Question about Sharp AR-5316 Advanced Digital Imager Copier
SHARP MX-2300N Hello the screen that pops up says "Load Extra paper (TYPE: Plain)" but that and all trays are full of paper. Hope that helps you. If you have a solution please let me know. Thank you kindly.-Meg
  • 47 Answers
Someone has sent a print job from a computer to the copier with an odd paper size specified. Go to Job status, under "print" highlight the first job in the que and delete it. (if the job was sent more than once you will have to repeat. ) Check the document and print settings of the offending document.
Posted on Dec 07, 2008
Mx 2830 - fails to print - asks to add extra plain paper
Check the paper type and paper size in the Printer Properties. Set them according the actual paper used in the printer. Check the paper size in your document you want to print. Correct, if differs from the printer's paper size.
Jan 09, 2014 | Sharp Office Equipment & Supplies
How do i print on cardboard (heavy paper card)
The mx2300n only supports up to 209gsm heavy card. You must make sure that your heavy card is not over this rating.
Set the bypass tray as 'Heavy' by clicking on the trays on the main copy mode screen, select type & size for bypass. Select heavy, and Auto AB as this will allow the tray guides to detect the size of your paper. Load the tray with up to 20 sheets of Heavy paper.
Open your document, select Print, then properties. Under the 'paper' tab, select paper source as bypass tray, and paper type as heavy (if you miss one of these steps, the ,machine will ask to load paper due to size or type mismatch).
That's pretty much it.
Oct 16, 2013 | Sharp MX-2300N Color Copier
Cannot change paper type to "plain", stays on "Extra"
Change the tray button key or switch on the panel. It wears out with time and cannot be detected even if pressed.
Jan 21, 2013 | Sharp MX-3501N All-In-One Printer
Print 4.374 x 5.75 sharp 2300
Envelopes must be run from the bypass tray at the side of the machine. touch the paper trays on the touch screen. Set the bypass to envelope and com10. when you go to print, make sure the paper type is set to envelope under printer preferances.
Aug 03, 2012 | Sharp MX-2300N Color Copier
How do i print 6 3/4 return size envelopes on a sharp 2600n
You have to select the Manual Feed Tray by touching the picture of the copy machine on the LCD screen. That will then show you the paper trays. Touch the paper type soft key for the Bypass/Manual Feed Tray and then select envelope. then press ok a couple of times till you are back to the main screen. Put your envelopes face down on the Bypass/Manual Feed Tray. If you are printing from a computer do the same thing after you go to printing preference/properties.
Oct 20, 2011 | Sharp MX-2300N Color Copier
There is a paper on a machine bu *** keep popping error msg-load A4R paper. WHAT COULD IT BE
Your using european standards instead of USA. Change the paper size to Auto Inch.
Sep 19, 2011 | Sharp MX-2300N Color Copier
Remove paper from center tray
i have a sharp m7001n that says to remove paper from center tray cant find there is not a finsher on it also says tray 1 and 2 is prohibited.can you help
Sep 20, 2010 | Sharp MX-2300N Color Copier
How do you load standard sized envelopes into a Sharp MX-2300 copier?
Use the Bypass tray to load it. But first try the paper tray and try to load it there and see if the paper tabs have a size adjustment for envelopes. If not try the by pass
Apr 10, 2010 | Sharp MX-2300N Color Copier
How do i use the auto configuration facility on a sharp mx-2300n. I have saved the configuration on the server but when I connect to this printer over the network, I only get Factory Defaults under User...
While at the printer settings page of the copier on your PC under printer configuration there is an automatic configuration tab. Once you press this it will ask you to check the boxes with the arrow . The paper is set determined by the copier itself. You may need to check your copier settings to make sure it detects the correct paper in the tray. Also it is not recommended to install this way mainly because if the customer doesn't want to print color they are not able to change the printer condition settings at the individual PCs. So individual install is recommended.
Oct 17, 2009 | Sharp MX-2300N Color Copier
"Load Paper" screen wont go away. Is loaded with paper!! Help!!
Goto the job status and select the print job that is waiting.. To the right, select details and select the paper size you want. Identify the job because you will want to make sure the settings in that document are set to the correct paper size and type.
Dec 03, 2008 | Sharp MX-2300N Color Copier
Sharp AR-5316 Advanced Digital Imager Copier Logo
549 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
