Question about Lexmark Office Equipment & Supplies
Cannot print lables. Other printing is okay. Everytime I put the labels in the printer,they do not print- just goes thru the motuions.
    Scholar:
  • 160 Answers
What printer? do you have labelling software installed? or are you using just standard word processing?
you may want to get avery label software. it's specifically used for those types of uses (though you don't need to use their labels as long as the labels are using a similar layout).
you can find the software at most office supplies.
if you want to use something free try
http://www.download.com/BarCode-Label-Printer/3000-2064_4-10537435.html?tag=mncol
Posted on Dec 05, 2008
In my application,i want to print the barcode generated from the application.i am using TTP 244 plus printer for printing the generated Barcode.but printer skips two lables and print the generated bar
Please verify the following:
- Driver: If you are using the standard printer driver, maybe you want to try another driver(Download an excellent driver at www.nicelabel.cl, searching by your brand and model name).
When installed, you should go to advanced settings and use the callibrate options.
- Software: Maybe your software has a configuration and the driver has another, set the same length for both and verify if the problem persists.
- Sensor: If the sensor has an issue, then you should try contacting a local reseller or partner for zebra. If that's the case, you probably will have to repair the printer($) or definitively replace it for another($$). Since it's a desktop printer, check your warranty first and maybe you are covered.
Jan 16, 2015 | Zebra GK420t thermal transfer and thermal...
Everytime I try to print lables, it prints one or part of one and then stops and the red light comes on. I've tried restarting it, turning it on and off. What is the problem?
press the botton 2 times to run calibration, if not work, press button untill flash 7 times, if not work, chek the setings from driver (if use labels with gaps, use non-continues) (if use ribbon, use Termal Transfer) chech the settings (sensor ir on GAP/Web)
Nov 10, 2010 | Zebra TLP 2844-Z Thermal Label Printer
I have a BROTHER MFC-8480DN all in one printer which I just purchased. My avery lables do not work right as the first 2 rows are okay and then the text does not fit right on the following labels. I use it...
Lables are slick some time the feed rollers will slide on them. Try to find lables that are course with no shine on them . The rubber that the tires are made of is of poor quality. Just dont have the grip . Hope this helps
Aug 12, 2010 | Brother Office Equipment & Supplies
My printer appears to be printing the lables but
Make sure you are using thermal paper roll and not regular label roll.
Oct 05, 2009 | Zebra TLP 2824 Thermal Label Printer
Zebra LP 2844 Prints 30 pages of junk instead of a Dazzle mailing
Turn off the printer and place your finger on the green feed button. With the button depressed, turn the printer back on. Let the light flash2.gif (ONLY!) four times and release the button. Printer will cycle through 2-3 labels. Press the feed button one more time.
You've just set the printer back to factory default.
Jul 23, 2009 | Zebra LP 2844 Thermal Printer
Printer does not print
hold down the feed button until both light flash off and let go. This will reset the printer. This should stop it from feeding multiple labels.
Apr 27, 2009 | Argox OS-203 Thermal Label Printer
Issue trying to print mulitple labels, red light
The physical label size must be set in the printer driver, both in the "Properties" and the "Default" tabs.
Jan 15, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Printing Labels
The MPF is simply the "Manual Paper Feed".
Your printer is set by default that the MPF paper type is "plain paper". Since you are telling the printer that you are trying to print lables, the printer is simply telling you that you need to load the MPF with lables.
If you say "ok", the printer sould continue and print the lables.
If you only print lables, the you can change the default paper for the MPF tray to "lables", and then you will no longer be prompted to load the tray.
Sep 25, 2008 | Dell 5100cn Laser Printer
Set up
May be your problems can be solved doing a calibration. To do this, turn off the printer, press the feed key and turn on the printer. When the led flashes in red quickly release the feed key, the printer will start to calibrate and after the calibration will feed one label.
It is explained in the user manual.
Mar 17, 2008 | Toshiba B-SV4D Label Printer
Printing Round Labels
the issue sounds inpart to be related the set lable length, the printer thinks that the data will not fit on the label and gives the error. also note that the gap sensor is not in the center so the printer will not and can not autodetect the media correctly. you need to tweak the label setup. you could trick the printer by centering the labels over the gap sensor or if you do a autocalibating use the lable size it give you which would be much smaller then 17mm
Nov 12, 2007 | Zebra TLP 3842 Thermal Label Printer
75 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
