Question about Denon DVD-9000 DVD Player
Dvd skips and eventually locks up after playing about one hour.
After heating up the dvd skips and eventually will lock up.  if I let it cool down for a few hours, I can play a dvd again for a while
2 Suggested Answers
  • 88 Answers
SOURCE: denon 9000 skips after an hour of use
it sounds like you have a heat problem,try to put your player somewhere that it has alot of room to keep cool,i've noticed some people put there players on top of the t.v. or close to other electronics,the whole key is keeping things cool,let me know if this helps because you have a very good player.
Posted on Dec 06, 2008
DVD just locks up after about an hour of play
The DVD Player is overheating, dont have other hot machines under it, let it cool down naturaly and whatever you do, DON'T try to cool it quickly with a fan or vacuum cleaner becasue the fast temperature change will crack the internal components.
Nov 24, 2011 | Samsung Televison & Video
Wont read games only reads dvds
This is going to be a bit long -- but very detailed, so please read it carefully. There are several reasons that an xbox 360 system will have problem reading discs. The error messages also vary from unreadable disk, no message at all but the game skips, "please insert disc in a 360 console" to "open tray." There are a few reasons this may happen:
1.Bad disc. Check the back of your disc for scratches. If it looks good (or plays fine in another console), then the disc is probably fine. Also-- try more than 1 game to be sure.
2. Bad laser. The XBox 360 has a DVD drive very similar to a PC's DVD drive inside. The drive contains a bunch of parts including a few motors and gears and a laser.The laser is the part that actually reads the disc. The reality is...with all the hours and hours of game play, lasers do eventually wear out. The laser isn't very easy to replace, but it is replaceable. You can find any and all XBox 360 lasers at the following website:
http://store.richspsxparts.com/xb360ac.html
3.Bad DVD Drive. Sometimes other components inside of the DVD drive can become bad such as the motor that spins the disk, the motors that open the tray, etc, etc. You can get a new DVD drive to just replace everything,including the laser, in one shot but there is a catch. The XBOX 360's DVD drive is tied to the motherboard using a software lock.The easiest way to overcome this lock is to buy the exact same manufacture DVD drive that is in your system now, remove the circuit board from the old DVD drive (which contains the software key) and transfer the circuit board into the new DVD drive that you purchase. If you do this simple procedure, there is no flashing involved. The following website carries DVD drives and also provides instructions on swapping the circuit board from the old drive into the new one.
XBox 360 parts: http://store.richspsxparts.com/xb360ac.html
DVD Drive Swap Info: http://store.richspsxparts.com/imnooninxb36.html
May 15, 2010 | Microsoft Xbox 360 Pro System Console
When i try to play a game it keeps sayiny play dvd
This is going to be a bit long -- but very detailed, so please read it carefully. There are several reasons that an xbox 360 system will have problem reading discs. The error messages also vary from unreadable disk, no message at all but the game skips, "please insert disc in a 360 console" to "open tray." There are a few reasons this mayhappen:
Jan 15, 2010 | Microsoft Xbox 360 Console
Dvd plays, and then skips and or locks. Must use
Have you tried unplugging the unit and blowing out all the dust and lint along with cleaning the laser?
Dec 15, 2009 | Televison & Video
Won't unlock after the self clean process
Yes, it should. Most will take a few hours (two or more) to cool down to a "safe" temperature so you can open the door. If it has been more than 12 hours, you may have a door lock issue and may need to schedule a service call.
Dec 05, 2009 | Food Processors
Dvd player makes noise, doesn't read discs
mine did the same thing it just kept ticking when i wanted to play a disk, id take to top off with the four tiny little screws and hoover it, mine still makes a bit of noise but works x
Mar 11, 2009 | Panasonic DVD-F86 Multi-disc DVD Player
Denon 9000 skips after an hour of use
Dec 06, 2008 | Denon DVD-9000 DVD Player
Sony dvd tray locked
had the same prob with a sony dav dz it kept saying locked but after hours and hours of pressing random combinations it came off im sure it was unplug plugback in then hold power and open tray and tap stop or a combination of those buttons.i woud try it again on mine to make sure but i do not want to lock it again.
Oct 23, 2007 | Sony DVP-S330 DVD Player
DVD DMR-E50 Doesn't Work
As it's been 5 months I suspect problem's been solved - how? I have similar problem, E50 recorded DVD-r's lock up after playing about an hour. RAMs and commercial DVDs play fine.
Aug 12, 2007 | Panasonic DMR-E50 DVD Recorder
Denon DVD-9000 DVD Player Logo
Top Denon Televison & Video Experts
Jonathon summesfield
Are you a Denon Televison and Video Expert? Answer questions, earn points and help others
