Question about Lexmark X7170 All-In-One Scan/Copy/Fax and Photo Printer
X9575 fax & recieve phone calls
I saw your solution for the drpd for an x125
what would be the formula for a Lexmark x9575
to detect phone calls from fax signal?
    Genius:
  • 2,035 Answers
Yes most of the Lexmark printer work on the same formula ...
Good luck ....
Posted on Dec 07, 2008
MY LEXMARK X125 STOPPED RECIEVING AND SENDING FAXES. IT HAS ITS OWN LINE NOT CONNECTED TO COMPUTER. ALSO MY SPEAKER DIAL TONE IS NOT WORKING. WHEN CHECKING MY DRPD WONT SET UP EITHER. THIS JUST HAPPENED 2...
Hello. If everything else is working, printing and copying, unplug the printer from the power source. Check the telephone line from your phone company by unplugging the fax machine from the wall jack where it is connected to. Plug a telephone device straight to that wall jack and check for a dial tone. If there's no dial tone, contact your phone company. If there is, plug the fax machine back to that wall jack. You can also try replacing the telephone cable with a another known working cable. Plug the printer back to the power source. Check again. Hope this helps.
Mar 23, 2010 | Lexmark X125 All-In-One InkJet Printer
How do I use use a distinctive ring to separate the incoming fax from the incoming normal calls I want to direct to the answering machine. I am from S. Africa. I am using an all in one Samsung SCX-4521F. I...
Firstly, you will need to get a 2nd ringtone from your phone provider. Most of them will provide a designated "fax ring" (not a new number) for little or no cost.
In DRPD mode, you can receive a call using the Distinctive Ring Pattern Detection (DRPD) feature. “Distinctive Ring” is a telephone company service which enables a user to use a single telephone line to answer several different services.
Using the Distinctive Ring Pattern Detection feature, your fax machine can “learn” the ring pattern you designate to be answered by the fax machine. Unless you change it, this ringing pattern will continue to be recognized and answered as a fax call, and all other ringing patterns will be forwarded to the
extension telephone or answering machine plugged into the EXT. jack. You can easily suspend or change Distinctive Ring
Pattern Detection at any time.
Before using the Distinctive Ring Pattern Detection option, Distinctive Ring service must be installed on your telephone line by the telephone company. To set up Distinctive Ring Pattern Detection, you will need access to another telephone or someone available to dial your fax number from outside (a cell phone will do!).
To set up the DRPD mode:
1 Press Menu until “Fax Setup” appears on the top line of the display.
2 Press the scroll button ( or ) until you see “Receive Mode” on the bottom line and press Enter.
3 Press the scroll button ( or ) until you see “DRPD Mode” on the bottom line and press Enter.
4 When “Set” displays on the bottom line, press Enter.
“Waiting Ring” appears on the display.
5 Call your fax number from another telephone. It is not necessary to place the call from a fax machine.
6 When your machine begins to ring, do not answer the call.
The machine requires several rings to learn the pattern.
When the machine completes learning, the LCD displays “End DRPD Setup”.
If the DRPD setup fails, “DRPD Ring Error” appears. Press Enter when “DRPD Mode” displays and retry from step 3.
7 To return to Standby mode, press Stop/Clear.
When the DRPD feature is set up, the DRPD option is available in the Receive Mode menu.
To receive faxes in the DRPD mode,
you need to set the menu to DRPD;
NOTES:
• DRPD must be set up again if you re-assign your fax number, or connect the machine to another telephone line.
• After DRPD has been set up, call your fax number again to verify that the machine answers with a fax tone. Then have
a call placed to a different number assigned to that same line to be sure the call is forwarded to the extension telephone or answering machine plugged into the EXT. jack.
• In Tel mode, you can receive a fax by picking up the handset of the extension phone and then pressing the remote receive code Alternatively, you can press On Hook
Dial
(you can hear a fax tone from the remote machine) and then press Start on the control panel of your machine.
• In the Fax mode, the machine answers an
incoming call and immediately goes into fax
reception mode.
• In Ans/Fax mode, the answering machine answers an incoming call, and the caller can leave a message on the answering machine. If the fax machine senses a fax tone on the line, the call automatically switches to Fax mode.
• In DRPD mode, you can receive a call using the Distinctive Ring Pattern Detection (DRPD) feature. This option is available only when you set up the DRPD Mode.
The full user manual for your machine is located here
Hope that is of help to you :)
Nov 09, 2009 | Samsung SCX 4521F All-In-One Laser Printer
We used to have two phone lines in our home office one for the x125 fax and one for our home phone. We now only have one line and can't seem to figure out how to receive incoming faxes. Can you help?
Check your manual. I f you don't have it, download it form Lexmark
http://www.lexmark.com/publications/pdfs/x125/eng/enogwin.pdf
I think page 61 may be of use.
Aug 06, 2009 | Lexmark X125 All-In-One InkJet Printer
X9575 phone conflict
You may have wired your FAX and Phone up wrong. Go to the following website to view the Manual and try going to page 28 and try wiring it up again.
http://www.lexmark.com/publications/pdfs/2007/9500/winug/en/lxdouser.pdf
Thank you for using Fix Ya!
If you still have questions, let me know.
Don;t forget to rate the overall satisfaction of this solution.
Feb 19, 2009 | Lexmark X9575 InkJet Printer
How do i recieve faxes?
I am having the same problem with my Canon MX310. I think you have to set up a DRPD (distinctive ring), but I don't know how to do that. If I find out how to fix mine, I will come back to you and let you know
Jan 06, 2009 | Lexmark X125 All-In-One InkJet Printer
Phone line gets busy tone while recieving fax in DRPD mode
As I understand it, this is as it should be. You have two different numbers sharing the same physical line and only one can be active at any one time, so if you are using the phone and someone tries to fax, the fax line will be engaged and similarly, if you are sending a fax and someone tries to ring on your phone line, it will be engaged.
Nov 07, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Calls to my home is pickup by fax
Here is a link to a pdf file version of your instruction manual:
You will need a pdf reader like acrobat reader or foxit reader to be able to view this file.
You need to change the number of rings before the fax machine answers your phone in order for you to answer the phone first, if you don't use the fax part of your machine simply unplug it from the telephone socket.
Aug 28, 2008 | Lexmark X125 All-In-One InkJet Printer
All in one lexmark x125 printer
I have a similar model Is the auto answer button on?
If no then on the fax go on the menu (LCD) and keep selecting until you get to the setting and amount of rings in that menu there should be a option for AUTO off/on answer phone etc.
I hope this helps (please feel free to ask more or you can rate this review)
Thanks
Fax problem
I had the same problem! You have to set your fax machine option to DRPD mode. Menu, to Fax setup, to DRPD mode, press ENTER, ENTER again, it should say waiting ring, you then have to call your fax line. Back to Fax Setup, Recieve Mode, press DRPD mode. This way your machine well distinguish a different ring for your fax.
Dec 18, 2007 | Samsung SCX 4521F All-In-One Laser Printer
Lexmark x73
Yes you need to connect to computer to receive and send fax........ Telephone as to connected to dial up modem of the computer if you dont have dial up modem then the faxing wont work.........
About Distinctive Ring Pattern Detection (DRPD)
"Distinctive Ring" is a service provided by some telephone service providers. Two phone numbers are assigned to one phone line so that you will hear different ring patterns for incoming phone calls than for incoming faxes. If you subscribe to this service, follow the instructions below to program your All-In-One to use it.
On the X125:
Press Setup once, then press Menu nine (9) times until DRPD appears on the display.
On the X63:
  1. Press Setup once, then press Menu eight (8) times until DRPD appears on the display.
  2. Press Options until you see Learn, and then press Start/Yes.
  3. Dial the phone number that you want to use as a fax number. (Do this from a different phone line, not from the line the fax will be installed on.)
  4. Press Setup.
  5. Press Menu until you see Fax Receive Mode on the display.
  6. Press Options until you see DRPD, and then press Start/Yes. The All-In-One detects the ring pattern and answers all incoming faxes on the second ring.
Sep 20, 2007 | Lexmark X73 All-In-One InkJet Printer
Lexmark X7170 All-In-One Scan/Copy/Fax and Photo Printer Logo
54 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
