Question about Linksys WRE54G 802.11G Wireless-G Range Expander (Retail) (NTUSLSWRE54G) Repeater
Linksys wireless-g range expander isn't working
Only one blue light, and weak signal, tough there is some signal, it is in and out and very weak. everything is just as it has always been, and i have always had a strong signal.
  • Anonymous Feb 23, 2009
    i have the same problem.... i always had signal now u can barely tell its on and it was working perfectly the night before
  • 48 Answers
SOURCE: wireless G ranges expander
when using the range extender you have to make sure you set the SSID, channel & wireless key in the range extender the exact same as the router also it has to be in the same IP range so if the router IP address is 192.168.0.1 the range extender IP address has to change from 192.168.1.240 to 192.168.0.240. once that is done restart the range extender and disconnect the ethernet cable & it the 2 lights should light up blue.
Posted on Feb 10, 2008
  • 48 Answers
SOURCE: Having Problem Acquiring IP Address
when using the range extender you have to make sure you set the SSID, channel & wireless key in the range extender the exact same as the router also it has to be in the same IP range so if the router IP address is 192.168.0.1 the range extender IP address has to change from 192.168.1.240 to 19.168.0.240. Hope that helps.
rahul26485
  • 611 Answers
SOURCE: range expander
back side reset button is there pull out the power cable and put in on that time u have press the reset button on same time. eithere you go the page of linksys configuration there one opiton is there reset or the default settings.
Posted on Jun 03, 2008
AvioriX
  • 689 Answers
SOURCE: setting up wireless range expander
Hi
You can get the online manual which contains all the steps to set it up. go to link below for the manual.
http://www.linksys.com/servlet/Satellite?c=L_Product_C2&childpagename=US%2FLayout&cid=1130267578138&pagename=Linksys%2FCommon%2FVisitorWrapper
Good Luck
Posted on Nov 10, 2008
marked
  • 6487 Answers
SOURCE: Linksys WRE54G WIRELESS 802.11G RANGE EXPANDER Range
The actual max distance of the range expander is about 50 feet, and sorry to say but it cannot bounce the wireless signal from it on a wall....
Posted on Jan 25, 2009
I bought a wireless Linksys wireles- G router used for 5.00. They said that it had a weak signal. I hooked it up and sure enough I have a weak signal. So weak that it does not connect to anything but there...
I made mine into a range expander with this information
http://lifehacker.com/#!5563196/turn-your-old-router-into-a-range+boosting-wi+fi-repeater
If you up to the challenge and can follow instructions, takes about 30 min to do.
When you put on the new OS for the router you can up your signal too.
Mar 28, 2011 | Linksys Wireless-G Broadband Router
Link Light red activity light blue. Tried to reset and use the auto configuration button but nothing is working.
Hello, It sounds like the repeater is not within range of the wireless router or access point. The repeater does not act as a wireless router by itself, but rather like extra antenna/signal booster, so you still need to have a wireless router within range. The router must also be using a router that is 802.11B/G compatible, or else the repeater might not be able to receive that frequency signal in order to boost it (should work with N also, but not quite sure if it has to be set to Standard Channel due to how N works. We are working on wireless frequencies in my course now, so I can contact my instructor, and get back to on that). If you have any questions, feel free to contact me, or simply reply.
Feb 12, 2011 | Linksys Wireless-G Range Expander (WRE54G)
Cant find a strong enough connection
You need to buy a Linksys Wireless-G Range Expander to boost the signal
  • Move your wireless router to a central location in your network, keeping in mind that the router should be at waist level at the very least, not on the ground.
  • Plug in the Linksys Wireless-G Range Expander in the room where your wireless router is. You'll move the range expander later, but for setup purposes, it should be in the same location as your wireless router.
  • Press the Linksys Wireless-G Range Expander's "Auto Configuration" button for five seconds, which will allow the range expander to detect your wireless network and configure itself with the appropriate settings.
  • Unplug the Linksys Wireless-G Range Expander and relocate it to a location closer to the Xbox 360.
  • Ensure that the antenna for the Linksys Wireless-G Range Expander is pointing upward, and keep in mind that the higher the range expander is placed, the better performance you will get out of it.
  • Plug the Linksys Wireless-G Range Expander back in, and your wireless network should have a much greater range, ensuring that your Xbox 360 is able to maintain a good connection to the network.
  • Dec 29, 2010 | Microsoft Wireless Network Adapter Xbox...
    I have wireless-G WRT54G2 V1...the signal coverage is weak. If it is more than about 5 m then the signal is lost. Any clue how to fix
    the easiest solution is to buy a wireless expander.
    http://www.linksysbycisco.com/US/en/products/WRE54G
    this will expand the range of your current router.
    however before buying check the following:
    your router is not near wireless land telephones, near a tv, or near any other obstacles that could block the signal.
    try to put your router somewhere high.
    Jan 24, 2010 | Linksys Wireless-G WRT54G Router
    How do use and install the linksys wireless range expander
    just plug it in and press the configure button on the side of it, and wait for both lights to turn solid blue, the eithernet port in the front is for connecting a router, or laptop, youknow something that takes an eithernet connection
    Dec 28, 2009 | Linksys Wireless-G Range Expander (WRE54G)
    Link light on (blue), activity light off (neither blue nor red)
    Press the RESET button on the back of the unit and reconfigure the settings.
    Sep 11, 2009 | Linksys Wireless-G Range Expander (WRE54G)
    Linksys wireless b router
    Weak signal problem can be fixed by firmware update however, if the client computer is too far from the router, it can't be helped. What you need is a wireless range expander. What it does is give you another 100% signal or atleast stronger signal to the spot or area where you have a weak or dead signal.
    Jun 29, 2009 | Linksys Wireless-G Broadband Router
    Jan 25, 2009 | Linksys Wireless-G Range Expander (WRE54G)
    Wireless G ranges expander
    Jan 20, 2008 | Linksys Wireless-G Range Expander (WRE54G)
    No Power
    Before you plug it in the wall, insert the installation disc and go through their tutorial. When you do that you'll plug in your range expander, press the auto configuration button on the side and wait for both lights to turn up blue. Then you can unplug the range expander and put it else where.
    Aug 08, 2007 | Linksys Wireless-G Range Expander (WRE54G)
    Computers & Internet Logo
    55 people viewed this question
    Top Linksys Computers & Internet Experts
    Prashant M
    Prashant M
    Michael Galve
    Michael Galve
    Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
