Question about Sony Grand WEGA KDF-55XS955 55" Rear Projection HDTV
Replacing the projection lamp
I recently replaced my lamp in my T.V. do to a pre warning message appearing in my lower left side of the T.V. requesting that I replace the lamp as the life of the previous lamp was soon to expire. However, upon replacing my lamp the warning message has not gone away and I am seekink information on how to get the message to go away.
  • 51 Answers
Heres a link to the manual
http://esupport.sony.com/US/perl/model-documents.pl?mdl=KDF55WF655&LOC=3
I did not see s specific procedure for the lamp reset. General reset would be to hold reset amd press power while on. You might try that.
Posted on Dec 05, 2008
  • 2,326 Answers
Try resseting the lamp timer following the info below: Procedure for resetting the KDF42WE655, KDF50WE655, KDF55WF655, KDF55XS955, KDF60WF655 or KDF60XS955 lamp timer:
1. Press the JUMP button 3 times on the remote to get to the Panel OSD mode.
2. Next press the remote channel 2 button 9 times to get to the Lamp Timer mode.
3. Press the remote 3 button, mute, then enter to reset the timer to zero.
It will take 45-50 seconds for the timer to reset. After the timer is reset you can shut the TV off. The lamp timer will remain reset (no need to save).
How to reset the lamp meter on a panasonic pt-52lcx16
Panasonic Projection TV Lamp Timer Reset
Your lamp will probably last a lot longer than the TV thinks it should. This procedure will reset the lamp timer so you don't have to look at that annoying message every time you turn your tv on. Remember that the "lamp" indicator light on the lower left of the set will stay on until the lamp is actually replaced. I had to buy a replacement lamp to get this information, could not find it anywhere for these model numbers.
Press the volume down button on the projection display and hold down the zero button on the remote control at the same time for more than 5 seconds. When the reset procedure is complete, a message will display that the lamp timer was reset to zero.
This procedure will work for Panasonic models: PT-52LCX66 , PT-56LCX66 , PT-61LCX66 , PT-52LCX16 , PT-56LCX16 , PT-61LCX16
Jul 20, 2014 | Panasonic Pt-52lcx16-b Replacement Rear...
How to reset the meter on a panasonic pt-52lcx16
Panasonic Projection TV Lamp Timer Reset r
Warning message for lamp replacement appears at each power up!
After replacing the lamp, make sure the lamp cover is securely closed. Select the Lamp Replacement option in the menu, (MENU > Settings > Setup menu) and follow the on-screen procedure.
Apr 20, 2017 | Sony LMP-H130 Projector Lamp Projector...
TV has new lamp but no color
Tried putting the old lamp back?
Jun 14, 2012 | Sony KDF-37H1000
HD70 DLP Projector: after replacing bulb warning message of "replaceme...
You need to reset the light counter. Access through right most menu item. Then arrow down to lamp settings.
May 17, 2010 | Optoma HD70 DLP Projector
After just recently replacing the bulb I am
Here is proceudre to reset lamp timer in your TV..
While pressing the VOL Down button on the projection display, hold down the PIP or SPLIT button on the remote control at same time for more than 5 seconds.
When reset procedure is complete, the screen message ' lamp time was reset to 0' will appear.
Hope this info will help you.
Thanks.
Nov 18, 2009 | Panasonic TY-LA1000 Projector Lamp for...
Warning replace lamp
common problem with this tv. About $130 to replace lamp + service ask ahead for that cost. These lamps are available through the internet. Time left is usually 200-0 hrs after warning
Dec 29, 2008 | Sharp 56DR650 56" Rear Projection HDTV
Where is the lamp housing unit & how do I remove it?
The lamp is in the front of the TV. Pop off the gray cover, about the width of the screen, located just left of the power button. You will then see a bunch of warning labels on the left. Unscrew the one screw that is there and take that piece off. There's your lamp. Unscrew the screw on the right of the lamp and the lamp will slide out.
Nov 05, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Sony Grand WEGA KDF-55XS955 55" Rear Projection HDTV Logo
964 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
