Question about Canon PIXMA MP780 All-In-One InkJet Printer
Print quality stuck on fine
Cannot figure out way to change print quality from fine (slow, gobbles ink) to normal. Downloaded manual, no help.
Please help.
  • 1 more comment
  • lerch731 Jan 19, 2009
    Change print quality from fine to normal
  • jt9476 Jan 25, 2009
    I have the same problem of not being able to change the image quality from fine (photo) to normal or fast from the printer itself, not the computer. The user guide says to use the "-" or "+" arrows on the printer to change the image quality settings but nothing happens when I use those buttons. Even though I'm using "draft" setting from my computer printer preferences it still prints at "fine" quality from the printer.
  • Anonymous Mar 02, 2009
    print quality stuck on "fine".  It was on normal yesterday, but today it's on fine and I can't get it to change.
  • 75 Answers
Did you check in the software? There should be a print quality option in your driver software.
Posted on Dec 05, 2008
Why did my printing rate suddenly slow down to about 20 Why did my printing rate suddenly drop to about 20 % of normal
Check the print quality settings in the Printer Control Panel. If set to best and color it will slow printing considerably and use ink much quicker. Draft and B&W printing is usually fastest and sips ink compared to other modes.
Feb 20, 2015 | HP Envy 4500 e-All-In-One Printer, Copier,...
Slow printing
Check that the default setting for print quality on your printer driver hasn't been set to "Fine".
In your Opertaing System, find your printer (in XP it's under Control Panel / Printers and Faxes) and select Properties. This should then bring up the settings for the driver.
Fine printing quality takes over double the time "Normal" quality takes so would considerably slow your printing.
Apr 10, 2014 | Brother MFC 210C All-In-One InkJet Printer
Canon pixma pro9000 -2 i have done all the print head cleaning and deep cleanig and the test shows no cloggs -- when i print specifying low quality ( fast ) and plain paper, the photo looks marginal...
Hello Charles! Welcome to FixYa!
Actually as you told that you have replaced ink cartridge sometimes ago so with the new ink the effect of primary colors is more and when you print on the high quality the effect of primary color is more.
If you are printing the photos with software the try to print it on medium quality, even on low quality, The result will be fine. You can change the setting of printing in any software. After a time while when the ink will be used the result will automatically fine even on High quality.
I hope you have a clear picture in your mind.
Sir, If you find my service helpful for you then please don't forget to Rate the Service as "Five Stars" and give Words of appreciation as Feedback
Thank You for taking my service and using FixYa
Dec 17, 2011 | Canon Office Equipment & Supplies
Kodak ESP 3250 Printer shows message "Unable to detect edge of paper" and paper just goes straight through
I've had this problem with my esp 3250 that has become progressively worse over past year. I have tried every fix available online from driver, cleaning, power, etc. My printers default quality was set to 'draft' (just to save ink) which obviously speeds up the printing and I've found that if I use 'normal' or 'best' quality, it seems to help the printer detect paper edges, I think bc it slows down physical printing process? go figure but it's gotten me around a few times when I've needed hard copies immediately. Also, changing to heavier bond paper, 92 or better helped with edge detection. I'll finish current ink and not buy another one of these:(
Jan 16, 2011 | Office Equipment & Supplies
My printer is hp 2418 it is given print is very slow . so what to do
Adjust the Quality Settings for your printer.
Reduce the quality.
If it's on Best/Maximum Quality, Then change it to Normal or Draft.
That will speed it up, although it will accordingly reduce print quality, as well as amount of ink used per page.
Mar 08, 2010 | HP Photosmart C6280 Printer
All of my prints are faded. i have always had these issues with this thing. every now and then it prints fine but rarely.
If you do not print regularly on an ink-jet printer, the prints will not be good. You can try going to "print preferences", find the "maintenance" tab, then do what is called a "head cleaning". Cleaning your print head might help improve the printing quality. You might have to do this several times, depending on the quality you seek. Also, bear in mind that cleaning the print head uses a lot of ink from your cartridges.
You can also try and change the quality from "normal" to "best" (also located in "properties", under "print quality" or something similar). Also, you should always adjust your printer to best mode when printing photos.
Hope that helps!
Mar 04, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Printing very very slow 1 page about 10 minutes
go to your printer/print settings/preferences adjust your print options there. set your dry time to less. ink usage to less and /or change your print quality to fast normal or draft. in printerpreferences select spool to printer first.
Apr 23, 2009 | HP PSC 1315 All-In-One InkJet Printer
the messages you get for cartridges other than the original are not trustful. You will get the right reading for original(from Brother) cartridges. Some ink is poor for printing photo quality.
not any refillable ink is right for printing photos, sometimes too dark, sometimes you don't get the right mix of colors.
Mar 30, 2009 | Brother MFC-5840CN All-In-One InkJet...
In copy mode I can't get Image Quality to change from Fine
Ok what I just found out is that if you use the paper key then the menu key to get down to image quality the n the + and - keys to change the selection.
Jan 05, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Brother DCP-135C Print Quality Settings Not Working Correctly
Have you uninstalled the driver, and reinstalled it?
Are you running Windows Vista? If so, have you downloaded the latest software from Brother's website?
It sounds like the driver is confusing the settings internally, which leads me to think that it is either corrupt or not compatible with your operating system.
Apr 19, 2008 | Brother HL 1440 Laser Printer
Canon PIXMA MP780 All-In-One InkJet Printer Logo
162 people viewed this question
old marine
old marine
