Question about Mitsubishi WS-65908 TV
I have a mitsubishi ws 65807, i get trouble code 23
The code reads Horizontal deflection error, how do I fix this problem? is a capacitor or what?
  • 116 Answers
The problem is most likely convergence integrated circuit failure. I recommend finding a local Mitsubishi repair center.
Posted on Apr 16, 2009
Error code 18 on Mitsubishi WS-55311
This is a V20 chassis, circa 2002
Available error codes for this unit are as follows:
12.....No error has occurred
21.....X-Ray protect circuit
22.....Short protect circuit
23.....Horizontal deflection failure
24.....Vertical deflection failure
Jan 07, 2015 | Mitsubishi Televison & Video
I have a Mitsubishi ws-65809, the tv won't power
I presume you unplugged the set and redid the check:
2,3 is deflection circuit problem (probably in Horizontal sweep circuit) and can be almost anything---check output transistors and look for cracked or bad cap in that area.
The error code is only a general indication of the kind of problem and this one is like saying car will not start etc.
Mar 18, 2012 | Mitsubishi Televison & Video
Mitsubishi WT42413 error code 23. It turns on for bout 4-5 min and shuts down! Not sure what to replace?
Error 23 means a fault in the horizontal deflection circuit. Its part of the HV circuit that drives the CRT. Possible reason for shut down is an overload thats causing a protection fault. Note that this is a rather risky repair for someone without prior experience. So if that is the case you might wanna seek the assistance of a qualified tv repair tech.
Aug 26, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Tv wont trun on
That's error code 23. The manual says that is loss of horizontal deflection. Maybe shorted-out Hor. Out. transistor, but it should be looked at by a shop if you're not a technician. probably at least $200, may be $400 for them to fix.
Apr 21, 2010 | Mitsubishi WS-65611 65" Rear Projection...
Mitsubishi WS 65807 issue- Pressing power button turns unit on for about 5 seconds and then the power shuts off. Unplugged for about 30 seconds and disconnected it from all other equipment, reconnected...
The model you have selected should have a self check feature: when turns off and the green power light goes off:
ON THE FRONT OF THE SET PRESS AND HOLD BOTH MENU AND INPUT(some sets the input is called device) together for at least 5 seconds and then release both buttons.
The power light should blink a two digit error code: for example: 2 blinks, a pause and 2 blinks--it will repeat the code about 10 times.
error codes for this set:
1, then 2 no error detected
2, then 1 X-ray protection
2, then 2 short protection
2, then 3 deflection circuit problem
2, then 4 vertical deflection problem
2, then 2 is the most common and easiest to fix.
Let me know what you find and if 2,2 I have detailed instructions for repairing that kind of trouble.
I am here to help people.
SD TECH
Oct 31, 2009 | Mitsubishi WS-65807 65" Rear Projection...
Ws-6580 error code 23
CODE / INDICATES
12 / No error has occured
21 / X-Ray Protect Shutdown
22 / Short Protect Shutdown
23 / Horizontal Deflection failure
24 / Vertical Deflection failure
Aug 06, 2009 | Mitsubishi WS-65809 65" Rear Projection...
I have a mitsubishi ws-55809 power comes on and then goes off
try to check it again as these are the only codes for your model.
3. Error Codes
The Error Code designations indicating a malfunction, or no malfunction, are listed below:
“12” ... indicates no error has occurred.
“21” ... X-Ray Protect circuit.
“22” ... Short Protect circuit.
“23” ... Horizontal Deflection failure.
“24” ... Vertical Deflection failure.
Mar 14, 2009 | Televison & Video
Please help me, i have Error code 23 on Mitsubishi WS-55511
A 23 error is loss of horizontal deflection First thing to check is the solder joints around the Flyback and around the two transformers T5A31 and T5A32. If you resolder those three items then pull the Q5A31 HOT ( Horizontal output transistor ) from circuit. If you send me a email to slinteriors@yahoo.com I will walk you through how to test the various components in the Horizontal deflection circuit and help you get your set up and running again.
Jun 24, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi VS-50705 TV has error code 23, Horizontal Deflection failure...tv won't turn on.
Unfortunately, problems in the deflection circuit can involve expensive parts. This type of repair is not for the do it yourselfers. It requires proper test equipment and diagnostic experience. Look to spend at least $350 and up. Maybe Santa will bring you a new plasma for Christmas. Good luck
Dec 12, 2007 | Mitsubishi WS-48613 48" Rear Projection...
Mitsubishi WS-65908 TV Logo
229 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
