Question about Cyclades TS 1000 Terminal Server
Hi, I have a Cyclades TS-1000 and I do not have the root password. Is there a way to reset it to the factory defaults.
  • Anonymous May 18, 2009
    Well, I do not have the console cable. Is there not a narrow hole to put something in to reset it to factory defaults?
  • 3 Answers
Well, you don't even have to go to that extreme to recover your root password. Connect to the console port of the TS to your laptop or workstation. Type reboot (as root) and hit Enter. As you watch the boot sequence, pay close attention as you'll need to input characters. Specifically, when you see "Linux PPC Load", press the space bar a couple of times and type out the word single and hit Enter. If you did it in time, you should see a hash (#) prompt without requesting a password. From here, type the command passwd and hit Enter. Choose your password and confirm it. Don't forget to perform a signal_ras hup followed by saveconf to ensure your changes are activated immediately and are saved to flash memory (non-volatile state). From here type reboot again and you should be back in business.
Regards,
John
Posted on Dec 22, 2008
Resor factury shdls router ct524(hardwair)??????No reset button on the back of the modem!!!!!!!!!!!!
The factory reset is completed via the configuration page. Enter the IP address of the router in your browser and then login. For
example, if the IP address is 192.168.1.1, enter http:// 192.168.1.1 Look for Erase and Reboot and click to reset to factory defaults. Caution! If you reset your device to the factory default, any changes to
parameters will be lost and all parameters will revert to their default values.
Try root at the default username and password unless it was changed. (or root and 12345). I am not aware of a hardware factory reset i.e. pin hole.
Dec 17, 2014 | Computers & Internet
I forgot the password for the 192.168.1.1 page what do i do
Please do the following.
1. If you have changed the default password you will have to reset router and the password will be set to the default password. To reset the router to factory default keep the reset button pressed for 15 seconds while the router is powered on the reset button is located on the back of the router inside a small hole which needs to be pressed using some pointed object like a pen or a pin.
NOTE** its importaint to note that if you reset the router to factory defaults you will lose all the configuration and you will have to reconfigure the router***
2. if you have not reset/ changed the password ever try using the following user name and password
username password
admin admin
system admin
root root
admin
System
root
Aug 18, 2011 | Gateway Wireless-B Router (wbr-100)
Hi i am having a problem setting my password for the router
The default username and password for most routers is admin, administrator, or root for the username and blank (no password), admin, or root for the password. That should get you logged in, if you have set a username and password and cannot get into the configuration screens most routers have reset button by the ethernet ports that when held down for approx. 30 seconds will restore the router to factory settings.
Mar 21, 2011 | Computers & Internet
How to reset Paradyne (1740A1400) Router ?
Hi Samsungvt!
You will have to access the Web Interface of the Paradyne Router to reset it to Factory Defaults.
First, connect your PC to the Paradyne Router. Check your IP address is in the range 192.168.1.xx (xx = any number from 1-254). Open your web browser, type 192.168.1.1 then press enter. Enter the default username and password (shown below) to access the router's web interface. On the left pane, click Erase and Reboot; this will reset the router to factory default.
Default IP address is 192.168.1.1
Default Username and Password: root
Let me know if there's anything else...
Anthony
Jun 21, 2010 | Paradyne (1740A1400) Router
Console connection from Cyclades TS1000 and Sun T3+ using RJ-45 to RJ-45 connector, no response.
From what I remember you would need a 'rollover cable' that connects the pins to each other in reverse order (e.g. 1 to 8, 2 to 7, 3 to 6, 4 to 5, 5 to 4, 6 to 3, 7 to 2, 8 to 1)
Mar 22, 2010 | Cyclades TS 1000 Terminal Server
We have an Avocent ACS32, that we 'forgot' the Admin pwd to.
start the unit single user mode by hitting space after Linux/PPC Load: .... and typing single and hit
use the passwd command to change password and saveconf to save the password
Dec 15, 2009 | Avocent Cyclades Alterpath ACS32 (ATP0105)
Router locked. Cant remember the password.. User "root"
The only solution for u to login in to the router is to reset the router.
1.If you forgot your password, you must reset your router. Unfortunately this process will change all your settings back to the factory defaults.
2.To reset the router, locate the reset button (hole) on the rear panel of the unit. With the router powered on, use a paperclip to hold the button down for 10 seconds. Release the button and the router will go through its reboot process.
3.Wait about 30 seconds to access the router.
4The default IP address is 192.168.1.1. When logging in, type in the default User Name “admin,” and the
default Password “admin” then click on the OK button to access the web-based manager.
Regards,
Ayyasam
May 29, 2009 | Buffalo Technology WHR-G54S Wireless...
Superuser password.
I am not sure what the default root password is, but you could try
this website:
http://www.tech-faq.com/reset-bios-password.shtml
Dec 20, 2008 | Acer Aspire One PC Notebook
Cyclades TS 1000 Terminal Server Logo
2,786 people viewed this question
Top Cyclades Computers & Internet Experts
David Payne
David Payne
Are you a Cyclades Computer and Internet Expert? Answer questions, earn points and help others
