1984 ford f250 i lost my key then screwed up the key hole now how do i get the switch out to replace?
Take a drill and drill out the tumblers use small bits to start off and then use large bits to finish out the job when the tumblers fall out take a small punch to knock out pin that holds the ignition in place then put in a new one be sure not to make a big hole of where the pin fits into because if you do the new switch will just fall out when you remove the key
