Question about Zanussi WJS1265W Front Load Washer/Dryer
Change door seal on wjs 1265w
How do you attatch the new seal to the inner drum, and where does the retaining spring band go?
    Scholar:
  • 86 Answers
Hi, Your new door seal will have a double lip seal? If you use a small amount of washing up liquid on the lip of the double seal this will then allow you to ease the door seal on really easy. The spring then goes on the outer part of the seal in the groove to hold it onto the tub. Becareful and make sure you put the door seal on the right way up or you will not be happy with the result! TORN CLOTHES!
Good luck...
Posted on Jan 02, 2009
Please, I want to Know, how ti change the rubber door seal? thank you.
Hello there
Disconnect all power to the machine first!!
1 Locate the outer clamp band securing the seal to the door rim on the washing machine and examine it carefully for holes or tears. Many can be prised off with a flat-bladed screwdriver they have a spring system holding them, but some have a tensioning arrangement that has to be loosened.
2 After removing the outer clamp band, locate the inner one securing the seal to the drum and establish how this is secured. It may be necessary to loosen a clip, or you may be able to prise the band off with a flat-bladed screwdriver. Some are like very large Jubilee clips that you have to undo usually from the top.
3 Once the clamp bands have been removed, use both hands to pull the seal away from the inner drum rim. Some AEG machines have a water spout holes that will have to be lined up. Others have a drain holes.
4 Rubbing a drop of washing up liquid into the groove on the AEG door seal/gasket that locates on the drum makes fitting the new seal easier.
5 Your new AEG washing machine door seal should be fitted by locating the drain holes at the bottom of the seal first then push it on with both hands working opposite directions towards the top. This is quite hard if you have never done it before.
6 Refit the inner band remembering this must be tensioned correctly for it to be water tight.
7 now fit the outer band and the test your AEG machine for any leaks,
I
Jan 01, 2011 | AEG L66600 Front Load Washer
Replace door seal
its not to easy to do but,,,
look at the bottom of the washer were the door closes the seal is held on with a spring wire,,unhook this wire and fold the seal inside the washer,,look for the inner drum there is another spring wire holding the inner part of the seal to the inner drum undo this as well,, pull old seal out through the door hole,,,now fold new seal so that the inner wire can be fitted round the new seal first to the inner drum,,then pull the new seal through the door hole and fit the outer wire to seal,,,
and then job a good un?,,, not easy a,,well i did tell you this!
Jul 12, 2010 | Frigidaire ATF6000ES Front Load Washer
Trying to change door seal on zanuzzi 1200 cannot get it back on
Follow these steps to replace your door seal:
For all Free appliance repair videos visit our VIDEO TUTORIALS
3 Once the clamp bands have been removed, use both hands to pull the seal away from the inner drum rim. Some machines have a water spout holes that will have to be lined up. Others have a drain holes.
4 Rubbing a drop of washing up liquid into the groove on the door seal/gasket that locates on the drum makes fitting the new seal easier.
5 the new washing machine door seal should be fitted by locating the drain holes at the bottom of the seal first then push it on with both hands working opposite directions towards the top. This is quite hard if you have never done it before.
6 refit the inner band remembering this must be tensioned correctly for it to be water tight.
7 now fit the outer band and the test the machine for any leaks,
All washing machine spares featured in this article are available at apart4u with more video help in our tutorial section.
Information provided is a guide only. aPart4u accepts no liability for any problems occurring whilst attempting any advice shown. If in any doubt about fixing your appliance, always contact a qualified repairer.
Nov 17, 2009 | Zanussi ZWF1440 Front Load Washer
How to change door seal
Oct 19, 2009 | Zanussi IZ12 Front Load Washer
Repacing the door seal on my oko lavamat washing machine
this could be out of the door tension clip you might see it in this video
Sep 04, 2009 | AEG Lavamat 88840 Front Load Washer
Zanussi wjd1667w door seal dislodged
May 26, 2009 | Zanussi WJD1667W Front Load Washer / Dryer
How do you change a door seal on a zanussi fjd 1266w
May 17, 2009 | Zanussi FJD1266W Front Load Washer
Door seal
remove the front retainer, wire/spring affair.
slip the front of the seal off.
seal is held onto drum by a large sprung retainer, remove this by levering it off with a screwdriver.
put the new seal in and it's a case of putting the retainers back. the inside can be made easier with the application of some soapy water in the seals groove that the inner retainer sits in.
good luck as it can be easy or difficult doing the same job.
Dec 23, 2008 | Hotpoint Ultima WD72 Front Load...
WASHING MACHINE DOOR SEAL REPLACEMENT
Sep 17, 2007 | AEG Lavamat W1050 Front Load Washer
How do I fit a new door gasket?
after putting the seal on with the aid of washing up liquid put the spring on first by the door catch hold it on with one hand and isnert a screwdriver in the hole for the door catch this will enable you to hold the spring on if you put your knee against the screwdriver giving you two hands free to push the spring on
Aug 04, 2006 | Zanussi FJS1225W Front Load Washer
Zanussi WJS1265W Front Load Washer/Dryer Logo
121 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
Chris Hall
Chris Hall
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
