Question about Toshiba 50HX81 50" Rear Projection Television
Coaxel and composite jacks produce scrambled picture, componite ok.
Have digital HD from cable co. works fine(componet)(2). Cannot use pip, or game systems because picture is no good from composite(3) and coaxle(2) connections. All seen are wavey lines with picture trying to straighten up screen that never does straighten. Can anyone tell me why I have this problem? Input looks like this- (1)antenna 0 n/g (2)video 1 n/g (3)video 2 n/g (4)video 3 n/g (5)HD strm 1 ok (6)HD strm 2 ok (7)antenna 1 n/g
    Genius:
  • 1,694 Answers
Bad hyper board = repair by qualified tech, PCB not available...
Posted on Nov 05, 2007
When i hook up my psp to the componet cable my picture is scrambled works fine on other tv
Your tv probably does not support the video file of the PSP. There are currently no solutions but maybe soon with an update
Apr 18, 2010 | Sony PlayStation Portable (PSP) Console
How can i connect my advent qrc430 to a hd television
There are two options available with this laptop. Unfortunatley you will not be able to produce a High Definition picture, but nether the less it is possible to connect it to a HD TV.
The connections available are;
1x VGA - You will need a VGA Cable (as long as your HD TV has a VGA/PC input) cheapest found on Ebay. There is also a VGA to HDMI cable. Still wont be HD but an alternative to think about.
1x S-Video (TV-Out) - You will need a S-Video Cable (make sure HD TV has this input) also cheapest on Ebay.
Both of these options do not produce audio through them so for this you will need a 3.5mm audio jack to 3.5mm audio jack. Plug one end into your earphone socket on your laptop and the other end into your HD TV PC Audio in socket/Audio in socket. If you have a Cinema/surround system you will need a 3.5mm audio jack to stereo phono, as long as the surround system has an audio input.
LINKS
VGA to HDMI cable: http://cgi.ebay.co.uk/1-8m-VGA-to-HDMI-Cable-Adapter-M-M-For-Laptop-PC-LCD-TV_W0QQitemZ350312945946QQcmdZViewItemQQptZUK_Computing_CablesConnectors_RL?hash=item519047591a
VGA to VGA: http://cgi.ebay.co.uk/5M-VGA-SVGA-15-PIN-CABLE-PC-TO-TFT-MONITOR-LCD-TV-LEAD_W0QQitemZ330370826650QQcmdZViewItemQQptZUK_Computing_CablesConnectors_RL?hash=item4ceba2c19a
S-VIDEO to S-VIDEO: http://cgi.ebay.co.uk/5m-S-Video-Svideo-SVHS-4-pin-Cable-Lead-Male-GOLD-16ft_W0QQitemZ360181396530QQcmdZViewItemQQptZUK_Computing_CablesConnectors_RL?hash=item53dc7bf432
3.5mm AUDIO to 3.5mm AUDIO: http://cgi.ebay.co.uk/1-8M-3-5mm-3-5-Jack-to-Jack-Audio-Cable-Lead-Wire-Gold_W0QQitemZ270522394462QQcmdZViewItemQQptZUK_Computing_CablesConnectors_RL?hash=item3efc64275e
3.5mm AUDIO to PHONO: http://cgi.ebay.co.uk/5M-3-5mm-to-2-RCA-Stereo-phono-Audio-Cable-for-iPod-Mp3_W0QQitemZ250574651547QQcmdZViewItemQQptZUK_Computing_CablesConnectors_RL?hash=item3a5769c09b
Hope this helps. If it does please leave a thumbs up....Thank you.
Feb 04, 2010 | Computers & Internet
When componet is hook up for hd
My first guess would be that the component connections are not matched. Check the component method and make sure that both the source and the TV are set the same. There are two methods:
1) RGB
2)Y,Pr,Pb
If the set is set for RGB and you are sending Y,Pr,Pb the picture will look a bit purple.
Dan
Jan 28, 2009 | RCA HD61W66 61" Projection HDTV
Audio works but the video is scrambled
I had this problem when I used my 360 on a new projector, its because the video setting on your 360 is set to 60Hz, and your display can only support 50Hz, you should still be able to see the picture enough to change the setting, but most games will now not work, so yu will really need to buy either;
- The VGA (like what PC'a use + audio) HD Cable
- The Component (a yellow, blue, green and red plug + audio) HD Cable
- The Advanced SCART Cable
or you can connect the standart composite cable (one yellow plug) to an RF modulator and use a coax (arial) connection, but this will give pretty dire quality.
Jan 02, 2009 | Microsoft Xbox 360 Console
When I want to watch something whether it be Cable, a movie, or video games the screen only stays clear for 4 seconds then it scrambles. Not only that, jumps from being scrambled to going to "no...
you have to go into the settings of the video card and change the "signal" from the one you are using now, this could be RGB, S-Video, Composite, Digital or Analogue, flick through these settings until you find the correct signal
kind regards
Nov 25, 2008 | Computers & Internet
DVD/VCR Combo
your model is "tuner free" that means it does not have the RF screw in connector. Buy one that has a tuner, preferably both ATSC(USA digital) and NTSC(USA analog)
Jul 17, 2008 | Philips Magnavox DVD/VCR Dual Player
Vizio VO32L & VO37L - PIP and Composite connection problems.
look in your owner's manual and you will see a list of input that can work with each other and ones that can't. If you don't have your service manual, you can go to vizio.com and get it there.
Jun 21, 2008 | Vizio L37 Television
Mitsubishi WD-52628 52" Inputs look like old cable scrambled channels
Change the 1000uf @16v capacitors on the FMT board that should solve your problem. You will most likely found that they have swelled. Let me know if you need further info.
Apr 04, 2008 | Mitsubishi WD-52628 52" Projection HDTV
No sound through ps3 hdmi
hi i had a problem, but had no pic, but did have sound, rang sony, and they said buy a new hd cable, went out and bought one, and it worked fine!!!
Jan 08, 2008 | LG 42LC2D 42 in. LCD HDTV
VCR DOES NOT WORK WITH NEW CABLE BOX
If you can get some of the stations without the box (often the case for those who subscribe to digital cable or movie channels), then one setup is to split the raw cable and feed the box and the TV, then have the box feed the VCR and hook up the VCR composite video and line level audio outputs to the TV. The VCR tuner would always be set to the VHF frequency your cable box RF output is on, usually ch. 2, 3 or 4. This setup allows PIP to work, with the TV tuner limited to unscrambled analog stations, and it also allows you to tape anything coming through the box, while watching unscrambled analog stations on the TV. However, it requires the VCR to be on and the TV set to the external video input to simply watch what is coming through the cable box. There are other ways to set this up with more flexibility using splitters and A/B switches, or you can look for a special switch box that handles the job. The above assumes your TV has composite video and line level audio inputs. The only way to have full flexibility to watch any scrambled or unscrambled station at the same time as taping a scrambled station is to have 2 cable boxes. The only way to have your VCR control the cable box and record different programs by switching the box by itself is to have a VCR with a cable box controller, also known as a cable "mouse". Hope this helps
Dec 15, 2005 | Quasar VHQ720 VHS VCR
Toshiba 50HX81 50" Rear Projection Television Logo
236 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
