Question about Gateway Projector 210 Multimedia Projector
Gate way 210 projector
I purchased used 210 to give to my parents for christmas it powers up fine but the image is all hazey and unreadable /also dosn't seem to be gatting signal from my laptop i have a infocus at home works fine
and the laptop installed hard ware seems to be working any helpwould be nice as i would like to make the christmas nice please help thank you!
  • 2,237 Answers
Needs cleaning. and the signal needs to match the source (laptop). go into the menu to adjust.
Posted on Aug 19, 2009
The projector keeps turning off the screen image but not powering down
The projector has a feature that keeps the screen dark when there is no slide in the projection gate. The light is blocked, but not turned off. There is a latch on the slide of the shutter that controls when it opens (slide in the gate) and when it remains closed (no slide in the gate). It sounds like the latch on the side of the dark shutter needs adjustment. Here is the website where you can get the adjustment procedure. http://www.kodak.com/eknec/PageQuerier.jhtml?pq-locale=en_US&pq-path=6499
Good Luck !!! Jim
Mar 11, 2014 | Office Equipment & Supplies
I have a Panasonic PT-LM2U; when it is turned on, everything powers up fine but the image projected is upside down. I've looked through the menu but didn't see an option for flipping or rotating...
Every modern projector that I have seen has a setting that will allow you to flip the image for this.If you purchased it used it was probably configured as a ceiling mount in an upside down orientation or rear projection onto a translucent screen. (The projection method can be set from the "OPTION2" menu. in a Model LM1 so it should be similar. http://service.us.panasonic.com/OPERMANPDF/PTLM1U.PDF
If yours doesn't have this option, then you'll have to use mounts that require the projector to be upside down.
Jul 18, 2011 | Panasonic PT-LM2U Multimedia Projector
Infocus DP8400x blue hazey line
this discoloration is the begining of the lcd panel being thermal damaged. this happens when the projector is being used for a long period of time and then being shut off using the switch on the rear of the projector instead of the on/off on top or the remote. to fix it it will have to be replaced. very expensive major repair.
Jul 11, 2010 | InFocus DP8400X LCD Projector
Optoma DV10 loud vibration and odd colours
check the colour glass wheel is shattered with a piece of glass still stack to the wheel. it not even thats why it vibrates
Aug 17, 2009 | Optoma MovieTime DV10 DLP Projector
I had taken some Halloween photos and when I went to go show them to my friend, it say "file contains no image data" so I've lost all my Halloween pictures, but all my other ones are still on...
Hello!!
Try opening those pics using memory card reader connecting to ur comp ... and try hard resetting once!!! Switch off ur camera , remove the batteries and press the power button for few seconds. then put the batteries back and try powering on!!
Nov 04, 2008 | Cameras
When trying to watch a film off the computer through the projector the colour red comes out green on the projector.
check your cable and use a different laptop or desktop to eliminate the projector. always do a factory reset.
Sep 08, 2008 | Mitsubishi SL4SU ColorView Multimedia...
Power problem
we were unable to pull the projector menu & it also took about 2 hours for the bulb to turn on.......the fan works, have changed the bulb, closed the bulb door & tried to reset the projector.......help!
Feb 24, 2008 | InFocus X1A Multimedia Projector
Green backround on the image
My projector is not a Hitachi but I think the menus are similar. You might try finding "signal" under "setup" in your menu and check to see if it is on or off. You want it "on". I hope this helps.
Jan 06, 2008 | Hitachi CP-S210 Multimedia Projector
Problem with a Gateway 210 DLP projector
The color wheel may not be turning. Remove the lamp and see if it will turn manually.
Aug 08, 2007 | Gateway Projector 210 Multimedia Projector
Gateway Projector 210 Multimedia Projector Logo
122 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
