Question about RCA D52W19 52" Rear Projection Television
52" RCA Rear Projction TV 1995
I psh the power button and it flashes the light on th imeditly turns back off and i checked the fuse and it is good.
  • RCA Master
  • 5,138 Answers
Check cp 150 2200uf 16v, if bad there is 2 more caps in same circuit 220uf 35v.cp111 cp114
Posted on Dec 10, 2008
My RCA 52" HDTV Rear Projection TV Model #MM52110JX1 will not turn on. Neither the remote, nor the front panel switch will turn on the TV. When you press the power button on the remote, the red indicator...
you must check the light indicator if how many times does it blink which tell the main problem or the error code of the tv. either the power supply doesn't work normally or the lamp need replacement.
Sep 23, 2013 | RCA D52W19 52" Rear Projection Television
I HAVE A 52' RCA HDTV THAT WILL NOT TURN ON ,AT TIMES IT SEEMS LIKE IT WILL TURN ON BUT THEN GOES BACK OFF,CAN ANY ONE TELL ME WHAT THIS PROBLEM CAN BE
sounds like the power caps CP150 CP120 and CP114 on the deflection board. You can get the RCA repair kit by that same name from www.tvrepairworld.com the kit also comes with instructions.
Mar 15, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA Tv wont come on at all. No light s flash or
hi, i think cathode ray tube has burnt out .......first check the fuse also thank u.......
Jun 03, 2009 | RCA D52W19 52" Rear Projection Television
Tv wont turn on, RCA D56w20, 56" rear prjection
replace the flyback 259296 and the CP150 capacitor. You can get the replacement parts with free instructions at the following link.
http://servicemanuals.vstore.ca/
May 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52'' projection TV: will not turn on
Try unplugging the set for a full minute, then plug it back in and try again.
Sometimes this will reboot a glitched up computer.
Otherwise you will need the assistance of a professional.
www.mcveyelectronics.com
May 03, 2009 | RCA HD52W56 52" Rear Projection HDTV
35" RCA 35" Entertainment Series - PIP
ok is the set completlely dead. DOEs the Led on the front flash. if it does not flash this is an indication of a primary power interuption. POSSIbley main fuse. Now generally the main fuse does not blow unless there something else wrong. some other component shorted. Now if the light flashes then this is an indication that the main fuse is still good and that the processor is getting power and that it has detected a condition that requires it to shut down. ussaly a high voltage issue
Dec 11, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
My 1995 RCA 52
Replace capacitors in power supply,( 4 cap. ) 2.2uf 100V, 39uf 100V, 470uf 25V, Ready!!
Apr 25, 2008 | RCA P52926 52" Rear Projection Television
Where is the fuse located?
first question does any lights on front panel come on does the green light flash.... if so then i will not be the fuse... otherwise just follow the main power cord back into the set to the back cuircit board behind the green board.
Mar 13, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52 in. Rear Projection
the main pwr board is defective and will need replacement...
Oct 18, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
TV WON'T COME ON
If the fuses are good and the on indicator lights you could have a short in the power supply, the high voltage section or just about any part of the circuitry. The most common problem is the high voltage. If you know TV safety and how to check transistors, unplug the unit and check the horizontal output transistor. If it is shorted replace the transistor, flyback and HV divider. If this does not solve the problem you will probably need a repair tech as this symptom could be a short anywhere in the unit. Good luck and remember to be safe.
Jun 30, 2006 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W19 52" Rear Projection Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
