Question about HP OfficeJet V40 All-In-One InkJet Printer
I just installed a new black ink. The error message keeps on saying wrong color cartridge installed. I replaced with the correct one for my officejet v40. Black 15.
  • triskora Dec 08, 2008
    I have the same problem. Did you resolve it yet?
  • Frank
    Frank May 11, 2010
    exchange the ink cartridge postion.
    you may have it in th ewrong position.
  • 28 Answers
Did you try changing the color cartridge too? I had problems with ink cartridges that were not HP cartridges.( not made by HP but some other co.)
Posted on Dec 09, 2008
4110 officejet series all-in-one error message saying i installed incorrect ink cartridge? what do i do? it is the correct one
Supported HP Inkjet cartridge part numbers The HP Officejet 4100 all-in-one series products use the ink cartridges listed in the table below. HP Inkjet cartridges HP 56 black cartridge (19 ml) HP 57 tri-color cartridge (17 ml) HP 28 tri-color cartridge (8 ml) Replacing the ink cartridgesThe power must be turned ON to the all-in-one or the print carriage will not move to the right.
  1. Locate and open the print cartridge access door on the right side of the all-in-one. The print cartridge carriage will move to the right for access. Figure 1: Opening the HP Officejet 4100 seriesc00121089.jpg
  2. Press down gently on the top of the old ink cartridge to release it from the print carriage. Figure 2: Removing an ink cartridgec00121090.jpg
  3. Remove the new print cartridge from its packaging and remove the protective tape from the cartridge as shown in Figure 3. Do not touch the gold-colored contacts. Figure 3: Removing the cartridge tapec00121091.jpg
  4. Holding the ink cartridge with the printed label up, slide the cartridges one at a time into the print carriage and press them into position as shown in Figure 4. If the cartridge does not snap easily into position, it is not aligned correctly. Remove the cartridge and reposition it. Do not try to force the cartridge into position. The black ink cartridge (HP #56) goes on the right side and the color cartridge (HP #57 or HP #28) goes on the left side. Close the ink cartridge access door when the ink cartridge has been installed. Figure 4: Installing the ink cartridgesc00121092.jpg
  5. A message will appear on the front panel requesting that the ink cartridges be aligned. Follow the steps below to align the ink cartridges:
    1. Press Enter on the all-in-one front panel to start the ink cartridge alignment process.
    2. After the Alignment page prints, place the page into the ADF upside down and with the printed side down as is shown in Figure 5.
    3. Press Enter. The all-in-one will scan the alignment page and finish aligning the cartridges.
    Figure 5: Aligning the ink cartridgesc00121093.jpg
Correcting error messages that appear after changing a cartridgeAfter inserting the cartridge, the Check Print Cartridge light flashes or one of the following messages appears on the computer monitor:
  • Check the black (or color) cartridge
  • Replace the black (or color) cartridge
  • The wrong black (or color) cartridge is installed
These messages indicate that the ink cartridge is not making good electrical contact, is bad, or is the wrong cartridge. Complete the following steps to diagnose and correct the condition:
  1. Open the front of the unit to access the print cartridges (as shown in Figure 1).
  2. Remove the ink cartridge and inspect it.
  3. Verify that it is the correct part number and if it is, reinsert it.
  4. Close the lid to see if the problem is corrected.
  5. If the message is still displayed after a few seconds, remove the ink cartridge again.
  6. Unplug the power cord from the back of the unit.
  7. Clean the electrical contacts on the ink cartridge with a soft clean cloth slightly dampened (not wet) with clean water. (See Figure 6) Each contact is very small and shaped like a rounded square. Figure 6: Cleaning the cartridge contactsc00121094.jpg
  8. Allow the ink cartridge to dry for a few minutes before reinserting the cartridge(s) and turning on the printer.
  9. If the problem remains, replace the ink cartridge.
  10. If the problem still exists after trying all of the steps above, the unit may need to be serviced. Contact HP for further troubleshooting or to arrange to have the unit serviced.
Make sure what ur using isn't a refilled cartridge and if it is check the expiration date, if nothing is wrong then you need to get urself a new printer or an upgrade so call up hp at 1800-474-6836 and get help of them,they'll guide you to a new /upgrade printer.
it's not a nice way of saying it but someone has to give you the bad news
Feb 01, 2010 | HP Office Equipment & Supplies
I have an hp officejet 7110 all-in-one and I've been getting a message saying that supply expired on the black cartridge. i replace it and it still won't let me print. what else could be wrong
Hello there:
This problem is usually due to a print head that needs to be replaced
I have provided the information that you will need ok
best regards mike
This document provides information on how to replace a printhead or ink cartridge.A printhead may need replacing when print quality issues cannot be resolved by cleaning the printheads or a front-panel display message indicates a printhead needs to be replaced.An ink cartridge needs replacing when a front-panel display message indicates either:
  • Low ink levels
  • Ink cartridge approaching expiration date
CAUTION: Never remove an ink cartridge and a printhead at the same time. Use the table below to identify the correct ink cartridge part number: Ink cartridge Part number HP 14 black print cartridge C5011A HP 14 tri-color print cartridge C5010A Use the table below to identify the correct printhead part number: Printhead Part number HP 14 black printhead C4920A HP 14 cyan printhead C4921A HP 14 magenta printhead C4922A HP 14 yellow printhead C4923A Replacing the ink cartridges Follow the instructions below to replace the ink cartridges:
  1. Turn on the unit, and open the print-carriage access door by lifting the handle until the door locks into place. Figure 1: Opening the access doorc00064456.jpg
  2. The print carriage will move to the center of the unit.After the print carriage stops, remove the ink cartridge by pressing the gray release button, then lifting the cartridge up and out of its slot. Figure 2: Removing the ink cartridgec00064457.jpg
  3. Remove the new ink cartridge from its packaging and, being careful to touch only the black plastic, remove the tape. Figure 3: Removing the tapec00064458.jpg
  4. With the ink cartridge label face-up, push the new ink cartridge firmly down into the appropriate slot until it clicks into place.The color ink cartridge inserts into the right-hand slot as indicated by the rainbow colored oval. Figure 4: Inserting the new cartridgec00064459.jpg
  5. Close the print carriage access door. CAUTION: If the ink cartridge is removed before a replacement is available, close the print carriage access door and replace the ink cartridge within 24 hours.
Identifying parts of the printheads Use the table below to identify the parts:
  1. Printhead handle
  2. Printhead tower
  3. Copper contacts
  4. Plastic tape
  5. Ink nozzles
c00064460.jpg Do not touch:
  • Copper contacts
  • Ink nozzles
  • Printhead tower
Jan 24, 2010 | HP OfficeJet 7110 All-In-One Thermal...
Installed a black ink cartridge and the printer shows the message 'black cartridge missing' and also says 'cartridge error: error 50c'
Hi there Error 50c
Can only gave it a try.
Regarding the Dell A940 "Error 50c"....the user guide doesn't seem to mention "Error 50c". They do, however, mention a "Cartridge Error" on page 52 of the manual. They claim this means that the printer has detected a short circuit (fuse/resister) in the cartridge. As you may or may not have noticed in the manual, this is what they recommend doing about it:
1) Press Power to turn the printer off.
2) Lift the printer cover/lid (scanner unit) until the scanner support holds it open.
3) Turn the printer on.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
4) Remove the color ink cartridge.
5) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the black cartridge with a new black cartridge.
If the error message does not display, repeat steps 1–3 and then go to step 6.
6) Reinstall the color cartridge and remove the black ink cartridge.
7) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the color cartridge with a new
color cartridge.
If there is no error message (indicated by flashing lights), repeat steps 1–3 and then reinstall both ink cartridges.
8) Lower the printer (scanner unit) until it is completely closed.
If you get the error message again, while both cartridges are installed, replace both of the cartridges.
Basically, what they want you to determine is,....if the short circuit is with the "black ink" cartridge or the "color ink" cartridge and then replace the cartridge that has the problem.
You may have to buy a new cartrige.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Nov 06, 2009 | Dell A940 All-In-One InkJet Printer
Changed ink cartridge now it won't work
Try removing the black and see if the error is still there. If it goes away the black is bad, if it stays you got a defective new color cartridge.
Jul 01, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Cartridge Error, Error 50C
Hi there Error 50c
Dell gets this lots so have a try.
color cartridge.
Mar 02, 2009 | Dell A940 All-In-One InkJet Printer
Problem of incompatible cartridge occure in my new J 4580
i had the same problem with the hp 4580. i needed to replace the black ink which i did. then the error message appeared "incompatible print cartridge tri color"...chatted with hp customer support, wasted a hour. claimed its a hardware problem need to have it fixed. i asked would i be charge he said yes but the printer was under warranty. he asked other questions...bottom line i left the chat box....bought another hp 4580, used same cartridges, same message...THEN finally i replaced the color cartridge...and BAM! it worked on both printers. solution...replace the color cartridge...cons..if this happens again its a waste of money to keep buying the colored ink...
Feb 03, 2009 | HP J4680 Office Jet All-In-One Printer
HP Officejet T45 keeps telling me I have the wrong Ink Cartridge
Clean the cartridge contacts and the printer contacts as shown here.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Jan 17, 2009 | HP OfficeJet t45 All-In-One InkJet Printer
Error inkcartridge
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200
Nov 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Cartridge problems
Ref: our live chat - Definitely worth replacing the colour one with a new one - some other people had identical problem and that cured it - they really don't survive not being used very well. :)
Apr 21, 2007 | HP OfficeJet k60 All-In-One InkJet Printer
HP OfficeJet V40 All-In-One InkJet Printer Logo
217 people viewed this question
Seeker5211
Seeker5211
