Question about Kenmore 15864/15862 Top Load Washer
Washer will not agitate
Washer does not agitate. If fills,draines,everything but agitates.Also if you push down & hold it on the top of the agitator,it will work.Please help?Washer ia a GE top load, don't know model. Also can not get agitator off.Thanks for your help. Ivy
  • 1 more comment
  • textornado Jun 09, 2008
    top loader hot point washer will not agitate. Everything works fine except it will not agitate. How do I remove the agitator from this machine?
  • Anonymous Mar 22, 2014
    model LXR9445JQ1 lower part of agitator will not move.I can hand turn the top portion to the right. how can I remove the agitator to check the problem.
    please help the start button to work thank you
  • 641 Answers
A wears out clutch might prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. Good luck!
Posted on Aug 06, 2007
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
I have a GE washer model # WHDRR418GWW. It is about 19 months old. It stopped agitating and spinning. It will fill with water and the timer/knob will go thru the cycles. But when it reaches the washing...
You have what is called "agitating dogs" there are usually 4 of them at the bottom of the agitator. They have small grippers which lock onto the agitator and agitates. If the washer is ever overfilled or over time filled to heavy this will wear down the nylon teeth on the "dogs". The top of the agitator will spin off, you will see a bolt inside at the bottom, remove bolt and the agitator will pull out. Google "agitating dogs on washer. It will give you pictures for a better understanding. If the belt was broken the washer would not drain, because the belt turns the pump. These dogs are about $5 and honestly easy to install. Good Luck.
Dec 04, 2010 | GE WHDRR418GWW 35 cu. ft. Washer
GE Washer WJSR2080V3WW will fill, spin and drain but not agitate.
The problem is the agitator coupler (about $ 7.00) simply pull straight up on the agitator - Give it a good tug. take the one bolt holding the coupler off - pull straight off. Replace the coupler and bolt (they are sold together). Line the agitator lines up with the coupler lines - when they line up it should go all the way down and snap back into place. and your done.
Sep 01, 2009 | GE WJSR2080V
Whirpool washer wont work
The lid switch, get something to hold it down to make machine work. Turn machine on and push down on lid.
Jul 26, 2009 | Whirlpool CAM2752KQ Top Load Washer
Will not agitate 110 92587210 Kenmore Washer
I have 2 words for you: "dog ears".
the dog aggitation ears are what cause the aggitator to aggitate. Those things wear down and not grab after time.
Pretty easy to change out. You just need to pull the aggitator out and change the 4 little plastic ears. Good luck :)
Jul 13, 2009 | Kenmore 24032\24036 Top Load Washer
Ge whdsr315 top load washer will spin but not agitate unless pushing down on agitator
Sounds like the nut that holds the agitator on to the shaft is not tightend down or the agitator is not fully "locked" into place on the shaft.
Jun 16, 2009 | General Electric WHDSR316G Top Load Washer
Fills, does not agitate, drains, spins, fills, does not agitate, drains, spins
grab the agitator at the base and give it a quick push upward..remove and see if the white dome with bolt holding it down is stripped on the inside where it splines onto the transmission shaft. :)
Jun 13, 2009 | Hotpoint VBXR1090D Top Load Washer
Washer fills but will not spin or agitate? 1 year
Check waste hose not pushed to far down tube.This would cause same problem
Jun 11, 2009 | Washing Machines
Maytag washer, model: LAT8415AAE top loader. Washer fills with water but will not start agitating,spin or drain.
Check lid switch. Most will not run with lid open and the switch may not be pressed down when door is closed
May 17, 2009 | Washing Machines
Ge top loader washer agitator does not work
To check the agitator. Start the washer into wash cycle. Once started Push down on top of agitator. If it catches some times or all of the time when pushing down, then then doggets are worn, under the agitator. You`ll have to remove the agitator to see these. If by pushing down on the agitator, nothing changes, Then you probably have a transmition problem. Check this and let me know what you find.
Nov 27, 2008 | Kenmore 22422 Top Load Washer
Kenmore 15864/15862 Top Load Washer Logo
539 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
