Question about Zyxel Prestige 841 (91-004-226010) Modem
Svchost error with zyxel p 600 series
I had windows XP service pack 2 and zyxel p 600 Modem was runing perfectly on it but after i put windows xp pro,and install zyxel, every time i connect it give me "SVCHOST.exe application error"
if i clicked on ok or cancel, i can't use the net and sometimes the pc freez
is zyxel 600 work with service pack 2 only?
thanks
    Sniper:
  • 163 Answers
Your operating system is corrupted..........
Posted on Jul 17, 2009
    Problem Solver:
  • 15 Answers
Hey, I think you should run a registry scan for your PC at first. You know that svchost.exe could be caused by the invalid or corrupted registry entries.
Posted on Jul 06, 2010
ErI have all this on the windows task manag
its normal. when you open task manager and you click the process tab you see alot of them under SYSTEM. those are manditory for your computer to run.
Mar 06, 2010 | Microsoft Windows XP Home Edition
Cannot load driver for dsl 200 modem on xp home service pack 3
try this:
http://www.xpvistasite.com/dsl_200_driver_27843.htm
Jun 03, 2009 | D-Link DSL 200 (DSL-200) Modem
Generic host error inwindows xp professional
It is a virus related to a security problem. Update to service pack 3 and dowwnload all updates as the first thing to do after installling windows, or an updated service pack 2..
Another link for a service pack 2 upgrade: Hope this helps. http://www.ryanvm.net/msfn/updatepack-sp2.html
Jan 10, 2009 | Microsoft Windows XP Home Edition
I have deleted svchost.exe from windows xp
To complete part one, follow these steps:
  1. Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
    Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted to do so.
  2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  3. If you have a dual-boot or multiple-boot computer, select the installation that you want to access from the Recovery Console.
  4. When you are prompted to do so, type the Administrator password. If the administrator password is blank, just press ENTER.
  5. At the Recovery Console command prompt, type the following lines, pressing ENTER after you type each line: md tmp
    copy c:\windows\system32\config\system c:\windows\tmp\system.bak
    copy c:\windows\system32\config\software c:\windows\tmp\software.bak
    copy c:\windows\system32\config\sam c:\windows\tmp\sam.bak
    copy c:\windows\system32\config\security c:\windows\tmp\security.bak
    copy c:\windows\system32\config\default c:\windows\tmp\default.bak
    delete c:\windows\system32\config\system
    delete c:\windows\system32\config\software
    delete c:\windows\system32\config\sam
    delete c:\windows\system32\config\security
    delete c:\windows\system32\config\default
    copy c:\windows\repair\system c:\windows\system32\config\system
    copy c:\windows\repair\software c:\windows\system32\config\software
    copy c:\windows\repair\sam c:\windows\system32\config\sam
    copy c:\windows\repair\security c:\windows\system32\config\security
    copy c:\windows\repair\default c:\windows\system32\config\default
  6. Type exit to quit Recovery Console. Your computer will restart.
Dec 02, 2008 | Microsoft Windows XP Home Edition
Use zyxel u1496e plus modem windows xp
Default Gateway 192.168.1.1 modem : Zyxel
p/d - green
eth - orange
internet - off Zyxel MODEM interface >> WAN >> Setup WAN >> UId & P/w >> Apply
Internet light will go Green
Nov 19, 2008 | Zyxel U 1496E Plus (AM021000) Modem
Start up problem
It appears that Service Pack 2 did not completely install. Try to boot into safe mode (F8 at startup). If you can, go to control panel, then add/remove programs. Scroll all the way down, select Windows XP Service Pack 2 and click "remove".
After it's removed, you will need to reboot, but the system should come up normally after that.
Hope this helps - please remember to rate :)
Sep 25, 2008 | Compaq Presario R3000 Notebook
Can't Open Internet Explorer
You have to contact your service provider. That's a thing which is done by them to secure there internet service. They will give you the username and password. I evn tried that and they asked me to type the modem name and 'admin' as a password. For example, my modem is STstarcom. so the username wax starcom and password: admin.
Thank you.
Aug 09, 2008 | Zyxel Prestige 841 (91-004-226010) Modem
Svchost cant be written
can you go to control panel, administrative tools and event viewer and look in applications and software and see if there are any red crosses that show up and if so right click on them and go down to properties and it will send you to microsoft for a possible solution. But also the services host, which is the svchost.exe is a complete programme which runs the internet ports and allsorts of things. Make sure you have no spyware or trojans, so run virus check and an antispyware programme to check for other nasties, you can get a free one here:- http://www.download.com/3000-2144-10045910.html Also run a registry cleaner, again you can download this excellent free ccleaner programme to get rid of all temp files and unrequired system files http://www.filehippo.com/download_ccleaner/ after all is run restart pc and see if its still popping up with the fault.
Jun 12, 2007 | Microsoft Windows XP Professional With...
Zyxel Prestige 841 (91-004-226010) Modem Logo
1,086 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
