Question about D-Link AirPlus DI-524 Wireless Router
Can't get wireless connection on new computer.
I have an old computer that connects (wireless) to the internet through my D1-524 router and modem. I got another computer, and I cannot get a wireless connection from the same location as the old computer. When I try to connect, it asks for a network key (either WRP or WEA, if I remember correctly). How do I get such a network key?
    Genius:
  • 1,061 Answers
You have enabled wep/wpa protection this is the password you need to enter.its the same as the working computerRICHARDM69
Posted on Dec 05, 2008
    Novelist:
  • 159 Answers
It's a DI-524 (Dee-eye). You created the network key, which is a fine thing. If you've lost track of it, you'll have to reset it to something else -- and then program both of your computers to connect with the new key.
You can probably get to the router here:
http://192.168.0.1
If you can log in, you can then click Wireless. Click WPA-PSK.
Pick a passphrase. You can use a sentence, even, something easy to remember, something easy to play with. Write it down and TAPE IT TO THE ROUTER, not over ventilation holes, so you never lose it again.
A good passphrase might be something that includes punctuation and isn't a common expression. You get 63 characters. Something like this might work, to give you an idea:
I hate that I lost the password, but life goes on.
Type it twice, carefully.
Then you'll have to tell both the previously working computer the password, as well as the new one.
And -write that down-. It's not the worst idea to put type everything useful (that http://192.168.0.1 address, your administration username and password, and your wireless password) into a Wordpad document, make the type very small, and print that, cut it out and tape it, being sure not to block any air holes.
I changed my internet modem and am not using the router I had been using. I have attempted to access Netflix and get error unable to connect to the internet.
Judit,
We need ore information. Does the new modem you are now using have a built in "router"? If not, you had better reinstall your old router as when you just use a plain old modem from either cable or dsl your computer will be visible to the "low life hackers" out in the internet and it will be so easy to gain access to your computer and files it will and should scare you! Are you now using a router with your new modem? IF NOT, reinstall your old router with your new modem! The reason your not getting Netflix could be that the port settings on your old router will not be the same as the modem and if your new modem does have a built in router, you will need to "reconfigure" your Netflix with the new modem/router. The ports that your old router allowed access to Netflix will not be the same in the new router. You need to set this up yourself. Good luck.
Mar 22, 2015 | Miscellaneous
Can you help me connect my Zonet Wireless AP Router ZSR2104WE now that I have purchased a new modem (Motorola DSL Modem 3360)?
You must hook these particular items up in a specific sequence. First power down both the modem and the router, only connect the modem to the isp until all appropriate lights on on. Next plug cat 5 to router where it is labeled internet or wan if neither label then to #1. until alights come up on router. Hope this helps.
Sep 06, 2012 | Zonet ZSR2104WE Wireless Router
I'm trying to connect a D-link DIR-615 router to my inlaws computer. They have an old motorola external modem which works fine, the new router is connected properly to the power suppy, ethernet cable from...
You haven't mentioned who is your Internet Service Provider (generally motorola modems are used by cable connections). After connecting the cables properly, you power cycle the modem and the router if this is a cable connection. However, if this is a DSL connection you better contact the ISP and fetch further information. Please contact me again if you need further information.
Apr 24, 2011 | D-Link DIR-615 Wireless Router
No internet connection when router is connected
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Apr 23, 2010 | Linksys Wireless-G Broadband Router
I have 2 desk top computers hooked up to one internet source and they are hooked up to a box which my old linksys router was hooked to. I now have a lynksys wireless router G. i unplugged the internet...
Are you trying to set up the router.
You can do it manually without the CD.
through the modem.
modem
Then you need to connect the computer to the
Click Here for step by step by instructions
Feb 11, 2010 | Linksys WRT54G2 Wireless Router
The wireless light is not illuminated and i can't get it to work??
This is a sign of an old router/modem. Also, try unplugging all of plugs that connect to the router/modem. Also, is this affecting you in connecting to the internet? if so, I recommend purchasing a new router/modem. They are very cheap now-a-days. :)
Matt P,
Computer/Gaming Relations Team.
Oct 22, 2009 | Netopia (3347NWG-VGX) Wireless Router...
Can I use old 2wire router to connect PC to new wireless router?
Hi, You can not use a router to connect a computer to another wireless router. You need to purchase a wireless adapter if you want to connect a computer wirelessly to the network. There seems no other way of doing this.
Let me know if you need any further help regarding this.
Regards
Anand
Aug 03, 2009 | Computers & Internet
Cannot get Internet connection with my new Linksys WRT310N wireless router
Power cycle modem and router. Check if getting wan ip address on router. I yes. Enter static DNS on router or on computer
Aug 19, 2008 | Linksys Computers & Internet
D-Link AirPlus DI-524 Wireless Router Logo
219 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
