Question about Plumbing
Grohe LadyLux Cafe mdl # 33 758 single handle; w/pull out spray head - Hot & cold flow from faucet is minimal; at near by bar sink (same hot/cold feed) flow is fine. Suggests to me an obstruction in the cartridge/valve assembly. How do I take it apart and clean or clear the obstruction?? r/fmb
    Scholar:
  • 68 Answers
There is a flow restrictor in the faucet. You have a very common complaint for these faucets. The restrictor will be shown in the owners manual. Remove the restictor. If you don't have the owner manual, work cautiously and take notes/pictures.
Phil
Posted on Dec 09, 2008
I have Grohe Ladylux and the flow will arbitrarily switch from stream to spray on its own.
Mine would stick in the spray setting. I soaked the whole head in vinegar to clean it and the problem went away.
Oct 05, 2014 | Grohe Ladylux Cafe Faucet with PullOut...
How do you remove the supply line from the spray head?
The hose should simply unscrew from the back of the head.
Here is the page on the Grohe site:
http://www.grohe.com/us/15219/kitchen/kitchen-faucets/ladylux/product-details/?product=33755-G077&color=SDE&material=33755SD0&~[ajax]=33063
Jun 03, 2014 | Grohe Plumbing
Grohe ladylux cafe kitchen faucet: new item, the pull out spray piece does not set firmly into neck so that it falls out easily
check and see if the weight is on the hose going to the handle, also check to see if the hose is free to fall down and that it is not hanging up on piping down under the sink
Best of Luck
Richard
Sep 06, 2011 | Grohe Plumbing
Hot Water pressure is nearly non-existent. Cold is fine. This is not a problem of turning on the water below the sink. Water faucets coming from the house are both fully open,, both hot and cold. Nor...
It sounds like you may have an obstruction in the supply valve under the sink. Turn off water to house. Remove supply tube from valve. Unscrew the packing nut. This is the nut where the stem of the valve enters the body of the valve. Remove it and flush the line by having someone turn on the main while you hold a cup or small bucket over the valve to prevent water from going everywhere. Also check to make sure the washer has not come loose. If the washer shot out when you flushed the line, replace it. Be sure to check flow before reinstalling supply line.
Jul 08, 2017 | Grohe Ladylux Cafe Faucet with PullOut...
Water flow from grohe ladylux kitchen faucet has slowed down with time. What can or should I do to increase water flow?
If it has a removable aerator screen, remove it and clean it out. If it can't be removed, try soaking the entire head in white vinegar for a couple of hours. You should see a big improvement.
Jun 28, 2011 | Grohe Ladylux Cafe Faucet with PullOut...
We have a Grohe Lady Lux Plus kitchen faucet and the water flow is slow on both hot and cold sides. We took the faucet apart to see if there was trash impeding the flow and found nothing. We put the...
Take it back apart and check the placement of all the o-rings and or seals.
The low water pressure may be no more then the aerator being dirty where the water comes out of the spout.
Feb 05, 2011 | Grohe Ladylux Cafe Faucet with PullOut...
Developed hot running water all the time
If the problem is that there is not enough hot water coming out, or when you can not get the hot water to shut off you may need to replace the cartridge inside the faucet.
Jun 26, 2010 | Grohe Ladylux Cafe Faucet with PullOut...
I have a Grohe Ladylux plus kitchen faucet very similar to this one, when I turn the water on there is a slight clunk and the water flow decreases. I am assuming I need a new valve but I havent' been able...
Before you start taking the whole faucet apart try taking the airiator or head of the end of the faucet. It may just be some sediment blocking the filter screen on the head. Unscrew the head and see if the water flows with the head off.
Jun 12, 2010 | Grohe Ladylux Cafe Faucet with PullOut...
Grohe ladylux cafe faucet has low flow eventhough supply valves are wide open. This is true for both hot and cold. When supply is disconected from faucet and valve turned on there is ample pressure. Is...
I have the same problem and have the fix. There is a water pressure regulator on the bottom of the faucet( under the sink) this part is bad. Grohe will replace it for free. Call Grohe at630=582=7722 tell them the model # of the faucet and the color of the regulator, they will send you a new one for FREE.
Jun 09, 2010 | Grohe Ladylux Cafe Faucet with PullOut...
Plumbing Logo
677 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
