Question about HP Officejet 6310 All-In-One InkJet Printer
HP Officejet 6310 wont copy or fax from top loader. To send a multipage fax I have to send each page separately
    Problem Solver:
  • 10 Answers
When you slide the pages into the top loader you reach a small plastic tab and probably stop there. Push pages in another 1/2 inch or so and you should hear a beep indicating the paper now is in far enough.
Posted on Aug 27, 2009
When faxing does paper face uup or down
You load the originals print side uo on the document feeder tray or print side down on the glass.
To send a single page fax you can either load the original on document feeder tray or on the glass; to send a multi-page fax you must use the document feeder tray.
The position of the paper is the same either you copy, fax or scan.
All this is clearly explained in the user's manual, that you should read and you can download from HP support pages for you printer:
Aug 09, 2009 | HP Officejet 6310 All-In-One InkJet...
When copying or printing a fax, a vertical black line 2-3 mm line
try cleaning the rollers with water in the feeder at the top check the glass too too see if it's dirty
Jun 27, 2009 | HP Officejet 6310 All-In-One InkJet...
Hp officejet 6310 all-in-one send fax configure
1. Press Setup on the front panel of the All-in-One.
2. Press 2 to enter in to Print Report.
3. Press 1 to enter in to Fax Confirmation.
4. Press 1 to turn on Fax confirmation
5. Press 2 to enter in to Image on Fax Send Report
6. Press 1 to turn on Image on Fax Send Report
Jun 03, 2009 | HP Officejet 6310 All-In-One InkJet...
When I copy, send a fax, or scan it turns out HP 6310 all in one
this is a hardware issue..connect the printer to the wall outlet..and then try to make a copy..if its still the same then machine should be replaced..reason is scanner blub is gone bad..
Mar 09, 2009 | HP Officejet 6310 All-In-One InkJet...
My hp officejet G85 won't successfully send multipages faxes Can you help me with this problem?
Not sending multipage faxes I will assume the pages are not feeding correctly. If this is the case replacing the entire ADF would be the easy fix.
Not available new from HP as far as I can tel but available if you search G85 ADF.
If machine is terminating the connection try reseating th LIU this is the board the phone line plugs into. part C6735-60009
Hope this helps
Mar 06, 2009 | HP OfficeJet G85 All-In-One InkJet Printer
My new 6310 HP won't receive faxes.
Hi
when you installed did you get the fax setup wizard during the installation. If not, you can get it by opening hp solution center-> settings-> fax settings-> fax setup wizard.
You can have the HP solution center icon in the desktop or try with hp Director.
if not you can look at the
hard-copy user guide walks you through all the setup variations, depending on what type of line you have, what components (answering machine, for example), and how you want to handle incoming calls and faxes.
Good Luck
Jan 29, 2009 | HP Officejet 6310 All-In-One InkJet...
ADF will only feed one sheet then stop
no,just try to clean the roller of the ADF at the same time the separator pad.make sure that you are using paper that is 24lb weight coz if you are using paper that is so thin if may cause also an issue that the ADF could not pick-up...if the issue is still occuring return/replaced the printer...
send feedback for further troubleshooting...
Aug 23, 2008 | HP Officejet 6310 All-In-One InkJet...
Faxing a word document
hi, i would like to know if you have an HP officejet 6300 fax icon???if you have try to print the document using the fax icon DO NOT used the normal HP officejet series icon.if you did used the fax icon it will display the FAX dialog box,input the necessary information needed.just follow the window..
i believe you can now send the fax..
send me feedback for further troubleshooting....
Aug 04, 2008 | HP Officejet 6310 All-In-One InkJet...
Fax machine will not fax
can you please mentione the setup of the fax you are using
Jul 05, 2008 | HP Officejet 6310 All-In-One InkJet...
HP Officejet 6310 All-In-One InkJet Printer Logo
126 people viewed this question
Seeker5211
Seeker5211
