Question about Magellan RoadMate 700 GPS Receiver
Loose contacts on cradle
No voice except when I press together the cradle and the unit. Anyone else have this problem? Thanks, edgellw
  • edgell farmer Feb 25, 2007
    I have squeezed the cradle and the unit together, compressed tightly and twisted wires around both with needle nose pliers. crude but effective.
    When I remove the wires, she quits speaking again.
    I tried cleaning the sound knob with solvent but only fix is with the wires.
    edgellw
  • Anonymous Nov 05, 2007
    There is a solution to the cradle/unit power loss. After shaking the unit while driving the cradle does not sit tight anymore on the unit. Take small strips of electric tape, one piece of tape for the top "nose of the cradle and app. 3 small strips of electric tape to the bottom indent, where the spring-loaded lock snaps in. Thta will provide a tighter seat for the cradle and pulls the cradle closer to the unit, hence keeping the power connection intact.
    Try that befopre spending $ 30.00 for a new cradle...
    Novelist:
    Scholar:
  • 86 Answers
Edgellw.. your U6 IC may be loose... (what's that?) on the back of your I/O board (board that power connects to) there are three small chips that more then likely are rubbing against the housing . The location of these three chips should be pretty apparent when you've taken the I/O card out. there are.. some 7-8 screws you'll need to take out to remove the board. BE GROUNDED when you do this please.. otherwise this could be the least of your problems. You say that when you squeeze the unit together is works.. so that makes me think that the IC chip I'm talking about is just loose and not completely off yet. So, if you can find the IC I'm talking about, then attempt to put some solder on there .. or get someone else to do it. If you have trouble finding the IC then let me know and I'll try to explain further. -Daniel
Posted on Apr 29, 2007
SOURCE:
Nuvi 3790 has no sound when on cradle
Mine had the same issue but could not find any gel; even bought a new dock but no luck.
Apr 11, 2012 | Garmin Nuvi 3790T 44 in Car GPS Receiver
Machine won't turn on
Place it in the cradle, making sure the brass contacts on the bottom of the unit are in contact with the brass contacts on the cradle (it is possible to securely seat the unit in the cradle without this happening). Make sure you've got power to the unit and it should turn on. If not, pull the faceplate and press the reset button. If it turns on, update your software. If it doesn't turn on it might be broken.
Mar 29, 2010 | Garmin StreetPilot C330 GPS Receiver
Remote is not recharging when placed in cradle even after cleaning posts with alcohol.
Generally there are three possibilities (apart from the battery going bad) that can cause your battery not to charge:
1) Some folks have reported that the battery is not sitting tightly enough in the battery compartment. You can try folding a small piece of thin cardboard and place it between the battery and the back of the compartment. This will push the battery towards the front of the compartment and create a tighter connection against the contacts.
2) There have been reports of problems with some of the charging cradles in which the remote does not make sufficient contact with the contacts in the cradle. To ensure that the remote begins to charge, place it in the cradle and listen for a single beep. The slide show should start and then, after a few moments the screen should darken. If you hear two beeps at any time, it means that the remote has lost contact with the charging cradle and has 'woken' and is no longer in charging mode. Wiggle the remote to ensure that it is sitting in the cradle and making contact. There are also some fixes that can be done of the cradle itself, including opening it up and adjusting the height of the contacts. Others have had luck cleaning the contacts on the remote and the cradle with something more 'high test' than alcohol - a contact cleaner like DeoxIT. Still others have actually sanded down the plastic surrounding the contacts on the outside of the remote in order to bring them closer to the cradle contacts.
3) If you still have trouble after you have tried everything above, there may be a loose connection inside the remote itself. There is a very small plug that connects the charging terminals on the remote to the battery compartment. In some cases, this plug can become loose (especially if the remote has been dropped). If all else fails, you can open the remote and check to make sure that the plug is completely seated or attempt to push the terminal contacts slightly farther out. However, most people have found that altering the height of the contacts on the charging cradle is a better way to go. If you want to open the remote, do the following: remove the two screws - one in the battery compartment and one at the top of the remote. Then, using your thumbnail (this is really the best, unless you have a thin, rigid piece of plastic. A part of a credit-card may work), force your nail between the two halves of the clamshell casing near the bottom of the remote on the left or right side. Once you get your nail (or plastic) into the remote, angle it down at about 45 degrees and simply slide your hand up one side. This will release all the locking tabs very nicely without marring the surface of the remote. Then do the same on the other side. Once you are done exploring, simply realign the two halves and snap them back together.
Nov 21, 2009 | Logitech Harmony 890 LCD Remote Control
The 880 unit will not charge. Have cleaned all contacts and seems to be making contact. Any suggestions.
2) There have been reports of problems with some of the charging cradles in which the remote does not make sufficient contact with the contacts in the cradle. This sounds like it could be your problem. To ensure that the remote begins to charge, place it in the cradle and listen for a single beep. The slide show should start and then, after a few moments the screen should darken. If you hear two beeps at any time, it means that the remote has lost contact with the charging cradle and has 'woken' and is no longer in charging mode. Wiggle the remote to ensure that it is sitting in the cradle and making contact. There are also some fixes that can be done of the cradle itself, including opening it up and adjusting the height of the contacts. Others have had luck cleaning the contacts on the remote and the cradle with alcohol or a contact cleaner like DeoxIT (sounds like you tried this). Still others have actually sanded down the plastic surrounding the contacts on the outside of the remote in order to bring them closer to the cradle contacts.
3) If you still have trouble after you have tried everything above, there may be a loose connection inside the remote itself. There is a very small plug that connects the charging terminals on the remote to the battery compartment. In some cases, this plug can become loose (especially if the remote has been dropped). If all else fails, you can open the remote and check to make sure that the plug is completely seated or attempt to push the terminal contacts slightly farther out. However, most people have found that altering the height of the contacts on the charging cradle is a better way to go. If you decide to open the remote, do the following: remove the two screws - one in the battery compartment and one at the top of the remote. Then, using your thumbnail (this is really the best, unless you have a thin, rigid piece of plastic. A part of a credit-card may work), force your nail between the two halves of the clamshell casing near the bottom of the remote on the left or right side. Once you get your nail (or plastic) into the remote, angle it down at about 45 degrees and simply slide your hand up one side. This will release all the locking tabs very nicely without marring the surface of the remote. Then do the same on the other side. Once you are done exploring, simply realign the two halves and snap them back together. Good Luck!
Jul 10, 2009 | Logitech Harmony 880 LCD Remote Control
I have a Olympus DS-4000 which downloads via the cradle to our transcription software. The recording is skipping and we are missing words and up to entire sentences. What could be the problem?
When this happens, in most situations it is the 4-position-slide component which is faulty (or loose between the notches). If you are UK based, contact BES in Luton for a repair (circa GBP70)
Jun 10, 2009 | Olympus DS-4000 Digital Voice Recorder
Midland GXT800 radio, opened, reassembled, won't charge now...Help!
hi ive got a midland 3001 and i carnt find any one to speek to ?
Jan 10, 2009 | Midland GXT850VP4 Two Way Radio
Magellan Roadmate 760
The weakness of the 760 is the cradle. Is the power wire or the cradle loose or wiggles? You may need to buy a new cradle if that is the case. They are expensive. I soldered my power wire right into the cradle and it worked fine.
Aug 26, 2008 | Magellan Roadmate 760 GPS Receiver
Forerunner 305
These units seem to be suffering from a bad connection on the inside of the unit. My wife's did the same thing. There was a connection inside that wasn't making contact. First try cleaning the 4 brass connection tabs on the watch and check your charger to make sure the tabs are raised and not squished. Second try to reset the unit. Hit mode reset and power buttons all at the same time. Hold these for 3 seconds and then release. If these do not work here is what I did. There are no screws holding the unit together. I used a exacto blade to very carefully pry the unit apart along the side seam. It's not easy to do. Be very cautious and gentle. Work the thickness of the blade into the joint to gently wedge apart. You are not trying to remove material! Once apart you will see some fingers that make a connection between the upper and lower part of the unit. This is where the problem was with my wife's 305. I gently raised these tabs to make a better connection, It's been working ever since. I didn't try it before but try pressing very hard on the unit where it says Forerunner 305. The case is very hard so it might not work. But if it powers up when pushing you found your problem. Hope this helps. Here is a link I found on opening a 205 (Same process) http://ctorunner.googlepages.com/dismantleforerunner205 To put the unit back together use Automotive silicon/gasket maker. Use a tooth pick to put a VERY small amount of silicon around the entire seam. Put the two half's together and wrap tightly with electrical tape. Test the unit immediately to see if it powers on and off. If it does not open it back up and raise the small prongs that make the connection from the bottom half to the top half. If any silicon squishes out the sides wipe with water and a rag. Let the unit sit over night. In the morning remove the tape.
Jul 16, 2008 | Garmin Forerunner 305 GPS Receiver
Palm LifeDrive not charging
I had the exact same annoying problem. Easy fix though. Get the palm universal cradle. The power connector is either worn or loose and making partial contact. So when you use the normal adapter there might be a position that works but generally it won't. When you use the cradle the weight of the LD presses the contacts more and it will behave.
I went through a couple of chargers before getting the cradle and fixing it once and for all.
Apr 16, 2008 | Palm LifeDrive Mobile Manager Handheld
It won't turn on, bt the battery still charging
Another way I've found to do this is to press the power button and reset button at the same time. Then when you get the message to clear all data press cancel. I get this every time I re-charge my axim in the cradle. Doesn't anyone have a better solution? When it happens I have to reset my time. It's usually a day behind.
Sep 14, 2007 | Dell Axim X50v Pocket PC
Magellan RoadMate 700 GPS Receiver Logo
26 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Damen Wong
Damen Wong
Are you a Magellan GPS Expert? Answer questions, earn points and help others
