Question about GE Security Simon 3 Wireless Home Security System
We have a simon 3 panel and were wondering if it will auto-arm?
We would like it to auto arm 12am and auto-disarm 9am
Is this possible ?
  • Jean-Louis Apr 25, 2013
    You can auto arm only, by option 38
    New Friend:
    Problem Solver:
  • 10 Answers
You can not perform this function unless you have a Simon XT, which will allow you to auto arm only, no limitation if you get a NX8 V2, and way more reliability, still produced by GE .
Posted on Apr 25, 2013
    Correction it will auto arm, only.
You can get the installation manual here.
http://www.home-technology-store.com/assets/PDF/GE/Simon-Install.pdf
Posted on Dec 05, 2008
Once a week at 4:00am my GE Simon XT does an auto phone test. At 4:12am it notifies me that the phone test has failed by beeping continuously until I press disarm. How do I get the system to stop running...
You will need the installer code to change the setting. Factory default is 1234. press the up or down arrow until "system programming" appears on display. press "OK" and "enter code" appears. Enter installer code. If it accepts it, "access codes" appear on the display. Use the down arrow until "timers" shows on display. Press"OK". Press the down arrow until "auto phone test tm" appears on display. Press" OK". use up and down arrows to adjust to "off". Press"OK". press "Status" and "timers" is shown. Press up arrows until "phone numbers" is showing on display. Press "OK" press "OK" again press "disarm" press "OK" press "Status" 4 times. You have now completed removing the phone number and turning off the phone test.
Nov 21, 2012 | GE Security Simon 3 Wireless Home Security...
Simon xt arms itself
there is an auto arm feature programmed in to the system. Check your setting and the system clock.
Dec 30, 2011 | GE Simon XT Wireless Home Security System
Just bought a simon xt system and setting up the touchpad. the touchpad can arm the system but it won't disarm the system when I type in the code?
Note: The default master code is 1-2-3-4 when the security system is shipped from the factory. You should change your code after your system is installed. See Code options on page 26.
If you have already changed the default master code, press the numbers in for the correct code and press enter.
Barring a faulty system the correct code and then 'enter' should sub-disarm or disarm.
Aug 25, 2011 | GE Security Simon 3 Wireless Home Security...
Module ok simon version 3
You need a new battery. 6VDC 1.2AH. The GSM module runs directly off the battery and it is no longer getting a full charge.
AlarmProfessor.net
Dec 30, 2009 | GE Security Simon 3 Wireless Home Security...
When I plug in GE Simon 3 panel it is already armed
Is your Simon 3 new or used? The default Utility Access Code 1 or 2 (i.e. the code you use when you open up the cover) is 654321, 54321, 4321 or 321. The default Master Access Code (i.e. the code you use to arm / disarm without opening the cover) is 123456, 12345, 1234, or 123. The length of the code depends on option 54. Default is 4 digits. If it's a used one that has non-default settings, you can reset memory to factory defaults.
Nov 17, 2009 | GE Security Simon 3 Wireless Home Security...
My system self arms itself
It is possible that some dirt had got into this and causeds it to think arm has been requested. Try blowing compressed air ( in a can) around the ARM button or all of them come to that, to see if that fixes it. Also make sure sokme of the buttons arent sticky or sticking
Aug 12, 2009 | GE Security Simon 3 Wireless Home Security...
I am trying to figure out how to use the remote phone access feature for my GE Simon 3 system. I want to call my panel to arm, disarm or check the status of my system when I'm away from home. ADT keeps...
ADT has there systems custom made for them. so they may have dumbed down the system so they dont have to spend there time helping with problems.
most system usr the ring hang ring method.
you dial the the number that your system is connected to let ring 1 to 2 timen hang up wait 20 seconds call back the panel should answer then follow your instructions. most panel will have you press somthing like *** them the panel will tell you to enter your access code. then the panel will walk you thru the rest.
mj
Jul 29, 2009 | GE Security Simon 3 Wireless Home Security...
GE Simon XT panel lights window, door and motion indicators
It sounds like the auto-stay arming function. Try arming it and opening and closing the door.
Feb 10, 2009 | GE Security Simon 3 Wireless Home Security...
Program
On Simon panels, the master code should default to 1234 if it's been powered down for several hours (I can't remember how long, at least four hours, possibly 12-16). So, unplug it from the wall and disconnect the system battery and leave it for the night. Power it up by plugging in the battery first and plug it into the wall. Then enter the code as 1234. It should annouce that the alarm system is disarmed. If so, your code is 1234. ;)
When removing the battery, be very careful to not break the little tab that holds it shut! Can't stress that enough.
Oct 19, 2008 | GE Security Simon 3 Wireless Home Security...
90 sec count down
You Can Turn off the panel beep under the cover that is what i did.
Apr 15, 2008 | GE Security Simon 3 Wireless Home Security...
GE Security Simon 3 Wireless Home Security System Logo
266 people viewed this question
Top GE Home Security Experts
Sean
Jim Goldsmith
Jim Goldsmith
Michael Galve
Michael Galve
Are you a GE Home Security Expert? Answer questions, earn points and help others
