Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Oven does not heat although display says it does
I have Frigidaire Oven with electronic controls. The top works great but the oven itself does not heat at all although the display shows that the heating element should be on.
I opened rear panel and measured the connection with multimeter between L1 and:
L2IN ~ 220VAC
L2OUT ~ 0V
Is there a relay which is probably stuck open between these two wires?
Which relay is it?
It seems that the two boards and display are soldered together and have to be removed separatelly?
  • python01 Dec 07, 2008
    I actually did manage to take the control board apart and changed the relay and everything works now. The L2Out line actually shows 220VAC when the relay is closed.
    I would be interested in buying faulty control boards for frigidaire stoves so if you have one sitting around let me know at
  • 41 Answers
Relays K5 and/or K6 are soldered on the board, but  can be desoldered and replaced with PB1185-ND. They are $4.22 each at The leads are a bit fat, so the through-holes have to be enlarged, and the leads have to be bent a bit.
Posted on Mar 20, 2009
  • Frigidaire Master
  • 2,651 Answers
The L2 out give 110v after the bake relay has closed, carefully remove the wire from L2 out and select bake, you should hear the click and the n you will get the 110v, if not you have a bad erc, the relays are not replaceable
Posted on Dec 06, 2008
Oven is not working its 5 years frigdare electronic elements are ok
Try setting clock before presuming board is faulty, ovens shouldn't work if clock is flashing or timer is counting down or bell symbol flashing. Consult your instructions
warmest regards
Richard The Repairman
Mar 29, 2014 | Frigidaire FEB30S5D Electric Single Oven
We have a frigidaire self cleaning oven . It made a bang and now there there is no power to my oven. Clock does not work , Burners on stove still work.
According to your symptoms, it appears that you will need a new electronic oven control board. If nothing on the range heats, you could have a tripped breaker on the 120 volt L2 leg of 240 volt power. This would prevent the cook top burners and the oven elements from heating.
Jan 21, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
Everything works fine except it does not heat up at all. Convection fan, Oven lights, Control panel all work an act as expected. I tested the Temp probe at 2K ohm an got 1.066. any help would be great. Is...
Hello there:
Here are two instances of when food "bakes poorly:" or not at all When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out. You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results. If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component. When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly. If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective. Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details. Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat. If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
Nov 20, 2010 | Frigidaire PLEB30S9DC Electric Single Oven
Heating element in Frigidaire range, model number FEFL64FSD.
Either the bake element is bad or the clock / control is bad. Element can be tested with an ohms meter
Sep 29, 2017 | Ovens
Oven not working
It sounds like the element/s have blown, especially if the fan is still working o/k.
You cannot always tell by looking at them if they are faulty or not.
Only way to be sure is to test them with a meter.
Hope this helps.
Please rate my solution.
Jan 18, 2010 | Frigidaire Ovens
OVEN CFEF372BC3 electric control panel not working
Look on the control board for fuses. Some fuses don't look like a standard replaceable fuse in a fuse holder. Some are soldered to the control board itself.
Jun 17, 2017 | Frigidaire 30" Self-Cleaning Freestanding...
You probably have a faulty element if it is a fan oven
Nov 18, 2008 | Frigidaire FEB27S5A Electric Single Oven
Frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work
my frigidaire oven will not light. The broiler works and the oven ingiter lights up, but the oven will not ingite. The electronic display does work.
Aug 25, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Electric wall oven will not heat up
This is ovenmad from the previous post. I had a repair guy come out and he found the problem to be the Safety Thermostat. When tripped, this allows everything to work on the oven except the elements. He did not have the part with him so will return in 6 days to replace it. That should solve the problem. No idea why it tripped. The safety thermostat is located on the rear of the oven so we will have to pull out the oven to replace the thermostat. Again, this was a Frigidaire Single Electric Wall Oven made in 2004. Hope this helps somebody else.
Dec 22, 2007 | Frigidaire FEB27S5A Electric Single Oven
Oven seems to be going crazy
You may have a problem with the keypad. I suggest that you review my solution at the following link:
I have shared this with over 1470 folks and most report success.
If it works for you please let me know at the following site:
Good Luck
Dec 13, 2007 | GE Profile JKP18 Electric Single Oven
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
264 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
