Lexmark x3430 disassembly instructions
Printer jammed with too much paper and when it was removed, there was a thin transparent brown "strap" that came unattached from the print carriage. i need to know where to reinstall it and the lexmark x3430 disassembly instructions will be most useful to do this. the unit is already disassembled, i just need a picture or guidance to put the part in and stop the cartridge from slamming from side-to-side in error mode...
  • kbdaok Dec 18, 2008
    Yo Justin, if you solved the problem please contact me (kbd@pi4c.com). My Lexmark x5020 ate a small envelope.
  • KLINGECLIPSE Feb 02, 2009
    PLASTIC STRIP CAME OFF THE PRINTER. HOW DO I FIX IT?
4 Suggested Answers
SOURCE: Deskjet 9800 disassembly
I have the same problem!
Posted on Oct 28, 2008
SOURCE: Pixma 830 stuck in right position. Tried your
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp830
Above is your support link for the MP830
http://www.devicemanuals.com/guide/Multifunctional/Canon/Canon-Multifunction-Injet-PIXMA-MP830-User-Guide-TkRBNU1UZz.html
Above is your user guide, below is your service and repair manual, this should help a great deal. The service manual, shows how to disassemble the printer and how to repair it too.
http://printcopy.info/?l=en&mod=docs&brand=Canon&prefix=PIXMA%20MP&gID=17002
Posted on Oct 29, 2010
jay767
  • 386 Answers
SOURCE: Paper jam msg on printer, carriage jam msg on
Hi Good day!! try this turn off the printer pull out the power cord and usb cable, check the pathway of the print head maybe there is something the block in your printer that may cause your print head to not move perfectly. if all clean move the print head to the center, now re plug the power cord and turn back on your printer, reply if still the same.
Posted on Dec 02, 2010
How do i fix my LEXMARK X3430?
Leading cause of paper jams is debris / foreign objects that accidentally fell into the paper feed area. Please try this approach to fix the problem:
  1. Remove the sheets of paper from the feeder.
  2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
  3. If you're willing and physically able, you may also carefully turn the printer over. Any debris should just freely roll out from the feeder.
  4. If feeder is clear, place the printer on the table. Open the printer cover and remove the cartridges.
  5. Check the cartridge area for any obstructions in the paper path.
  6. Close the printer cover.
  7. Re-brick your printer by pulling out the power supply - the black box where the power cord is plugged into. Re-plug after 30 seconds.
  8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again to verify that the problem is fixed.
If that doesn't help, try to re-seat the cartridges by removing and re-inserting them into the printer. Make sure they are properly seated and secured.
I hope this helps.
Feb 17, 2012 | Lexmark X Office Equipment & Supplies
Carrier Jam, there's nothing in it, I put new cartridge in still saids carrier jam, other then that this thin strip came out
The thin strip could be the encoder strip (transparent strip) which is responsible for the proper movement of the cartridge carrier along the carrier assembly. Please contact Lexmark Technical Support Center for additional assistance.
Sep 21, 2011 | Lexmark X4650 InkJet Printer
Is there online help to repair a Lexmark X 7350
Hi.
Please refer to disassembly instructions for Lexmark 7500 series. Procedure is the same.
Here the service manual:
Lexmark X7500 Service Manual
Jul 10, 2010 | Hoover Dishwashers
LexMark x3430 printer
Here is a guide of all possible paper jam locations on the X340 printer. http://bit.ly/cS4lpm
If still no paper is found on any of those places then the printer has a faulty sensor. Depending on the paper jam numeric error is the sensor that may be failing.
Feb 12, 2010 | Lexmark X340n All-In-One Laser Printer
Paper jam error, but no jam present
mabey its the wrong paper youre putting in it:O?
Jan 03, 2009 | Office Equipment & Supplies
LEXMARK X5470 PAPER JAMNED INSIDE PRINTER,UNABLE TO REMOVE.CAN I PURCHASE INSTRUCTION ON HOW TO DISMANTLE.
Try forcing a sheet of paper or thin cardboard through the paper path in the direction the paper feeds. This may push out the jam so you can reach it.
Jul 17, 2008 | Lexmark Office Equipment & Supplies
218 people viewed this question
k24674
jasbo
jasbo
