How to fit wall bracket to tv
When bought tv we had it in stand and now would like to put on the wall but have no instuctions on how to fit to the bracket
  • Anonymous Dec 12, 2008
    hi i have the same problem and would like to tell you its ok now
  • 58 Answers
The bracket should have instructions. the set will have screw holes on the back to bolt to the bracket.
more detailed info needs to come from the bracket MFG
Posted on Dec 05, 2008
I need help finding mounting screws and bolts for my 47" 1080P 120HZ LCD w/2YR. The table that I bought for the tv dindn't bring them.
If you want to put the LCD on a stand you"ll need the original that screws on the bottom. best way to mount LCD is to the wall or on a metal stand. There are holes on the back of the LCD to mount the bracket most brackets have a lot of holes just move the bracket up or down until two line up. The screws are almost all metric coarse thread and usually are included with the bracket kit. I got my kit at Wal Mart
Apr 18, 2011 | Televison & Video
I had the TV upside down for about 5 minutes to take the stand off of it. I put brackets on to mount on my wall. I put the TV on the wall then plugged the TV in. There was a sound and then a puff of...
Whoops, did you not use the right length screws.
The mounting bracket screws will short onto some electronics if you fit screws that are too long and from your superb description, it sounds like you did everything right but do not mention what screws you used.
Smoke coming from a TV is always a sign that something has burned out and unfortunately it is never a fuse. The TV will need fixing, there is no chance of it still working after it has smoked.
If you are lucky, it will just require a power board but you need a TV engineer to look at it as it is not something that you can usually do yourself. Even if you bought a new power board and installed it, there is no guarantee that the main board/processor board or inverter has not blown as well and this is why I recommend a professional looks at it.
Unless your house insurance covers the damage (if the excess is not too high).
Feb 06, 2011 | Panasonic Viera TX-32LX70 32 in. LCD TV
42LH3000 LG LCD TV
SOME TV'S HAVE A PANEL TO ACCESS THE A/V CABLES...I.E. HDMI,S-VIDEO,COMPONENT,ECT. IF YOURS IS THE CASE LOOK WHEN YOU REMOVE THE PANEL AND SEE IF THERE ARE ANY COVERS THAT NEED TO BE REMOVED SO YOUR STAND CAN SLIDE INTO PLACE.
Feb 20, 2010 | Televison & Video
How do i mount it on a wall bracket ... like what screws do i take out the back of the tv to attach it to the bracket
first buy the right bracket for weight of tv there is 4 big black screws near center of tv ( IF FITTED )take them out place bracket over 4 screw holes then use the 4 screws you took out make sure they are tight ( DONT FORGET TO TAKE STAND OFF )
Oct 12, 2009 | LG 37LG30 37 in. LCD HDTV
Try to mount TV to the wall and need to release the TV stand
To Display your LCD TV using a Wall Bracket:
If you decide to wall mount your LCD TV, always use a ULlisted wall bracket appropriate for the size and weight of the LCD TV: 32HL37/32HL37U/32HL17/32HL17U: 38.6 lbs (17.5 kg)
37HL17: 46.3 lbs (21.0 kg)
42HL17: 59.5 lbs (27.0 kg)
1) CAUTION: Two people are required for installation.
2) Unplug and remove any cables and/or other component connectors from the rear of the TV.
3) Follow the instructions provided with your wall bracket. Before proceeding, make sure the appropriate bracket(s) are attached to the wall and the back of the TV as described in the instructions provided with the wall bracket.
4) After attaching the appropriate bracket(s) to the wall and the back of the TV, remove the pedestal stand from the TV as described below.
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface. Note: Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can be removed without tools.
3) Remove the five screws. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand away from the TV.
Sep 28, 2009 | Toshiba REGZA 32WLG66 32 in. Television
Sony Bravia 40" LCD TV Stand
There is a slotted area on the bottom of the unit and the bracket on the stand slides over top of it. There should have been four screws that came with the packaging that fit in the four locations in the lower center of the cabinet back that secures the unit to the Stand.
I hope this helps,
Skyassoc
Aug 25, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
I want to wall mount my 26LB30QD but the stand needs to come off, there is nothing in the instuctions on how to remove the stand, please advise.
With the tv laying flat on to the screen, remove the two screws in the recessed holes. Then remove the two screws above towards the input panel, one under AUDIO-L/AUDIO-R and the one under HDMI-1. The stand should easily slide out.
Mar 06, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
I am trying to remove the stand on a LG Model : 52LB5D. I have removed the 4 screws on the back but can't remove stand. It feels like there is another screw or something holding it in.
If you are looking at the back of your tv there is the stand bracket with a screw on each side. remove those screws and nothing will happen. that is the problem i was having but if you look right above the ones you just took out and there is going to be a black screw. take those off from each side and it will fall off.
Dec 09, 2008 | Televison & Video
Non wall mountable samsung tv
Take the feet off. See the manual.
May 24, 2008 | Televison & Video
Stand
How do I remove the stand?
Apr 13, 2008 | Toshiba Televison & Video
Televison & Video Logo
691 people viewed this question
Top Televison & Video Experts
