Question about Gaggia Syncrony Espresso Machine
Gaggia Syncrony- "Decalcify" message- what do I do?
The machine is about 14 months old, it brews fine, but is showing "Decalcify" on the screen. I descaled it but it is still there. I cannot find any info regarding this message in the manual. Any suggestions as to what I can do? Thanks!
  • Anonymous Mar 31, 2008
    my machine keeps saying "decalcify" and I'm not sure what I do?
  • Anonymous Mar 23, 2014
    When I plug the machine in and turn on the switch the screen lights up but there is no message and the machine does not do anything.
    I have tried pressind othe buttons but nothing.
    Coul it be revived or should I get rid of it.
If the decalcify messsage continues to appear after you've descaled, press the ESC button for 3 to 5 seconds to clear the message.
Posted on Sep 30, 2007
Although I don't remember it, I had the same problem, and there is a way to reset it by pressing a combination of buttons. I called wholelattelove.com where I bought it and they new the fix.
Posted on Aug 19, 2007
My Gaggia syncrony digital has just stopped working....the coffeee is still being ground but there is no coffeee coming out....no water seems to be getting through. Any ideas?
There is one of 2 things going on either the machine needs to be descaled and or the brew unit screen is blocked. Remove the brew unit from machine and check screen below the red o-ring.
Aug 04, 2011 | Gaggia Syncrony Compact Coffee...
Gaggia syncrony digital DECALCIFY, I done the prosess but i have the worning about DECALCIFY
You must use the correct tablets for this, gaggia make special decalcifying tablets.
The machine must be cold when running the program.
It takes about an hour to run the solution through the machine.
Please dont forget to vote this answer was helpful.
Many thanks
Mar 04, 2011 | Gaggia Syncrony Compact Digital Espresso...
We have a Gaggia Syncrony Logic that is just over two years old. After each brew cycle, the puck is successfully ejected but water and some grounds flow out under the drip tray instead of into it....
Hi
Check the drain behind the brew unit. There is a pocket below the injector that can plug up and cause water to drain under the drip tray. Check this first. Stick you finger in the pocket and see if there is water in it. If there is, the drain below and to the right is plugged and just needs to be cleaned.
Dec 09, 2010 | Gaggia Syncrony Logic 74884 Espresso...
I have a Gaggia syncrony compact coffee machine and the coffee grinder has jammed for the second time. The repair agent employed by Gaggia inform me that they have been waiting for spare parts from Gaggia...
If the grinder jammed it might have been because the grind was too fine, try adjusting coarser then using the + or - lever to add more coffee for proper extraction. To clear jam remove brew unit and locate door to grinder chamber on left, vac out grounds, also beans in hopper. When clean run grinder and set to coarser, then add small amount of beans and test.
Aug 25, 2010 | Gaggia Syncrony Compact Coffee...
Gaggia Syncrony logic rapid steam machine leaks water from bottom
Check the chamber under the white plastic valve behind the brew unit, it might be blocked with coffee.
Apr 13, 2010 | Coffee Makers & Espresso Machines
Gaggia syncrony logic not dispensing water. Just drops pods and red light comes on. have cleaned brew unit shower screen and dispenser tube. still have the problem
Lubricate the brew unit with a food safe grease this should help.
The brew unit becomes stiff and fail to load up fully this stops the water being dispensed
Jan 18, 2010 | Gaggia Syncrony Logic 74884 Espresso...
Hi, Our Gaggia machine will not disburse water through coffee dispenser. Sounds like its operating normally till water flow should happen. Then the motor slows down to nothing. Have descaled to no effect....
Try this press the button for ground coffee then when it lights up press the coffee brew button, if water flows normally then the grind on the grinder needs to be adjusted coarser, if no water then the screen on the brew unit is blocked.
Sep 07, 2009 | Gaggia Syncrony Logic 74884 Espresso...
Screen says decalcify - Gaggia Syncrony digital
Fill watertank with descaler solution, place a large bowl underneath the steam wand, locate the button that looks like a sideways 8 or oo or similar, press it for five seconds and the machine will begin auto descaling. Follow further instructions on scree.
Mar 19, 2009 | Gaggia Syncrony Compact Digital Espresso...
Gaggia Syncrony Espresso Machine Logo
1,115 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
