Morning, I need to scan a hard copy page on to my computer...not sure of the steps? I put page under the lid and hit scan button...
  • Anonymous Feb 21, 2009
    I can't find the instruction booklet, nor can I remember how to scan. I hit Start Scan with the page under the lid, but it said that it can't connect to the PC. How do I connect?
    Sergeant:
  • 237 Answers
Normally, You can scan from scanner or your computer. Either way, you will have to save it onto your computer. If you hit the scan button, it should pull up the scan software for you, with options and preferences for you to choose from. If this is just for records/storage purposes, just choose the default settings and save it under a name and location you will remember. Hit scan and you should be good to go...
Posted on Dec 05, 2008
Printer will not scan
he HP All-in-One product displays one of the following error messages on the control panel when scanning or copying:
  • Scanner failure, power off and on
  • Scanner System Failure
  • Scanner failed, cannot make copies or fax
  • Scanner failure. Unable to scan, copy, or send a fax
  • Scanner failure, cycle power
Additionally, the scanner bulb might not turn on during scanning.ry the following solutions in the order presented to resolve the issue. When one of the solutions resolves the issue, there is no need to continue troubleshooting.Solution one: Check the scanner lightFollow these steps to check the scanner light by making a color copy of any document.
  1. Load plain white, unused, letter size paper in the paper tray.
  2. Lift the scanner lid, place the original face down on the scanner glass, and then lower the scanner lid.
  3. Make a color copy.
  4. When the product starts to scan the document to copy, slightly lift the scanner lid to see if the scanner light turns on. It is not necessary to lift the lid completely CAUTION:Do not look directly at the scanner light.The scanner light should be visible under the scanner glass to the right or left.Figure 1: Scanner light visible underneath the glass
    1 - Area where scanner light is visible2 - Scanner glass
    • If the scanner light does not turn on when the scanner mechanism moves across the scanner bed, continue to the solution to reset the product.
    • If the scanner light turns on , continue with the next solution.
    Solution two: Check the power connectionFollow these steps to troubleshoot the power connection.
    1. Press the Power button (c01602202.gif ) to turn off the product.
    2. Unplug the product power cord from any surge protector, extension cord, or power strip, and then connect the power cord directly to a wall outlet.
    3. Press the Power button (c01602202.gif ) to turn on the product.
    4. Load plain white, unused, letter size paper in the paper tray.
    5. Lift the scanner lid, place the original face down on the scanner glass, and then lower the scanner lid.
    6. Try again to make a color copy.
      • If these steps resolved the issue , you do not need to continue troubleshooting.note.pngNOTE:If the product works properly when plugged directly into a wall outlet rather than a power strip or surge suppressor, the power strip or surge suppressor might not allow enough voltage for the product to work properly.
      • If the issue persists , continue with these steps.
    7. Press the Power button (c01602202.gif ) to turn off the product, disconnect the power cord from the wall outlet, and then reconnect the power cord to a different wall outlet.
    8. Press the Power button (c01602202.gif ) to turn on the product.
    9. Try again to make a color copy.
    • If the issue persists , continue to the next solution.
    Solution three: Reset the productFollow these steps to reset the product.
    1. Press the Power button (c01602202.gif ) to turn off the product.note.pngNOTE:The product might not turn off after pressing the Power button. Continue to the next step regardless.
    2. Disconnect the power cord from the rear of the product.
    3. Unplug the power cord from the electrical outlet.
    4. Wait 30 seconds.
    5. Replug the power cord into the electrical outlet.
    6. Reconnect the power cord to the rear of the product.
    7. Press the Power button (c01602202.gif ) to turn on the product.
    8. Load plain white, unused, letter size paper in the paper tray.
    9. Lift the scanner lid, place the original face down on the scanner glass, and then lower the scanner lid.
    10. Try again to make a color copy.
Dec 11, 2011 | HEWLETT-PACKARD Officejet 4500 All-in-One...
I have a lexmark 2600 all in one machine. How do I scan more than 1 page at a time?
This photocopier can only copy 1 page at a time. This is due to only being able to place one sheet on the viewing surface per scan.
To make a scan follow these instructions:
  1. Open lid and put the document or photo face down
  2. Close the lid to press the document flat and avoid dark edges
  3. Have the printer connected to the computer and both turned on
  4. Press the scan icon on the printer
  5. Follow onscreen instructions
  6. Repeat for each document needing to be scanned
Sep 14, 2011 | Lexmark X7350 All-In-One Printer
How do i scan on my brother copier?
Scanning is a standard all-in-one printer feature that converts a hard-copy document into electronic information, which your computer can store and modify. You can scan legal files, office reports or just about any other kind of document and create an electronic backup for your files, send it as email or alter it to suit your needs. Follow these steps to scan a document on an all-in-one printer:
1. Turn on your all-in-one printer and computer. Check the connections between the two machines.
2. Lift the printer's document lid. Examine the scanning surface and the underside of the lid for dust and fingerprints.
3. Put the document you wish to scan face-down on the glass. Use the alignment markers to help you square up the object. These are usually found on the left-hand edge of the scanning area.
4. Close the printer's document lid slowly so the document does not shift position.
5. Select a scan resolution. The higher the dpi (dots per inch) count, the sharper and more detailed the image.
6. Push the scan button. You may have to do this on the printer itself or on your computer.
7. Check the preview of your scan on your computer. Depending on your all-in-one printer and software, you may have to prompt your computer to display the preview for you.
8. Edit the image as it appears on your computer if you want to make changes. Your scanning software might let you enlarge, resize or otherwise manipulate the final product.
9. Accept the scan and save. Return the original document to a safe location.
I hope you find it very helpful. Best regards.
Aug 17, 2011 | Brother MFC-9840CDW Laser Printer
Use of Scanner
On this model there is a SCAN in black and white or color buttons but you need to have something on the glass to scan. Once it scans it prints!!!
Now lexmark software if installed comes with a program to scan with. you need to check under your prgrams folder under lexmark for the scanning software that was installed with the print driver.
If you open the lid and you do not see the white light chances are your scanner has and needs a bulb inside and at the point to install one of these you might want to concider a new printer.
Please be considerate and leave your feedback and comments and ratings before you leave, Thanks
Apr 30, 2010 | Lexmark X2500 All-In-One Printer
How do I scan a pic from printer to computer?
Things You'll Need:
  • Computer
  • All-in-one printer
  1. Step 1 Blow the dust from your scanner and printing area with canned air. Clean the scanner bed and the underside of the document lid with a damp, lint-free cloth before scanning.
  2. Step 2 Get your computer and all-in-one printer turned on and talking to each other. Open the scanning software on your computer if needed. If not, you can use the controls on your printer to run the show.
  3. Step 3 Lay the picture to be scanned face-down on the glass. Square up the photo using the guides that are usually located along the edges of the scanning bed.
  4. Step 4 Close the lid.
  5. Step 5 Go for a higher dpi (dots per inch) count if you plan on displaying the scanned image at larger-than-life size. Otherwise, you can select a lower resolution.
  6. Step 6 Click the scan button on your computer's scanning software window. Some all-in-one printers need you to press the scan button on the printer itself; check the manual before using.
  7. Step 7 Get a preview of the scanned image up on your computer monitor. This might happen automatically depending on your software settings; if not, you will have to prompt your computer to display one.
  8. Step 8 Correct small defects such as red-eye in the image. Save extensive changes for later with dedicated photo-editing software.
  9. Step 9 Accept the scan and save to your hard drive. Remember to put your picture away.
Apr 08, 2010 | HP Photosmart C4240 All-In-One InkJet...
The Scanner now has a pink line down the page - when I save a scan it has the pink line! Can this be fixed easily or should I buy a new All-In-One? I really like the HP 7410 -great until now.
I always advice my customer to follow below steps if a vertical line are encountered while scan or copy.
SOLUTION ONE: Reset the All-in-One
Power Reset:
If there is static interference, or loose connections with the product, this can result in bands or lines in
the copy, fax, or scan output. To resolve this issue, check the product connections and reset the product.
1.Make sure the product is powered on, and then disconnect the power cord from the product.
2.Disconnect the USB cable from the product, and then disconnect it from the computer.
3.Reconnect the USB cable to the computer, and then reconnect it securely to the product.
4.Disconnect the power cord from the wall outlet, and then reconnect it to the wall outlet.
5.Reconnect the power cord to the product.
6.Press the Power button to turn on the product.
If the issue persists, see the next reset.
Partial Reset
1.Remove the power cable from back side of the printer while its ON.
2.Press and hold "#" and "3" button, while holding them both insert the power cable and release the button after 10 seconds.
3.If printer turns OFF, press power button to turn it ON.
Semi-Full reset
1.Remove the ink cartridges.
2.Remove the power cable from back side of the printer while its ON.
3.Press and hold "#" and "6" button, while holding them both insert the power cable and release the button after 10 seconds.
4.If printer turns OFF, press power button to turn it ON.
5.Insert the ink cartridges.
NVM Reset
1. Remove the ink cartridges.
2. Remove the power cable from back side of the printer while its ON.
3. Press and hold "OK" and "Cancel" button, while holding them both insert the power cable and release the button after 10 seconds.
4. If printer turns OFF, press power button to turn it ON.
5. Insert the ink cartridges.
If the issue persists, see the next Solution.
SOLUTION TWO: Clean the product and make a blank copy
If the scanner glass or the white underside of the lid has debris, this can slow performance and affect copy
and scan quality. To resolve this issue, clean the All-in-One.
Before you begin, gather the following materials:
*Several clean, soft, lint-free cloths
*Mild glass cleaner
1. Press the Power button ( ) to turn off the product, and disconnect the power cord from the product.
2. Open the scanner lid.
3. Spray a clean, soft, lint-free cloth with mild glass cleaner.
CAUTION:Do not spray the glass cleaner directly on the glass to avoid damaging the scanner.
4. Wipe the scanner glass and the white underside of the scanner lid with the dampened cloth.
5. Dry the scanner glass thoroughly with a clean, dry cloth, or chamois to prevent spotting, and then dry the white underside of the scanner lid.
NOTE:Do not use tissues that can leave fiber residue.
6. Clean and thoroughly dry the small strip of glass to the left of the scanner glass, and then clean and dry the white plastic strip on the left underside of the scanner lid.
7. Close the scanner lid.
8. Reconnect the power cord to the product, and press the Power button to turn on the product.
If the issue persists, please service the product.
Thanks & Regards
Rizwan
Jan 31, 2010 | HP OfficeJet 7410 All-In-One InkJet...
I'm getting a color line going down the page on my pictures and the quality of the picture is no good
IssueWhen you copy, fax, or scan an original, the resulting output contains vertical bands, lines, or streaks in one or more colors.When you print the original, the output is normal. Figure 1: Sample output with vertical white or black linesc01892760.gif Figure 2: Sample output with vertical colored bands or linesc01892761.gif
NOTE: This article does not apply to most PSC products, to the Photosmart C6100 or C7200 series, or to the Photosmart Premium C309a and C309c All-in-Ones.If you are using a PSC product other than the PSC 2400 or 2500 series All-in-Ones, go to Vertical Bands, Lines, or Streaks in Copies, Faxes, or Scans (c01887564) (in English).If you are using a Photosmart Premium C6100 or C7200 series All-in-One, go to Vertical Bands, Lines, or Streaks in Copies, Faxes, or Scans (c00899181) (in English). If you are using a Photosmart Premium C309a or C309c All-in-One, go to Vertical Bands, Lines, or Streaks in Copies, Faxes, or Scans (c01622189) (in English). Solution one: Reset the All-in-One If there is static interference, or loose connections with the product, this can result in bands or lines in the copy, fax, or scan output. To resolve this issue, check the product connections and reset the product.
  1. Make sure the product is powered on, and then disconnect the power cord from the product.
  2. Disconnect the USB cable from the product, and then disconnect it from the computer.
  3. Reconnect the USB cable to the computer, and then reconnect it securely to the product.
  4. Disconnect the power cord from the wall outlet, and then reconnect it to the wall outlet.
  5. Reconnect the power cord to the product.
  6. Press the Power button (c01892763.gif ) to turn on the product.
  • If the issue persists , see the next solution.
Solution two: Clean the All-in-One and print a blank copy If the scanner glass or the white underside of the lid has fingerprints, smudges, lint, dust, or other debris, this can slow performance and affect copy and scan quality. To resolve this issue, clean the All-in-One. Before you begin, gather the following materials:
  • Several clean, soft, lint-free cloths
  • Mild glass cleaner
Step one: Clean the scanner glass and lid
  1. Press the Power button (c01892763.gif ) to turn off the product, and then disconnect the power cord from the product.
  2. Open the scanner lid. Figure 3: Open the scanner lidc01893292.gif
  4. Wipe the scanner glass and the white underside of the scanner lid with the dampened cloth. Figure 4: Scanner glassc01893293.gif Figure 5: Scanner lidc01893294.gif
  6. Close the scanner lid.
  7. Reconnect the power cord to the back of the product, and then press the Power or Start button (c01892763.gif ) to turn on the product.
Step two: Make a blank copy
  1. Remove any originals from the scanner glass.
  2. Load plain white paper in the input tray.
  3. Press Start Copy Black to make a blank copy.
If the copy is clean, there is no need to continue troubleshooting.If the copy has vertical bands, lines, or streaks, there might be dust inside the product, poor internal connections, or the product might be damaged. See the next solution. Solution three: Service the All-in-One If you have completed all the steps listed above and are still experiencing a problem, service the product. Causes
  • Static interference
  • Loose USB cable or power cord connection
  • Fingerprints, smudges, lint, or dust on the scanner glass
  • Dirt or debris on the scanner lid
  • Scratched or damaged scanner glass
  • Poor internal connections
  • Dirt or debris inside the product
  • Damaged or faulty scanner bulb or parts
Jan 27, 2010 | HP Photosmart 2610 All-In-One InkJet...
Hp Photosmart c5280 1/ 2inch thick black line
There is something on your scanner glass. Clean the glass with glass cleaner. If this happens when using the automatic document feeder, open the top side cover where the paper feeds into. There is a narrow glass strip there. Clean that as well.
If this fails, the scanner head has a bad sector on the CCD and will need to be replaced. You will probably find that it will be cheaper to replace the printer entirely if that is the case.
Jun 22, 2009 | HP LaserJet 3055 All-In-One Printer
I am trying to put a picture from my printer to my computer how do I do it.
To scan a picture into you computer, follow these steps below:
Follow the steps below to scan an image from the control panel:
1.
Lift the lid on the HP Desskjet F4180.
2.
Place the original on the glass with the side to be scanned facing the scanner glass and on the left front corner of the glass.
NOTE: For quality copies, ensure that the scanner glass is clean and that there are no foreign materials adhering to it.
3. Close the lid.
4. Press the Scan button located on the Printer. A preview image of the scan appears on the computer where it can be edited. The edits made apply to the current scan session only.
Make edits as desired to the preview image and click Accept .
NOTE: The Scan button does not work with the Windows 2000 operating system. The software CD contains drivers for Windows 2000 only and therefore has limited functions.
Cheers!
Apr 18, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
Canon printer MP470: I have never been able to use the OCR. Can you tell me how to click, click, click to do OCR? I go to MP Navigator/ One Click/ OCR/ then it says specify program where scanned...
Dear Tom,
No problem, you're a mere 17 steps away from creating a high-quality document using Canon's cutting-edge OCR software!
1. Load doc onto platen.
2. Press "SCAN" button.
3. Make sure "DOCUMENT" bar is yellow and press "OK" button.
4. Make sure "SCAN TO PC" button is yellow and press "OK" button.
5. Press "BLACK" button (w/ white diamond on it) located under the word "START" (might take a couple of tries as this button tends to stick a little.)
6. On computer screen, find image of doc that was just scanned and select it by clicking on little check box under image so a check appears. MAKE SURE NO OTHER DOCS ARE SELECTED AND/OR DE-SELECT THEM NOW.
7. On computer screen, find "double chevron" bar in lower left-hand corner and click on it.
8. Click on "EDIT/CONVERT."
9. Click on "CONVERT TO TEXT FILE."
10. This will bring up a new window. Click on the "blue arrow" with "1-2-3" next to it, located in upper left-hand corner of computer screen.
11. This will bring up a new window with three buttons to choose from. Click on the middle button, which says "PROCESS ALL UNRECOGNIZED PAGES"
12. This should start the OCR process and bring up a new window.
13. At this point, I just hit "CANCEL" and highlight & copy the OCR text by myself. (This will allow you to get around the "SPECIFY PROGRAM" program you referred to in your post.)
14. Then I open a new doc in Word (or whatever word processing program you use) and paste it directly into the new doc.
15. Then I save it into whatever folder I need to save it in.
16. Make sure to read through the doc and correct any OCR typos and/or "artifacts."
17. Save one more time to make sure you don't lose your work and you're done!
OPTIONAL 18th STEP: Open a beer and do a big bong hit -- you've earned it, soldier!
Aug 28, 2008 | Office Equipment & Supplies
