Question about Jenn-Air SVE47100 Slide-In Electric Kitchen Range
Hello there, My stove beeps repeatedlyand willonlystopwhen Iunplug the stove ... I read that it maybe the circuit board. Is this the problem and can I fix it myself?
  • mitfix Dec 07, 2008
    I have a similar problem. I used the clean function on the stove and when it finished an F1 code appeared on the display and the internal fan in the oven runs constantly! I unplugged the oven but that did not solve the issue! Another web site suggested I replace the electric control unit. Any suggestions?
  • aj
    aj May 11, 2010
    Is it really the stove beeping or the control pad in front? Also, is this for the SVE47600 model?
    Habit-Forming:
  • 171 Answers
Yes trhe stove have a swich behind every knob one of them is bad on the on position, remove allthe knobs and the knob panel to get to the swiches, and remove one at a time intel noise stops thats the one needs changing. or it may be that the are wet.
Posted on Dec 06, 2008
I cant get my stove to stop beeping. f1 error
You need to get the exact model number and make of this stove. Get ready for a bad circuit board to be the culprit, because electronic stoves are pretty much unfixable by mechanical means and the problem usually comes from a bad capacitor, corroded or overheated circuit board.
When you get your model number and make, go to YouTube and just type in your model stove and ask "how to repair a F1 error code on a blah blah stove". There are so many video's there on how to repair things with actual instructions and pictures. It's great.
Use this link to close in:
https://www.youtube.com/results?search_query=repairs+to+appliances+or+stoves
Jan 27, 2015 | Kitchen Ranges
Stopped working, flashing code F7 and beeping
Hello Michelle, thank you for your inquiry!
Typically error code F7 indicates that your Frigidaire range is experiencing a failure with either the potentiometer or UIB (User Interface Board). Let's try resetting you range by unplugging it or flipping the household circuit breaker off. This usually clears most false error codes. It is best to wait approximately ten minutes and then turn on your appliance. If the error code persists, it would be advisable to contact an experienced appliance repair tech to assist further.
Best regards - Z
Mar 16, 2014 | Frigidaire Stove/Oven/Range Cooktop -...
Hi there. Our Moffat stoveModel 24K60 has been in service since 1966, and, with a few minor service calls is still ticking along. No pun intended, but that's the problem. The clock is not only...
Hello there schematics for your unit will be next to impossible to find on the internet. My guess is that your unit uses a manual type timer as units that old usually have the timer independent of the other functions of the unit.therefore you wont be able to find any wires which power the unit. Mostly the timer will run on its own as a result of sensors on the unit. Both options which you have considered are gud but lubricating the bearings seems more likely although getting at it might be a bit difficult what you need is a watch expert usually they have methods of loosing out the entire clock mechanism taking it for servicing and fixing it back on your unit this way the bearing noise will stop. Also if you decide to take of the clock completely the same procedure applies.
Hope this solution has been helpful?
Apr 15, 2011 | Kitchen Ranges
I had the oven on and I heard a loud popping noise, now the stove doesn't work (eg. the letter Fy1 comes up , the stove makes beeping noises, the stove door locks and unlocks etc.) The model # is...
rwere
Hello, and sorry to read about your problem.
Sounds like you have a general main board failure,
I suggest you call a service company
I tried to help you. Please help me and vote/rate my response thanks.
Dec 24, 2010 | Frigidaire Ovens
My stove beeps and flashes F1 after having the stove on for a few minutes
Hi - F1 indicates a fault in one or more circuits on control board. No good news here. Boards range from 150-250$ + install. Usually fail during 'self-clean' or as techs call it- 'self-destruct'. Let me know if info is helpful- Thanks- ED
Mar 02, 2010 | Kenmore Kitchen Ranges
The stove just says F1 and beeps won't let me do
Hello with the limited information and no make or model I can only give a generic response to this one. Most manufacturers F1 code indicates a bad control board (EOC) and or a bad touch-pad. If you have any other questions please feel free to comment. Mike
Nov 03, 2009 | Ovens
My meat probe on my jenn-air electric stove works but no beep
you may need to scroll through your settings to turn the beep on
Nov 25, 2008 | Kitchen Ranges
Random beeping and panel buttons not working
There may be a failure of some type in the system processor area.
Maybe some of the steam from the bioling water and oil and water from the cooking got inside on to the circuit board, and caused some damage.
It is also possible that the heat from the stove did some damage.
It is also possible that there was simply a failure in the system processor area.
Jerry G.
Apr 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Kenmore Stove Glass top
I have a Kenmore glass stove, not sure what the model number is I don't have it with me right now. Yesterday, the timer started to beep and F1 started to flash in the display. The stove top is working, but the oven does not. The only way I can get the timer to stop beeping is to unplug the stove.
Any suggestions as to what is going on with this stove. It's only 4 years old.
Thanks
Oct 22, 2007 | Kenmore 46123 Stainless Steel Electric...
Jenn Air model S176W
Heat and moisture (steam) kills the electronics in any control. but if the mark are on a circuit then there was a short in a circuit. I would check the series if your stove( first two numbers in the serial number)if it is a early series. for sure that they have make improvements in the control. And a Replacement controls will have all the improvement and revisions. good luck and let me know what you do..kraztech
Sep 07, 2007 | Jenn-Air JGS8750 Gas Kitchen Range
Jenn-Air SVE47100 Slide-In Electric Kitchen Range Logo
82 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal De
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
