Question about Oritron Televison & Video
Oritron no picture
We were trying to get our surround speakers set up on our Oritron DVD..when we were going thru the menu to set all the parameters, we changed from PAL to NTSC and we've lost the picture. We've got audio, but with no picture, we can't even get back to the menu to reset. Don't know if it was the PAL/NTSC change that did it, but we're without a picture..
    Master:
  • 333 Answers
Phase Alternating Line (PAL) is a colour encoding system for analogue television used in broadcasttelevision systems in most countries broadcasting at 625-line / 50 field (25 frame) per second (576i)
NTSC is the video system or standard used in North America and most of South America. In NTSC, 30 frames are transmitted each second. Each frame is made up of 525 individual scan lines.
You might try disconnecting all power from the system. unplug it.
disconnect the TV. Power back up. Maybe it will reset to factory settings. See if your TV will have a switch to NTSC.
Posted on Oct 05, 2017
4 Suggested Answers
SOURCE: oritron dvd 3119 player
after unsuccessfully trying to naviagate the menu , i unplugged the dvd player for 10 or 15 min. then plugged it in again and changed the output i had it plugged into,,from video 1 to video 2 and i got my picture back it seems fine now
Posted on Apr 03, 2008
SOURCE: Oritron dvd 3119 player
You have to blindly instruct the NTSC/PAL menu item, which toggles between NTSC and PAL;
This is how it is done:
1) turn your dvd player off.
2) Turn it back on and make sure there is no DVD in the player tray.
This will ensure the menus are active
3) Using the remote, press the dowm menu selector key exactly three times
4) press the center menu select key once.
This will activate the display adjustement menu
5) press the down menu key exactly once.
This will activate the NTSC/PAL menu
6) press the center menu key
DONE.
The player should now have switched back to NTCS if it was in PAL.
IF it was in NTSC it should have switched back to PAL.
Note: If you still have the manual you can follow the menu tree blindly using the instructions in the manual. The above sequence is for activating the NTSC/PAL menu.
This player can also switch to progressive scan, which creates a similar problem. At least the progressive scan menu has enough warnings before it will actvate.
Posted on Sep 22, 2008
I would make sure to add step 2.1 which is to select the menu button. I tried these steps but without selecting the menu button first, I could not reset. Good luck
Posted on Jan 01, 2009
Tip
Oritron DVD600 Region Free Fix
Oritron DVD600 DVD Player Region Free Fix
Would you like to unlock your Oritron DVD600 DVD Player to Region Free?
Follow these steps to unlock your Oritron DVD600 DVD Player:
  1. Press the Menu button on your remote control.
  2. Using your remote control, enter the code 1, 6 and 7.
  3. Press the Mute button on your remote control.
  4. Press the Okay button on your remote control.
Your Oritron DVD600 DVD Player is now Region Free.
I hope that helps.
on Apr 25, 2010 | Oritron DVD600 DVD Player
Ontelligent eye not working
  • Has the I.S. (Intelligent Sensor) ever worked?
  • Did someone make changes in the Picture Menu and now the I.S. is not working?
Sometimes the changes the IS makes are so small you cannot notice, but the I.S. is working.
LG’s “Intelligent Sensor” uses 4,096 sensing steps to evaluate its surroundings. Using a
sophisticated algorithm, the LG processes picture quality elements including brightness, contrast, color,
sharpness and white balance. The result is a picture optimized for its surroundings, more pleasing to
watch and which can also save up to 50% in power consumption.
1. You can go into the Menu, Picture Menu, and then Advanced. From there you can fine tune all the picture settings.
2. You can also try a Picture Reset. Inside the Picture Menu, you can perform a Picture Reset. The Picture Reset returns the “selected picture mode” back to the default factory setting.
3. If all the above fails then the problems are between the Main board (process the picture parameters) and the Intelligent Sensor (is reporting the surroundings to the main board). Either one of these issues will require new parts.
Good Luck.
May 20, 2010 | LG 42PX5D 42 in. Plasma HDTV
Some DVD's i play only play the soundtrack to the DVD, not the dialogue, while others play both. What's up with that?? LG dvd player dv8743p. Cheers for any help
I had this problem, till i went into setup on my remote then chose audio and noticed all the speakers for surround sound were turned on in the options. As i don't have surround sound i turned them off . Now it works ! The player was sending the sound to non exsistant speakers. Hope this helps
Nov 21, 2009 | Oritron DVD600 DVD Player
NO SOUND FROM TV THROUGH THE SOUND SYSTEM SPEAKERS
All you need to do is follow the following directions on your TV and you will be on your way listening to your great Philips TV on your great Sony Surround Sound. You do not need to buy any other cords or anything else. Its just a setting on your TV that needs to be adjusted.
By the way, I have a Sony Home Thearte System DAV-HDX275 and I've had it for almost 8 months and its sounds good with my TV and Movies. The speakers are very cheap and it doesn't give you the sound you expect. So I came accross some Boston Accustics CR65's that are not sold anymore but they did run around $700 a peice. I am upgrading the Reciever very soon to a better qualtiy Reciever. This Surround Sound System is great for a starter Surround Sound System.
  1. Press MENU on the remote control and select TV settings >
  2. Press up or down to highlight a sound setting and press right to select the setting.
  3. Press up or down to adjust the setting, and press OK to confirm the change.
  4. Press Menu to exit.
You want to pick Incredible Surround, but if that does not work try them all. The Incredible Surround should do the trick because that switches it from the TV Speakers to the Surround Sound.
Thank you for using Fix Ya!
Don't forget to rate the overall satisfaction of this solution.
Have a Great One!
Mar 13, 2009 | Philips 42PFL3603D/27 42 in. LCD TV
Tv built-in dvd player wont play thru surround sound
goto your menue setings and slect sround sound and set up to external sound system.
Jan 10, 2009 | Toshiba LCDTV/DVD Player 19HLV87
Apr 03, 2008 | Oritron NPD3117 DVD Player
GO VIDEO DVD + VCR model: DV 1130 I want only the basic connection
Once the setting for Progressive Scan output is entered,
an image will only be visible on a Progressive Scan compatible
TV or monitor. If you set Progressive Scan to On in
error, you must reset the unit. Pointing the remote at the
player, press the STOP (x) button to stop any disc that is
playing. Next, press the STOP (x) button again and hold it
for five seconds before releasing it. The video output will
be restored to the standard setting, and a picture will once
again be visible on a conventional analog TV or monitor.
Nov 07, 2007 | Televison & Video
DVD sound problem
Go into the setup menu into the audio options (use arrows on remote to go up and down menu and press left to enter the next menu to change options). By memory when I was running this just through a TV and not through a surround sound system, I had to turn off the addition speaker options in the audio menu. The one's like centre speaker etc have an small/large/off option. I had to turn these off so that all sound would come through the TV speaker only. That is about all I remember as I was trying to get this running for my aunt and I no longer have the DVD player.
Oct 04, 2007 | GoVideo DVD-VCR Combo
Televison & Video Logo
Top Oritron Televison & Video Experts
 Grubhead
Grubhead
Mikee
Are you an Oritron Televison and Video Expert? Answer questions, earn points and help others
