Question about RCA R52WH73 Projection Television
I am working on an RCA HDTV Model # R52WH73. The RGB channels are not aligned properly on the screen and there is no option in the menu for correcting the alignment. I have electronics repair experience, but have never worked on this type of television before. How can I correct the alignment of the channels inside the unit?
  • 106 Answers
There are bad connections on the flyback transformer and, in addition, right beside the flyback you will see three little square fuses. The one in the middle will be open. Replace it and solder the flyback, All will be okay
Posted on Dec 05, 2008
I have an rca tv that im trying to hook up to a dvd player and I can't get a signal or channel to work. I don't have a remote but the menu button works. what channel should it be on to play dvds
depend on tv input; if it's only one rca input mean is composite video; if are 3 rca input mean rgb video. so from dvd you need a scart to composite or rgb. on tv usually is AV or AUX channell. try to find a universal remote to select properly the channel. bye
May 23, 2014 | Televison & Video
Black screen for HDTV channels -- but TV menu and DVDs display normally
Try hard reset, Please unplug the tv cables and power cables for 30 min and redo the cable and check its working ....
Good luck...
Aug 01, 2008 | Hitachi 42HDS69 42 in. Plasma Television
I have a r52wh74 rca hdtv flatscreen the tv menue keep on poping up fast on the screen and the volume goes up and down
Thats a common issue with that chassis ITC222A which is always caused by the small signal board needing replacement. You should be able to get the small signal board from www.tvrepairworld.com
Feb 27, 2013 | RCA R52WH73 Projection Television
Rgb will not align
Go to Menu then to setup do you see convergence Listed ,if you do not then you have a Blowed Fused
FL231 it will be Located on Deflection board on right hand side of FBT flyback Transfomer there is 3 in a roll they are small looking brown rectrangler caps it will be the one in the Middle, These are Fuses.06 volt
Partstore.com has them. Let me know if you need more help.
Mar 23, 2010 | RCA D52W23 52" HDTV CRT TV
Help I need a replacement screen
You can find a new OEM RCA replacement lenticular screen and Fresnal screen (availble together as the screen assembly) for a model # R52WH73 from a major RCA distributor at the following links:
RCA R52WH73 Replacement Part Screen Assembly (Fresnal Screen w/ Lenticular Screen)
And here's a link for the protection screen if needed:
RCA R52WH73 Replacement Part Protection Screen / Super Shield
Apr 10, 2009 | RCA HD52W59 HDTV Projection Television
HDTV question for this model
You should have on the rear jack panel the RGB input which is the 3 rca jacks and red & white for audio. That is how you recieve HD on that model.
Mar 25, 2009 | Zenith D61W25 61" Rear Projection...
Bow tie looking picture with 3d color mis-alignment
you have lost convergence. First thing to check is to see if you are missing the convergence option in the customer setup menu. if you do not have this option then i suggest reading the article in the tips and tricks section entiltled "the fl231 fuse problem" this is a common and sometime easy repair if you do have it then you might need a convergence power board
Mar 09, 2009 | RCA R52WH73 Projection Television
Menu pops up continually
Replace contact switches on Front panel board on/off vol- vol+ ch- ch+ Menu First try cleaning them with contact cleaner if that does not work /replace them.
Jan 06, 2009 | RCA R52WH73 Projection Television
RCA R52WH73 Projection Television Logo
75 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
