Question about Sony Ericsson K790i Cellular Phone
No power in the cell phone .
There is no power at all ,
It cannot be a Water issue ,
The red light on the right lower part of the cell phone is broken ,
Bought the cell phone in March 2008 ,
broke it in May and got it fixed for 3000 Rs ata local Sony Ericson Service Center .
After that the phone fell down and the Mic stopped working .
For a day I used the earphone + mic to make calls ,
After a day the phone was dead .
HELP !!
  • 112 Answers
IF your earphone dead plz conform it
r
try to roster your cell phone and then try agin
Posted on Dec 13, 2008
My phone wont charge at allits not the cable ive tried several ive tried about everything
  • I am guessing that you have tried multiple wall power adapters. I am also assuming that you have tried several usb cables. If you have not tried a different wall power adapter and power cable go do this first.
  • If I were you I would remove the battery and hold the power button down for 30 seconds. Then replace the battery and back cover. Try charging the phone. If it works you are good to go.
  • If this does not work something major is wrong with your phone. It is most likely a loose charging port. A cell phone repair tech can fix this issue. I would see if your phone is under warranty first.
  • Make sure the cost of the repair is worth it if your phone is broken. Compare the cost of a repair to buying a new phone.
  • This could also be a bad battery, water damage, etc. A bad power port is the most likely cause of your problem.
May 25, 2015 | Samsung Galaxy Mega 6.3 Mobile Phone
Turn it on
Hi Susan, are you asking how to power up the blackberry torch? If so you just need to press and hold the red telephone symbol!
Dec 20, 2014 | RIM BlackBerry Torch Cell Phone
WHY DOES ICE MAKER NOT HAVE WATER, BUT WATER DISPENSER HAS WATER?
Good Morning Friend, thank you for your post!
From what you have described it sounds like your ice maker is not making ice but your dispenser is dispensing water. If your ice maker has stopped producing ice completely, here are a few simple troubleshooting tips that may help you resolve your issue:
    1.It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these: If your ice maker has a small red plastic lever, lower it to lower the wire. If there's no plastic lever, simply lower the wire. In either case, the ice maker should begin producing ice again.
    2.Also make sure that the temperature is 8 degrees Fahrenheit or lower. If your freezer is too warm, the ice maker won't cycle properly.
    3.When was the last time the filter was changed? Most filters are recommended to be change approximately every 6-9 months depending on your water usage and frequency.
    4. The ice maker fill tube may be blocked with ice or have a clogged water filter. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts!
    5.Also the water shut-off valve or water-inlet valve, or both, may need replacing if necessary. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, then more than likely it will need to be replaced.
    Hope this helps! - Z
Aug 29, 2014 | Frigidaire Refrigerators
Not making ice
Hello locket_mba, I am happy to assist you!
If your ice maker has stopped producing ice completely, here are a few simple troubleshooting tips that may help resolve your issue:
·It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these: If your ice maker has a small red plastic lever, lower it to lower the wire. If there's no plastic lever, simply lower the wire. In either case, the ice maker should begin producing ice again.
·Make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
·When was the last time the filter was changed? Water filters are recommended to be change approximately every 6-9 months depending on your water usage and frequency.
·The ice maker fill tube may be blocked with ice or have a clogged water filter. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts!
·The water shut-off valve or water-inlet valve, or both, may need replacing. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Hope this helps!
Jan 29, 2014 | Frigidaire Refrigerators
Ffhs2611lw doesnt create ice
Good Morning Tom, thank you for allowing me to assist you!
  • It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these: If your ice maker has a small red plastic lever, lower it to lower the wire. If there's no plastic lever, simply lower the wire. In either case, the ice maker should begin producing ice again.
  • Make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • When was the last time the filter was changed? Water filters are recommended to be change approximately every 6-9 months depending on your water usage and frequency.
  • The ice maker fill tube may be blocked with ice or have a clogged water filter. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts!
  • The water shut-off valve or water-inlet valve, or both, may need replacing. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Hope this proves helpful!
Jan 24, 2014 | Frigidaire / FFHS2611LW
Fgh82844lf4
Hello nassaupc - If the unit has stopped making ice completely, try checking the following steps.
· It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these: If your ice maker has a small red plastic lever, lower it to lower the wire. If there\'s no plastic lever, simply lower the wire. In either case, the ice maker should begin producing ice again.
· Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won\'t cycle properly.
· When was the last time the filter was changed? Most side-by-side filters are recommended to be change approximately every 6-9 months depending on your water usage and frequency. The ice maker fill tube may be blocked with ice or have a clogged water filter. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts!
· Also replace the water shut-off valve or water-inlet valve, or both, if necessary. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you\'ve found broken parts, you can just replace it.
Should these suggestions prove to be ineffective, contact with a professional to accurately pinpoint any potentially more serious issues.
Jan 14, 2013 | Frigidaire FRT21P5A Top Freezer...
The unit is no longer heating the water. The red light comes on indicating that the unit is heating the water, but only cold water comes out of the faucet. We've tried raising and lowering the...
This will be a thermostat or element problem. The red light tells us that you have power to the unit. If you are handy you can test the thermostat and the element with a continuity tester. A voltmeter may also be used. This will tell you where the fault lies.
Mar 06, 2011 | Stiebel Eltron Tempra 24 Electric Hot...
I'm getting hot water for 2 minutes , then it gets cold
Most electric hot water heaters have two thermostats, one near the top of the tank and one near the bottom, and are covered by removable metal cover plates. The thermostats are pressed firmly against the bare metal wall of the hot water heaters tank.
The top thermostat usually has a high limit switch that will trip if the water gets too hot. When it trips it shuts off the electricity to both the upper and lower heating elements.
To reset the high limit switch there is usually a red button that you must press. When the upper limit switch trips it is often an indication that something else has gone wrong with the heater.
When the top of the tank is hot the upper thermostat removes power from the upper heating element and transfers the power to the lower thermostat and heating element. If the lower thermostat is defective, then the lower portion of the tank will not be heated and the supply will be greatly reduced.
Check for power at the upper thermostat terminals where the power is sent to the lower thermostat and heating element. If there is no power then the upper thermostat should be replaced. If there is power then check for power at the lower heating element. If there is no power at the lower heating element then replace the lower thermostat.
If there is power to the lower heating element then it should be getting hot. If it is not, replace it. Another possibility is a broken dip tube. Check for a broken dip tube and replace if necessary.
Hope this helps out
Feb 02, 2011 | General Electric GE SmartWater Household...
W\hat does it mean when i see a red exclamation
you don't have to be bothered my friend,the red exclamation sign simply indicates that the message is broken along the way which means the message is not delivered completely from th person who sent the message,the lower light tends to notify you about this abnormality and when the message is deleted from the pphone there is nothing it's trying to notify you of,therefore the lighter colour disappears when the message is deleted,
So stay cool,calm and collected because no one is trying to bugg your cell phone.
Be cool.
Jun 24, 2010 | Cell Phones
Red light when swith on power button ?
cell is dirty, or you have a broken wire in the cell.
Dec 22, 2007 | Oreck XL® Air Purifier
Sony Ericsson K790i Cellular Phone Logo
148 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
