Question about Frigidaire Kitchen Ranges
Wall oven too hot,at 350 setting is almost 400 degrees burns food
    Problem Solver:
  • 14 Answers
I have a very old GE wall mount oven. Original to around 1960. You can take the temp control knob off and there is an adjustment on the back of it. Easy peasy and only need a screwdriver.
Posted on Nov 26, 2015
    Scholar:
  • 160 Answers
You need a new thermostat control. or purchase a small oven thermometer and us it to adjust/compensate the oven temp by lowering the setting to 300.
only other option is to purchase a new oven.
check with a local repair shop on price to install a new thermostat control unit. if the unit is over 10 years old, it would be more economical to replace the unit entirely.
Posted on Dec 05, 2008
Why does my oven temp go down sometimes 50-100 degrees? I set it at 400 and check food and it's not done. Check temp and it's not what I set it at
thermostat problem normal cooking is done in the 150 to 280 range
at 400 you are getting to self cleaning temp and any cooking done there will burn
Jul 03, 2017 | Kitchen Ranges
Whirlpool oven will only get to 250 degrees, help
250' Centigrade is full power, Gas Mark 9, 482' Fahrenheit
This is an approximate conversion chart between gas mark and electric ovens. This information was copied from the rec.food.cooking FAQ.
Gas Mark Fahrenheit Celsius Description 1/4 225 110 Very cool/very slow 1/2 250 130 --- 1 275 140 cool 2 300 150 --- 3 325 170 very moderate 4 350 180 moderate 5 375 190 --- 6 400 200 moderately hot 7 425 220 hot 8 450 230 --- 9 475 240 very hot
Sep 24, 2015 | Whirlpool Ovens
Oven burning food
Don't worry my wife does the same thing. Not sure if your talking about the range top or the baking potion. We'll assume the baking area. If your using cheap bakeware that could be part of the problem try using a different cake or loaf pan of heavy construction. Also you may try reducing your temp in 25 degree increments to see if your oven runs hot. Example buy 3 cheap frozen pizzas and if they say value at 400 try 375 , 350, and 325. If one of those temps gives the desired result assist accordingly and consider contracting Bosch customer service to inquire about how to fix thermostat errors.hope that helps I didn't have much to work with.
Mar 24, 2014 | Bosch Ovens
GE Profile Oven temperature varies wildly
What is the model number of your unit?
Nov 19, 2012 | Ovens
My oven burns everything.
Use a 'oven thermometer' in the oven and determine the 'actual temperature' in the oven. Your knob setting is off (not calibrated) and the oven is hotter than the control knob setting.
Sep 16, 2009 | Ovens
The oven will turn on and get warm (not up to set temp)not as hot as it should. I no longer hear the forced air noise from the fan/blower from the back of the oven? It will not cook food, in the time frame...
is your power setting up allthe way (10) is it a convection oven also? microwaves dont usualy have a temp. setting unless there is a probe pluged in inside oven to a jack on inside wall of microwave microwaves can also get old and lose power if so you can get cheep ones at wallmart
Jun 17, 2009 | Microwave Ovens
Oven clicks to self cleans or f3, the door locks and food burns
Replace the oven temperature sensor.
Take your model number to any appliance parts store for a replacement sensor.
Apr 20, 2009 | Whirlpool Accubake RF362LXTS Electric...
My Kitchen Aid Supuerba top covection oven will heat to set temp 350-400 then drop over 100 degree's but still read on digital display 350 or 400
how do you know it is dropping 100 degrees ?
If the set temperature is 350-400 the heaters will work untill the thermostat will read that the temperature is reached - after that the heaters will shut down and the temperature will drop...and after few minutes when the temperature goes below thw set point (in this case 350-400) the heaters will turn on again - this will happen for the duration of the timing you have selected (example 45 minutes)
Oct 04, 2008 | KitchenAid Kitchen Ranges
T3 electric wall oven - Temperature set buttons
I had the same problem. The entire control panel had to be replaced. That included the display, keypad and all the hardware behind it.. it's one integrated unit. Luckily I had the extended warranty, otherwise it would have cost close to $400.
Jan 20, 2008 | Maytag 30 in. Electric Single Wall Oven...
Kitchen Ranges Logo
181 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
