I have a freecom 400gb external hard drive plugged in to my usb 2.0 port when i turn it on i get a message saying it will perform faster if its plugged into a usb 2.0 port any ideas
  • driller2000 Dec 05, 2008
    thing is all other usb 2.0 appliances work ok in that socket i think the problem occured after i installed service pack 3 on pc
  • 519 Answers
This means that although your hard drive is capable of handling usb 2.0 speeds, your PC has the older USB ports or if your PC has USB 2.0 ports, you don't have USB 2.0 drivers installed. You will most likely find USB 2.0 drivers from your motherboard manufacturers website.
Posted on Dec 05, 2008
Freecom usb port broken away from circuit board inside enclosure
It is hard to buy replacement for the same enclosure, but there are many USB2.0/3.0 enclosures available on the market for 2.5 and 3.5 inch drives.
Make sure read reviews for issues and performance on those enclosures.
Apr 10, 2014 | Freecom Xs External Usb Hard Drive 2tb
The SimpleTech 160GB ext. drive has a usb 2.0 cable with a y plug. I can only plug in one but I use the additional power supply. I get a message at times telling me to use the usb 2.0 port for faster...
You are using the correct connection, the external power supply is powering the drive, so the USB cable is just handling data. I believe the message may be telling you that you will get faster performance using a USB 2.0 connection, it is probably sensing that your computer's USB port is USB 1.1.
Feb 24, 2011 | SimpleTech Signature Mini 160GB External...
Windows 7 64bit with support for USB 2: when I plug my pendrive in a USB port, there's an advice saying that if I plug it into a USB 2 port, it will perform faster. But how do I know which port is USB 1...
I hate this message.
You can use a program like PC Wizard from CPUID that will tell you what all of you pc specs are.
From your specs you may not have usb 2 ports.
Device manager should also say what usb ports you have.
The best ports to use are the ports on the rear of the computer, front usb ports sometimes dont have as much power to drive external hard drives or high drain devices
Jul 10, 2010 | Linare Desktop, AMD Sempron 2200,40 GB HDD...
I have an external freecom 400gb hard drive
The chances are that you would have burnt the Power IC's, so there might not be any damage to the Hard Disk itself. you culd try buying a cheap External Enclosure at the closest IT store or moun the Hard drive on to a desktop computer. you should be able to retrive the data.
Mar 25, 2010 | Computers & Internet
USB's slow and external drive
For the USB ports, you may want to verify that the drivers for the "enhanced USB" are up to date and for USB 2.0 or 1.1. USB 2.0 ports are generally backwards compatible for 1.1 devices. The "enhanced" does indicate USB 2.0 controller. 30mins to backup 3GB to your external drive is a VERY long time. USB 2.0 transfers data up to 480mbps, but if you get an error message indicating that the device can perform faster on a 2.0 port, you maybe transferring data at 12mbps which is USB 1.1 speed
To speed up the transferring of data, identify which USB contoller in Device Manager is the USB port you're having a problem with, and delete it from Device Manager. Then, plug in your external drive into a USB port its never used before.
As for the naming of hard drives, Hitachi partners with several drive manufacturers including Dell and IBM.
Feb 22, 2010 | Philips Computers & Internet
Freecom Hardrive "Malfunction"
Not necessarily your information (data) was lost. The freecom hard drive might have some problems installing itself or some connection issues. I would take it to a data recovery technician. Of course there is always a 50 50 chance that you lost it or not. Wish you the best, Good luck
Dec 31, 2009 | Computers & Internet
Freecom 400gb not being detected
you may need to format it via Computer Management->Disk Management if there is nothing in it.
Apr 17, 2009 | Freecom (24358) 160 GB Network Hard Drive
Freecom 400GB Hard drive not recognized.its a Freecom mobile drive xxs 400gb , my pc just cant recgnize the hard drive
I'll assume your using Windows.
I'll assume it's a USB drive.
I'll assume it is an external drive.
And I'll assume it's formatted as NTFS.
Try using the USB (or FireWire) port for anouther drive to see if that is the problem, if it is then reinstall the driver for the port, through the Computer Managment Concole (assuming yur using windows).
If you formatted the drive as FAT, re-format it as NTFS.
Jan 02, 2009 | Computers & Internet
Freecom 400gb Drive
Have you tried to connect those drive individually and checked if they get detected when stand-alone? If they get detected stand-alone, install the Freedom software happen. Cheers
May 23, 2007 | Freecom (24358) 160 GB Network Hard Drive
Computers & Internet Logo
133 people viewed this question
David Payne
David Payne
