Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Epson CX 7400 WONT LOAD PAPER
I have an Epson CX 7400 and it wont load the paper.It acts like it wants to but it wont load. I DONT KNOW HOW TO LOAD THE PAPER
  • Anonymous Apr 10, 2009
    Mine does the same thing. How do i check the gears?
  • 28 Answers
Fiend your solution direct from EPSON. Here is your solution...
http://www.epson.com/printer/prob676ijt65/solution
takiqq27
Posted on Sep 04, 2009
  • 4 Answers
The reason: number one it is an Epson and all their printers have very weak plastic gears in the paper loader mechanism that break easily when you unjam a paper jam. You have to treat these printers like fine China. That is why you see allot of Epson printers Refurbished.
Buy a Canon if you want at least three years of no problems with their paper loading mechanism. Almost any other printer manufacture builds a better printer than Epson, Sorry for the bad news.
Usually you just buy a new printer when you have these paper loading problems, also try to see if the printer is jammed still with a piece of paper, or maybe some dirt or lint and hair, blow it out with compressed air and make sure the rubber roller paper feeder is turning, if not then you can buy a new printer for cheap these days. Usually a new printer cost the same as the replacement ink for the printer, so buy a new printer. Printers now a days are disposable especially Epson.
Posted on Feb 26, 2009
2 Suggested Answers
SOURCE: Epson CX 7400 WONT LOAD PAPER
I had the same problem. If you call Epson, they will send you another printer out. I did this, and they didn't even ask me to send the old one back. You do have to have the serial number handy though. My suggestion is to call Epson.
Posted on Oct 21, 2008
My epson sx535wd printer will not feed my photo paper through the second feed to print
My 535 wont load 4 x 6 photo paper and has not done from new, i gave up in the end as chasing around trying to find an answer was nearly impossible.
Dec 16, 2012 | Epson Stylus Office Equipment & Supplies
ADF wont feed the paper through the printer
You can load up to 30 sheets of plain paper in the Artisan 800 ADF. If the ADF doesn't feed the paper, check the following.
1. Make sure that you are loading plain paper only without a holes. 3-hole punched paper is not supported by this printer.
2. Load paper not exceed 30 sheets.
3. Open the ADF and check for any jammed paper or foreign object that is blocking the paper feeding path.
4. Check if the BIG GREEN ADF indicator is lit when you load paper in the ADF.
If the issue persists, your printer will require service. You can contact the Epson for warranty if your printer still under warranty. If your warranty expires, look for an a service center that can repair your printer.
Oct 29, 2011 | Epson Artisan 800 All-In-One InkJet...
Epsom tx110 wont feed paper
Hi!
Try to check for any obstruction. Fan the paper as well on the paper tray. Closely check the mechanism as well when it acts like grabbing the paper. If all fails. Call Epson for a replacement.
Hope this helps.
Oct 12, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Ink and paper lights flashing alternately epson c64 photo edition. paper fine, ink levels fine, power fine, comms with computer fine, still wont work, Help.
-turn off printer
-disconnect from computer
-load a couple sheet of plain paper
-press & hold paper feed button while turning the printer on
-it should print a test page if it is working fine, otherwise it is bound for service
Apr 02, 2010 | Epson C64 InkJet Printer
Ink cartridges are all full, but when I print, it acts as if it's printing but nothing appears on the paper.
  1. Turn off the Stylus CX.
  2. Load letter-size paper in the sheet feeder.
  3. Press the cp_button_48_er.gif ink and cp_button_1.gif On buttons together and hold them down for about 3 seconds.
    The Stylus CX turns on and prints a test pattern, which includes a nozzle check. Shown below are some examples of what the nozzle check may look like.
Nozzle check pattern with no gaps im_158_er.gif Nozzle check pattern with gaps im_159_er.gif
Feb 15, 2010 | Epson Stylus CX4800 All-In-One InkJet...
Whats going on with my printer
Replace paper feeder. Or find at aicaxz solutions about fixing paper jam without replacing.
Sep 17, 2009 | Epson Stylus Multifunction Inkjet Printer/...
The spring from the back where you load the paper has pop out and I dont know where it goes, and now I can not print anything because the paper cannot go through? Can someone help and guide me to put
The location of the spring is located near of the sensor.The sensor is attached by the sweveld arm then install the spring in the center of the pivot area of the sensor.So that the sensor will goes up ,it need a spring to do the act.
May 28, 2009 | Epson Office Equipment & Supplies
Computer keeps saying "paper out" or "not loaded properly"
disconnect the printer from the computer
do a manual paper feed
if it can feed paper, replace usb cable or try another usb port
May 14, 2009 | Epson CX8400 All-In-One InkJet Printer
Sep 03, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Printer will not feed/accept paper.
Front LCD reads error "Check Paper & Retry" When paper is inserted and loaded correctly and machine is reclosed the printer then initializes then reverses the feed of the paper and is ejected and error continues to reappear.
May 25, 2008 | Epson Stylus C48 InkJet Printer
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
316 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
