Question about Home
Faucet is dripping
Trying to take a delta t17430 apart need to know how to get the stem out
  • Anonymous Mar 18, 2014
    Moen 7594E faucet installed but it keeps dripping
  • 33 Answers
Here is the technical breakdown of your unit:
Delta T17430
Here is the repair and maintenance catalog:
Delta 17430 maintenance catalog
I believe the information you need here is on page 16 and 17.
Hope this helps!
Posted on Dec 06, 2008
Delta 2555-216 Victorian Double-Handle Centerset Lavatory Faucet with Metal I have a slow drip in bathroom sink and do not know how to remove the stem to get at the washer in the Victorian listed above.
If you notice right below the handle,there should be a small opening where ,by using an allen wrench you should be able to remove handle giving access to the stem retaining nut ......CAUTION... be sure cutoff valve is turned off(both hot and cold cutoffs.... under lavatory sink before removing..........unscrew retaining nut and remove stem.....hope that helps......
Sep 01, 2011 | Delta 2555-216 Victorian Double-Handle...
I have had my Delta bathroom faucet about four years. The hot water side drips. Can not get it to stop. It is one faucet with hot and cold handles with all sitting on a small platforum. The platforum is...
Go to delta website, take a picture of faucet with your cell phone and send. They should be able to identify and send you the parts. Meanwhile you'll have to turn water on and off from the emergency shut off valve under the sink. If it looks like the picture, it's probably the rubber seat and spring. If you don't want to wait go to your local "hardware" store. There may be someone there to help you. Bring the stem or cartridge, along with the rubber seat and spring. Don't use cold water while stem is removed. Turn cold off as well to prevent a mishap.
Apr 23, 2011 | Delta Faucet Bathroom Faucet - Delta 2...
I have a Delta Tub/Spout Pull Down Diverter that has a pretty persistent drip. The HOT and COLD handles are turned off and seem to be as tight as they can be. After doing some research online I believe...
If your Delta RP17453 Pull-Down Diverter Tub Spout stops dripping after 5 minutes, your ok. If it never stops dripping, you need to replace delta faucet cartridge(s) behind the handle(s). This is were the water turns on and off and stops the water flow to the tub spout.
Delta faucets are some of the easiest to repair, and parts are usually available at any hardware store or home center. If you have a two handle faucet, replace both delta seats and springs and stems. If you have a single handle Delta faucet, replace the entire cartridge.
Jan 26, 2011 | Delta Faucet Delta RP17453 Pull-Down...
The roman tub faucet keeps dripping. I push down on the stems and it stops?
the retaining nut,located under handle may not be screwed down all the way.this happened to me on similar / same faucet's.so try this and see,nice and easy
Dec 30, 2009 | Delta Faucet Delta T2710-LHP Classic Roman...
I have a model 3555 delta victorian faucet that has a drip, do I need to replace the stem unit assembly
First isolate which side (hot or cold) that the leak is coming from by turning off one or the other valved under the sink. once you know if its the hot or cold faucet, then shut off all water supply to the sink and remove that faucet handle with a very small allen wrench ( there should be a set screw in the side of the handle) inside of the valve (handle) there will be little rubber seals like o-rings that are worn out and need replacing. you can purchase them at home depot or a hardware store
Nov 21, 2009 | Delta Victorian 2155-SSLHP Bar Two Handle...
Replace the seal on the 470 DST single handle pull out faucet
Turn the water off at the faucet, remove the handle and the retaining nut that is apart of the trim. You will see where you can use a wrench to remove it. The ball assembly will come right out and you can replace the washers right below it. Put it back together and if needed, tighten the tension ring that is on the retaining nut (usually grey or white in color) so it won't leak water around the ball stem. Good luck.
Apr 02, 2009 | Delta Faucet Delta 470-BL-DST Signature...
Delta Faucet Kitchen Single Pull
Yes, It can be fixed but it isn't a washer. There is a replacement stem for the faucet . They are readily available at most big box stores and possibly the local hardware store. Bring your faucet model number with you.
Phil
Oct 17, 2008 | Delta 2402 Classic Single Handle Kitchen...
Home Logo
218 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
