Question about HP LaserJet 4350 Printer
LaserJet 4350n Error 49.C02
The printer is showing this error almost every week, the firmware, and driver are up to date. The printer is part of a network
The message that it shows is "49.C02 Turn OFF and ON the printer."
    Genius:
  • 1,605 Answers
49.XXXX PRINTER ERROR To continue turn the printer off then on Description The printing operation has been aborted. The issue can be caused by a firmware error, invalid print commands, corrupt data, invalid operations, poor quality parallel cables, poor connections or specific applications. Action
  1. Press Cancel Job to clear the print job from the printer memory.
  2. Turn the printer off and then on to clear the error message.
  3. Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job, contact the software vendor for assistance.
  4. If the above action does not solve the issue, contact HP or authorized service provider.
Posted on Dec 05, 2008
My printer hp laserjet 4350n displayed error 49.FF05 SERVICE ERROR .what is the problem
49.FF04 - in older 4xxx printer it mneans a firmware error - try to do:
1. cold reset
2. updaete firmware
3. remove network card from printer and instert it back - or try to turn printer on without it.
4. reinstall the formatter - phisical connection may be not good ( formater is a "cage" that the networc card is inserted)
go to http://www.hp.com for more information
May 27, 2015 | HP LaserJet 4350n Printer
What does this mean on my HP LaserJet P3005dn Printer, error 49.c02
This error is usually caused by out of date firmware. The printer is getting commands from a program like Acrobat it does not understand. Click thi slink to go to support page for your printer. Drivers Software Firmware for HP LaserJet P3005 Printer series Download the current firmware, I suggest the easy firmware update which is the first option, and then run that file.
May 20, 2014 | HP LaserJet P3005dn Printer
Hp color laserjet cm1017 mfp 49 service error showing in disply screen and restart the printer
Aug 15, 2011 | HP LaserJet CM1017 MFP All-In-One Color...
49.c02 Error To continue turn off then on HP4700 LaserJet Color Printer
49.XXXX
PRINTER ERROR
To continue
turn off then on
A critical firmware error has occurred that
caused the processor on the formatter to
abort operation. This type of error can be
caused by invalid print commands, corrupt
data, or invalid operations. In some cases,
electrical noise in the cable can corrupt
data during transmission to the printer.
Other causes include poor-quality parallel
cables, poor-connections, or home-grown
programs. On rare occasions, the formatter
is at fault, which is usually indicated by a 79
Service Error.
1. Turn the printer off then on.
2. Press Stop to clear the print job from
the printer memory.
3. Turn the printer off then on.
4. Try printing a job from a different
displays only with a certain software
5. If the message persists with different
software programs and print jobs,
disconnect all of the cables to the
printer that connect it to the network or
computer.
6. Turn the printer off.
7. Remove all memory DIMMs or thirdparty
DIMMs from the printer. (Do not
remove the firmware DIMM.)
8. Remove all EIO devices from the
printer.
9. Turn the printer on.
10. If the error no longer exists, install
each DIMM and EIO device one at a
time, making sure to turn the printer
off and on again as you install each
device.
11. Replace a DIMM or EIO device if you
determine that it causes the error.
Aug 08, 2011 | HP LaserJet 4700 Printer
My printer hp laserjet 4350n is not printing because it shows or display 49. ff04 service error
abort the operation.
This type of error can be caused by invalid
print commands, corrupt data, or invalid
operations.
In some instances, electrical noise in the
cable can corrupt data during transmission
to the printer. Other causes include poorquality
parallel cables, poor connections, or
specific software programs.
Sometimes, the formatter itself is at fault,
which is usually indicated by a 79 Service
Error.
Recommended action Hp Service Manual
1 Press CANCEL JOB to clear the print job
2 Turn the printer off and then on.
3 Go to www.hp.com/go/lj4350_software.
Select Download Drivers and
Software. Check for the latest firmware
image version at the bottom of the
page. If this firmware image is newer
than the one installed on the printer
and the printer can receive a firmware
update, download the newer firmware
upgrade.
4 Try printing a job from a different
5 If the message persists when using
different software programs and
attempting specific print jobs,
disconnect all cables that connect the
printer to the network or a computer.
6 Turn the printer off.
7 Remove all memory DIMMs or thirdparty
remove the firmware DIMM in slot J1.)
See Firmware DIMM (LJ 4200/4300
only).
8 Remove all of the EIO devices from the
printer.
Jul 06, 2011 | HP LaserJet 4350 Printer
My printer hp laserjet 4350 shows error 49,what could be the cause
Most times a "49" error indicares the need for a firmware upgrade.
If the machine is networked, disconnect the network cable and power the printer off, wait 2 minutes and power it back up. It should reset the error.
BEFORE reattaching the network cable delete the job in the printer queue that caused the error ( Most likely a PDF file).
Go here:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=412171&prodTypeId=18972&prodSeriesId=412160&swLang=8&taskId=135&swEnvOID=228#290
and download and install the latest firmware
A workaround is to print the PDF as an image
May 20, 2011 | HP LaserJet 4350 Printer
Printer error :"49.C02 service error " message
i think this caused by your windows is not genuine
Jan 14, 2011 | HP LaserJet 4700 Printer
49.2f9d error hp laserjet 3005dn how to solve the problem
Most times a 49.xxxx error on an HP printer is caused by either the print driver, firmware or the print job itself.
If it happens when printing a PDF file try sending the file to the printer as an image.
Upgrade the print driver and the firmware.
You may need to disconnect the printer from the pc or network, power it off and pull the plug for a couple of minutes to clear the error.
If it's a network printer it would be a good idea to check the printer queue for any jobs still in it and delete them before powering the printer up again.
Dec 14, 2010 | HP LaserJet P3005 Printer
49.c02 service error message on HP laserjet 4100
General printer error. Unplug the power cord for 10 seconds.
Jan 21, 2009 | HP LaserJet 4350 Printer
HP LaserJet 4350 Printer Logo
1,668 people viewed this question
Ben Johnson
