Back to:
Tags:
Optiquest Q 71  17 in.CRT Conventional Monitor
Display Problems - Static-like flickering with...
posted by Hags888 on Feb 11, 2007
Recently the image display on my Optiquest monitor started having problems. I have no idea what the issue is, and the visual problem is difficult to put into words. Basically the image quality when down the drain and it is having trouble displaying the colors properly. It's almost as if the image is all static-y with these weird points of light all over the screen, especially surrounding text.
The problem just started happening on its own. I didn't change any of the display settings. I have tried the following things to fix it and nothing has worked:
-Updating graphics card driver
-Restarting/Unplugging computer
-Unplugging/cleaning monitor connection to computer
-Leaving the monitor off for several days
-Changing the display settings manually
Any ideas? Do I need to contact the manufacturer and get it repaired?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Feb 12, 2007
Thanks for Trying (70)
bob_rinker
Rank:Guide Guide
Rating: 76%, 8 votes
It didn't get moved closer to something else that could generate an electro-magnetic field, did it?
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Display Problems - Static-like flickering with color problems and "sparkly" display:
I don't want to Accept this solution
Can you Help with these Monitors problems?
Monitors
I am trying follow the steps below, I can't turn the...
Monitors
I took my car in for an oil change about five weeks ago...
Monitors
hello sir I have purchased a samsung monitor last year.but...
Optiquest Q 71 (White) 17 in.CRT...
I have upgraded a W95 station to W98 but it stubbornly...
My Optiquest flat panel 17" monitor became black...
Loading problems.
Repair Service
Find Monitor Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
