Question about Samsung HLN467W 46" Rear Projection HDTV
Color went to grayish green, dull picture.
The color on my HLN467W Samsung went to a grayish green "especially in flesh tones". Picture is still very sharp other than color. Also, I don't have any led's that remain lit after the lamp comes on, should I ? The set is 4 years old and had warranty issues in the beginning so they replaced a major part already that was causing the set to re-fire the lamp over and over, but never come on. I have never replaced the lamp, could this affect the color ? I hate to spend $140 bucks on a lamp and not fix the problem. Thanks, Marty.
It ended up being one of the connectors on the composite cable. I did not know that the different colors came through separate cables. I do now, Thanks.
Posted on Dec 08, 2008
I just bought a UN46D6000SF and, while the pix is gorgeous, I don't like the flesh tones (they appear light/washed out). Are there any settings that I should adjust to make them more agreeable? Thank...
Adjust the picture temperature to a warmer setting.
Try this...
Advanced Settings Press MENU ? Picture ? Advanced Settings ? ENTER
There you will find a lot of options, one of which should include an option for Flesh Tone. Your TV might not have that option. If that is the case you would look around the menu's for color options or color temp and make some adjustments in those area's to make the pictures warmer.
Apr 08, 2011 | Samsung Televison & Video
Red Tint on Screen
This is normal and is a color calibration issue.
For correct color, NEVER use the "WARM" setting. Why? Too red. You cannot get REALISTIC or ACCURATE color using the "Warm" setting.
Since we are speaking of Samsung, first avoid the "Flesh Tone" adjustment. When things are set correctly there is no need for this adjustment. It is a quick fix and not for the "discerning eye".
1. First, access the "Color Temperature" menu. From here select "Cool2" or the coolest temperature setting.
Note: For Samsung use "Cool2", or if not available, "Cool1". Samsung has inadvertently increased calibration confusion by issueing TVs that have just "Cool1", and TVs that have both "Cool1" and "Cool2" :0[
For other brands, use "Cool", or "High", or "+6500k". Anything lower artificially reddens the picture and compromises detail.
2. Now return to the color settings and reduce "Color" to between 30 and 40 (on a 100 scale). The sweet spot is just near the place where the color rapidly washes out.
3. To round out the color palette, move to the "Tint" adjustment and ADD a couple (3-5) clicks to the GREEN.
Adding the touch of green is what is needed to take out the last bit of "pink" and will make all the tones and all colors display properly.
I hope this helps!
To further increase the quality of your picture visit
http://www.wowvision.tv/main.htm
Highdefjeff :0]
Jun 15, 2010 | Samsung LN46C630 TV
Green hue
Hi,If you are experiment hues,color distortion ,black and white picture,hear buzzing high pitch sounds, it could be time to replace the color wheel.Your part # will be BP96-00250A you can find it here: http://www.discount-merchant.com/Samsung-BP96-00250A-ColorWheel-Assembly-p/bp96-00250a-color-wheel.htm? and here's the instructions to replace it: http://www.fixyourdlp.com/guides/samsung/bp96-01579a.php Have a blessed one!
Feb 19, 2010 | Samsung HLN467W 46" Rear Projection HDTV
Samsung HLP4663w. After replacing the Ballast, Bulb and Color Wheel (color wheel came without the CCA values and the Actuator and Index delay values) we still have the same color and picture problems. Do...
if the picture is blue green there is a jumper to be removed on the dmd board on connector cn810--the index delay should be between 40 and 50 for optimum color --or adjusted for best flesh tone also in the options the cw setting should be set for cw2
Feb 06, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
New lamp, now color variation, dull picture and overheating
it sounds like if your tv is a dlp the colorwhele is stuck
probibly because a after market or faulty bulb has melted it
get serviced imedietly
Jan 23, 2009 | Mitsubishi WD-62531 Projection Television
Red and orange screen
it is the STK's in the rear that need replaced usually about 300 to do the job, call a jvc familiar reapair center, They say they always have them in stock
Mar 12, 2008 | Televison & Video
Color Problems 60PP9352 60" Rear Projection
Check to make sure the green is lit up! You will need to remove back and look inside to tell.
Jan 06, 2008 | Philips 60PP9352 60" Rear Projection...
Flesh tones and red colors
any hue adjustments usally relly cheap tv u got also hard to get good colers from it the lg one is nice i like samsung and sharp
go throw azll colers cheak dvd cables
Jan 06, 2008 | Insignia IS-LCDTV32 32 in. Television
Samsung HLN467W 46" Rear Projection HDTV Logo
94 people viewed this question
Henry  Thomas
Henry Thomas
