello, machine will need to finish calibration so it will not come back, so if machine failes it could be that the color cartridge is not printing, because this machine uses yellow to calibrate with.
Oct 06, 2010 | HP PSC 2110 Color Printer
Installed a new HP black ink cartridge; the officejet 8500 pro will not print any black print. The color ink works okay.
First print a self test page on the printer and check if you have black print on it or not.
To do that Go to your printer :-
Press Setup button -->Go to print report-->hit ok--> use arrow keys and choose the self test page.--> hit ok.
If you have the self test page fine then try to make a black copy from the printer.
Put a black font printout on the scanner glass facing downwards. Press copy black
Check if you have the black ink working.
If yess then there is some thing on the system you are doing wrong. May be the printer properties needs to be set or some settings needs to be checked.
If no then try to clean he ink cartridge and try to align the cartridge on the printer.
To align Do this
Press setup-->use arror keys to navigate to tools -->and choose the option align cartridge or align printer.
If you do not find the option in the tools option try looking for it in the print report...
On the computer Go to printer under control panel and right click on the printer and go to print prefernces --> go to the TAB called colors and under color options -->choose print in greyscale--> and under that choose the Black only option. --> hit apply and then hit ok.
Now try printing..!
Let me know if any of these steps works....
May 12, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Alienment sheet prints every time I print a page.
just put the printed alignment test page paper on scanner glass and press the scan button to complete the process. It is alignment process which is printer is doing for self testing after installing new cartridge. Just finish the process.
. It is necessary to after aligning the page it need to scan with the scanner. Otherwise it keeps pop up.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Have a nice day and do not forget to rate please...!
Mar 15, 2010 | HP PSC 1315 All-in-One Printer...
Hp2210 message ''press enter to align cartridges'',
from user manual::
To align newly installed print cartridges
1. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
NOTE: If you have colored paper loaded in the input tray when you align the print cartridges, the alignment will fail. Load unused plain white paper into the input tray, and then try the alignment again.
If the alignment fails again, you might have a defective sensor or print cartridge.
Contact HP Support. Go to www.hp.com/support. ....
2. Load the print cartridge alignment sheet print side down on the left front corner of the glass with the top of the page to the left.
3. Press the Scan button.
Score the solution and download the manual if you need it
Mar 24, 2009 | HP PSC 2210 All-In-One InkJet Printer
When I change the black ink cartridge, the alignment page and instruction page are printing out fine. When I place the alignment page on the glass as instructed and press 'ENTER', the printer gives a...
I just had the same issue (align page not detected).
We had just re-installed the empty color cartridge back into the printer (long story but basically we knew we could only print B/W).
The align page printout had a lot of empty spaces around the black lines. This is apparently where the color lines are supposed to print.
Without those color lines, the printer would not detect the align page as color is part of the alignment being done.
Since we only wanted black printouts, I pressed 'cancel' to stop the alignment process, and now we just hit the Black copy button and ignore the alignment prompt on the printer window.
The HP site (enter psc750 in product window) has some helpful ideas as to what the problem might also be. It could be the shipping tape is still on the new cartridge (and preventing the black or color from printing on the align sheets) etc.
Mar 20, 2009 | HP PSC 750 All-In-One InkJet Printer
Test page printing at the time of printer powered on
s.gif Solution minimtop.gif The product aligns the print cartridges every time that print cartridges are installed or replaced to ensure the highest-quality prints. The alignment page will continue to print every time that the product is turned on or off until the alignment process is completed. NOTE: If you remove and install the same print cartridge, the unit will NOT align the print cartridges. The unit remembers the alignment values for that print cartridge, so you do not need to realign the print cartridges. Follow the steps below, in the order presented, to correctly complete a print cartridge alignment. s.gif Step one: Remove the print cartridges minimtop.gif
  1. If the On/Resume button is not lit, press the On/Resume button to turn the product on. Figure 1: Press the On/Resume button to turn the product on c00316907.gif
  2. Make sure the paper tray is down and there is letter or A4 unused plain white paper loaded in the paper tray.
  3. Lower the access door until it stops. Figure 2: Lower the access door c00316908.gif Make sure the print carriage moves to the center. Figure 3: Print carriage in the center of the printer c00316909.gif
  4. Wait until the print carriage is idle and silent, and then, using your thumb, lightly press down on a print cartridge to release it. Figure 4: The print carriage c00316910.gif
    • If replacing the tri-color print cartridge, remove the print cartridge from the slot on the left.
    • If replacing the black print cartridge, remove the print cartridge from the slot on the right.
    Figure 5: The print cartridges in the proper position c00316912.gif 1 - Tri-color print cartridge 2 - Black print cartridge
  5. Pull the print cartridge toward you out of its slot.
s.gif Step two: Install the new print cartridge minimtop.gif
  1. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab. Figure 6: Remove the tape c00312625.gif 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.c00312564.gif
  2. Slide the new print cartridge forward at a slight upward angle into the empty slot. Using your index finger, push the print cartridge forward until it clicks into place. Figure 7: Insert the print cartridge c00316911.gif
  3. Close the access door.
s.gif Step three: Align the print cartridges minimtop.gif If you are installing a new print cartridge, the product begins to print a print cartridge alignment sheet. This may take a few minutes.
  1. Lift the lid of the product.
  2. Place the top of alignment page face down in the left front corner of the glass. Figure 8: Place the alignment page face down c00316913.gif
  3. Close the lid.
  4. Press the Scan button.
  5. The On/Resume light will blink during the alignment process.
  6. After the On/Resume light stops blinking, alignment is complete.
Feb 26, 2009 | HP PSC 1410 All-In-One InkJet Printer
I have C4200 All-in-One printer. I installed a new color catridge. I printed align sheet, put it on glass, clicked color button. But when I try to make a copy, all I get is another alignment sheet.
The alignment procedure is usually required after replacing an ink cartridge and you haven't yet completed or paid attention to the instructions it provides to fully complete it. Once completed it will return to normal operation.
Dec 05, 2008 | HP Office Equipment & Supplies
Have just unpacked new HP Photosmart C4200 All-in-One Cannot get machine to accept cartidges which werre supplied with the printer
NOTE: The product must be on before you can insert the print cartridges.
  1. Open the print cartridge door. Figure 7: Opening the print cartridge door c00880893.jpg
  2. Make sure the print carriage moves to the right. If it does not move to the right, turn the device off, then turn it back on again.
  3. Open the packaging and remove the tape from both cartridges. Figure 8: Removing the tape c00880894.jpg CAUTION: Do not touch the copper-colored contacts or re-tape the cartridges.
  4. Hold the cartridges with the HP logo on top.
  5. Insert tri-color cartridge in the left cartridge slot and the black cartridge in the right cartridge slot . Figure 9: Inserting the print cartridges c00880895.jpgc00880896.jpg
  6. Push the cartridge firmly into the slot until it snaps into place.
  7. Close the print cartridge door.
Step eight: Align the print cartridges When a new print cartridge is installed, the product aligns the cartridge. Align the print cartridges at any other time by using the software installed with the product. Aligning the print cartridges ensures high-quality output. NOTE: If a print cartridge is removed and reinserted, the product will not prompt for an alignment. The product memory retains the alignment values for that print cartridge. Follow these steps to align newly installed print cartridges.
  1. When prompted, make sure that plain, white letter or A4 paper is loaded in the input tray, and then press the button next to OK . The alignment page prints.
  2. Lift the lid. Place the top of the alignment page face-down on the front, right corner of the scanner glass. Figure 10: Placing the alignment page c00880898.jpg
  3. Close the lid.
  4. Press the button next to OK . When the On button stops flashing, the alignment is complete and the page can be removed.
Nov 18, 2008 | HP Computers & Internet
Hp 2110 All in One Printer
Does the machine ask you to "align" the print cartridges when you turn the machine back on? If the alignment page when finished printing is missing a key color (say yellow), then the alignment will not succeed.
Jul 29, 2007 | HP PSC 2110 All-In-One InkJet Printer
53 people viewed this question
jasbo
jasbo
