Question about Canon imageRUNNER C3200 Copier
My office has a Canon color imagerunner C3220. I want to use it to enlarge some images for a seasonal decorating contest. How do I break an image into pieces so that I can enlarge it into multiple 11x17 pieces? I very much appreciate your help. Best, Amy
  • 65 Answers
I can help. In order to do this, you press the "copy ratio" then you select "multi page enlarge" from there, you can either select the number of pages you want to use (meaning the machine will calculate the percentage by which it enlarges) or you can select the ratio you want to use ie how big you want it to be (the machine will calculate the amount of pages to fit that ratio)
I hope this helps.
Posted on Dec 05, 2008
  • Maurice Holliday Dec 05, 2008
    Did this information help you out?
I have a Image Runner C3200 and it is tinting the paper black when making copies
- clean the laser units glass with the special cleaning tool provided with the copier
- check and clean the image transfer belt blade and the recycle mechanism
- check if the tinting is on the imaging unit , if yes change unit if not chevk above
Jul 27, 2012 | Canon imageRUNNER C3220 Color Copier
Vartilcal white line on magenta color
there is few reasons for it:
There can be that a bigger amount of toner is on primary charge assy, or fault on image transfer belt, or fault on drum or magnetic cylinder of toner unit.
Without seeing the copier,its hard to say, but I would recomend to replace Magenta drum unit.
Hope that helps!
Sep 01, 2011 | Canon imageRUNNER C3220 Color Copier
I can not scan from my color image runner c3220 to my computer. Its on a network, and I installed the network ScangearTwain Driver. It see the scanner but does not allow me to scan. I can print to the...
its a titywity prob sir. i have also faced it .it sometimes work some times doesnt. if u have installed the scan gear then u have u use a scanner software life adobe etc to access the scanner through it. u can also use word,photoshop,corel etc to access it
May 26, 2011 | Canon imageRUNNER C3220 Color Copier
Large paper printing
12 x 18 is the largest size paper that can be used on this copier. If anything larger is used the machine will jam. The copier uses a series of paper sensors to track and time the paper throughout the printing process. The max is 18 inches anything over that cuase the machine to jam.
Apr 14, 2010 | Canon imageRUNNER C3220 Color Copier
When printing in color on a canon c3220, images have 'ghosts' or shadows
try to check your paper cassette setting and try to use user mode * select " auto adjustment / cleaning to fix the problem.
Jan 24, 2010 | Canon imageRUNNER C3220 Color Copier
How to print enevelopes from cannon image runner C3220
You simply run them through the bypass tray, about 10-15 at a time. There is no fast way to do it.
Jul 09, 2009 | Canon imageRUNNER C3220 Color Copier
How can i print envelopes from my cannon image runner C3220
Look on pages 2-42 thru 2-53 of the Reference Guide for the proper proceedure.
Ghosting image on canon c3220
Suggest to check the transfer unit. Especially the transfer cleaning blade..
Jun 12, 2009 | Canon imageRUNNER C3220 Color Copier
How to align an image runner C3200
The colour alignment is carried out automatically. Run auto gamma adjust. If this does not resolve anything, some part is at fault. Typical faulty item would be slipping transfer belt.
Mar 31, 2009 | Canon imageRUNNER C3220 Color Copier
Canon imageRUNNER C3200 Copier Logo
94 people viewed this question
old marine
old marine
