Question about Sony KP-51WS520 51" Rear Projection HDTV-Ready Television
KP-51WS520 wont turn on - standby & timer lights on constantlly
4yo Sony KP-51WS520 does not turn on. Both the standby and timer lights are on constantly, no blinking. Reset does not change anything. Just before this happened, tv seemed caught in a loop - trying to start itself, but not being able to, over and over - saw the tv doing this, unplugged it, and... the steady lights appeared. Any insight or testing I can try would be appreciated. Thanks!
  • mark_stein Dec 05, 2008
    No experience w/big screen tvs but enough w/smaller electronics to chk the voltage and take a look. I have the service manual and see IC702 on the A board. Thanks for explaining why the lights don't blink. If this is the problem can I just replace that board?
  • 10,594 Answers
You need to check supply volts on main micro IC702 on main board of Sony KP-51WS520 TV.
If you have experience of big TV repair then I would recommend to get service manual of TV from any online store and check above said IC supply volts. TV must give error by blinking light in case any problem in drive circuits and if main micro fried, no error signal will be there.
Posted on Dec 05, 2008
  • Shahid Electronics
    Shahid Electronics Dec 05, 2008
    I think you should check supplied voltages for that IC like..
    3.3 volt on pin 16
    STBY 5 volt on pin 99
    If above said are available, then IC is defective and replace A board.
I have sony wega sony wega tv kp 51ws520 no turn on just standby light blinking and i lost remot plz help me
Is the light blinking 9 times? If so thats a very common problem caused by failed diodes on the G board which will need to be replaced.
Jul 19, 2011 | Sony KP-51WS520 51" Rear Projection...
Sony kp-51ws520 when turned on just has standby light flashing . the rest is all dead, no picture or voice.
Standby flashing light shows that tv got some internal problem. How many times standby light is flashing is info that provide info about what section of tv got problem.
Count standby light blinks and let me know, there would be 3 seconds long pause in blinks so count pause to pause.
Jul 21, 2010 | Sony KP-51WS520 51" Rear Projection...
The standby light just blinks when i try to turn it on and it wont turn on
Count the number of blinks of the standby light. It will bink a count, pause and do it again (Common counts are 2 -9) Give this count to a Sony service center and they can help you know what the issue is. (Probably the lamp)
Apr 17, 2010 | Sony KP-51WS520 51" Rear Projection...
I have a 51 in. Sony model kp-51ws520. when I turn tv on I get sound by no picture. Standby light blinks 5 times then shuts off . If I power it back on, sound no picture then standby blinks 10 times after...
Ck small blue capacitor next to hori output Transistor 2k volts they have been known to go Bad, if its OK replace Both of your STK ICs STK392-110s use 180s Mats has them 1-800-628-1118
Mar 23, 2010 | Sony KP-51WS520 51" Rear Projection...
My Sony KP-51WS520 wont turn on
There is a small diode in the power supply that is bad. Do you have the capability to replace this yourself? (can you solder?) If so I can help you through it.
Jul 07, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Sony KP-51WS520 won't turn on
Something bad in power supply or horiz output.Possible bad gun.Needs a repair shop unless you know electronics.
Tv wont turn on
You have a zero crossing failure.
Replace diodes D6301 and D6116 on the G board with 1n4002 diodes.
May 17, 2009 | Sony KP-51WS520 51" Rear Projection...
TV will not come on. TV standby light blinks nine
You need to call a Sony service center for this problem. It will cost you less in the long run.
Apr 16, 2009 | Sony KP-51WS500 51" Rear Projection...
T.V. won't turn on
PCB repair should be done by a qualified tech. Your problem could be HV cap bad,xformer defective or bad connection problems and pico fuse open. Check 2KV cap near xformer.
Sep 26, 2007 | Sony KP-51WS520 51" Rear Projection...
Sony KP-51WS520 51" Rear Projection HDTV-Ready Television Logo
372 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
