Question about HP Pavilion dv9000z Notebook
Pavilion PC Notebook Verve dv2000 Microphone
Hi: I plugged in a vocal microphone to the port on the front of the pc and it won't work. Do I have to do anything special to make it work? Thanks! I have a HP DV9000 the external mic jack did work in the settings it showed as sum now sum does not show only the built in mic I have rolled back - that didnt work - then I reinstalled - that didnt work I am trying to record from an old tape casstte
  • 88 Answers
You need to update your driver.just go to your control panel click on performance and maintainance,then click on device manager and if any device has a ? next to it double click on that device and windows will open a window and ask you what you want to do ,just click either install driver or update driver,this should do the trick.
Posted on Dec 05, 2008
How to enable built-in microphone in HP Pavilion dv2000
You may need to reinstall the driver for the device, open the Device Manager to verify your Audio Adapter. You can find the drivers for your machine here, select your OS: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&lc=en&dlc=en&product=1817074
Apr 04, 2013 | HP Pavilion dv2000t 14.1" Notebook Laptop...
How do i turn my lap top microphone on or do i need to plug one in regards mike
Hi Mike,
The spec say it has a built-in microphone. If you are using Windows, open the sound controller and check that the slider on the microphone is turned at least half-way up. When you open the sound controller (speaker in the systray next to clock), the microphone is normally muted. To test, unmute and tap the microphone or speak into it. Make sure you have the volume turned up on the speakers too.
The dv1000 notebook is equipped with:
  • 1 Type I/II PCMCIA card slot. I store my Media Remote control. (left side)
  • 1 IEEE-1394(Firewire) (right side)
  • 3 Universal Serial Bus (USB 2.0) (Two on the right side and one on the left)
  • 1 Built in 6-in-1 digital media reader (No Compact Flash)(Right Side)
  • 2 headphone-out (front)
  • 1 microphone-in (front)
  • 1 TV-Out (S-video) (right side)
  • 1 RJ-11 (modem) (left side)
  • 1 RJ -45 (LAN) (left side)
  • 1 External VGA monitor port (left side)
  • 1 expansion port for use with HP Expansion Base(sold separately). Available only with Intel Extreme graphics with productivity port (left side)
  • Power jack (in the back)
  • CD/DVD drive (right side)
Jun 01, 2011 | HP Pavilion dv1000 Notebook
Is there an internal microphone and if so where is it located trying to record myself i have a compaq presario 2200
Hi, the HP Compaq Presario 2200 PC has no built in or internal microphone. You will have to purchase an external one to record audio. The microphone jack, when viewing the laptop from the front, is located on the left side.
There are small round holes which are jack ports. From the front to the back, the microphone port to plug in a microphone is the second hole back. Here is a manual in case you need more help with your laptop: Click Here.
Hope this helps. If it does, please accept and rate the solution! Contact me with any more questions you may have. Thanks for using FixYa!
May 22, 2011 | HP Compaq Presario 2200 Notebook
Microphone is not working
plug microphone into port (ear and microphone)should see a pop on screen, go into control panel add and remove hardware
device manager, look for any yellow ?, right click on yellow ?
update driver,
Aug 16, 2010 | HP Pavilion dv1000 Notebook
Did the fix, now microphone doesn't work
please check the button on and appiy microphone cable plug
otherys services his microphone and so.
Sep 14, 2009 | HP Pavilion dv1000 Notebook
Thinking about purchasing a HP loading dock HP DV2000(ES631AA)
Compatibility document.write(neg_specification_newline('HP Pavilion dv2000, dv6000, dv9000; Presario V3000, V6000 series; compatible (reduced functionality) with Pavilion ze2000, dv1000, dv4000, dv5000, dv8000; Presario M2000, V2000, V4000, V5000; HP Special Edition L2000 series using included expansion base adapter
Note: When using a notebook that requires the included Expansion Accessory Adapter, the following functions will not be supported on the HP Notebook QuickDock: VGA port functionality, stereo microphone (only mono is supported) and power button (must use the notebook power button).')); HP Pavilion dv2000, dv6000, dv9000; Presario V3000, V6000 series; compatible (reduced functionality) with Pavilion ze2000, dv1000, dv4000, dv5000, dv8000; Presario M2000, V2000, V4000, V5000; HP Special Edition L2000 series using included expansion base adapter
Apr 18, 2009 | HP Computers & Internet
Microphone
i think you would need a seperate mic for that laptop.
Feb 25, 2009 | HP Pavilion ze2000 Notebook
Bock Band will not play without microphone
I have this problem too, anyone have a solution yet?
Jan 01, 2009 | Sony Playstation 3 (PS3) Console
yaa you have to set your microphone valume but first check if you are getting right connection.
In front panel jac there are three Jacks
  • The Left on is for microphone, i.e. you should insert the microphone node in it.
  • The second 2 jacks are for speakers you can insert speaker node in any one or both.
Try this I think it will work, otherwise ask me and let me know whats going on.
Gud Luck
Iqbal
Apr 16, 2008 | HP Pavilion dv4000 Notebook
HP Pavilion dv9000z Notebook Logo
347 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
